My Hoopte30 Project Attempt #6 - the painless way to earn cash back every day
  • AWDBOB
    • Aug 2013
    • 4393
    #511
    Originally posted by Northern
    Might have to fab up an idler to increase the wrap on either the crank, compressor, or both?
    I think i'm just a ham fisted ape and have been unable to get the tension perfect lol
    I would, however, kill for an M20 serpentine belt conversion kit. Paging whodwho save us from der v belt
    Originally posted by varg
    Do you have access to a welder? Grab a turnbuckle and a couple of pieces of threaded rod that fit it. Weld two curved pieces of round stock to the ends of the threaded rods then cut them to length and thread them into the turnbuckle, so it looks like )——≡≡≡——( . Tensioning tool, wind it in the whole way, place it between the pulleys, then expand it until the tension is just right and wind it in to remove it. A pain compared to a built in tensioner, but it would allow you to dial it in, tighten the compressor down, then remove the tool.
    ​This is a great idea that I am going to pursue, thank you!
    Originally posted by moatilliatta
    You could ratchet strap your seat post to your front tow hook to keep the tension on the bike?
    I have an E30 hitch, maybe just add a kuat rack?
    I have a hitch problem not a bike rack problem sadly. That' s a super duty 1UP rack, I could probably put a dirt bike on it in a pinch haha
    I was initially trying to make the hitch fully bolt on/reversible so i could do a group buy for them, but I may just perma mount them on both cars with a 3rd anchor point and be done with it.
    • AWDBOB
      • Aug 2013
      • 4393
      #512
      I was close with my old neighbor who passed away (C10 guy in the background of my photos if you've been around for a while). The family decided it was time to consign his pride and joy, a '35 MB, which is rumored to have been ordered and used by the German military.
      I helped them dig it out of its hiding place today, figured y'all would appreciate it.
      Untitled by bimmertown, on Flickr
      • e30austin
        • 15382
        #513
        WOAH. what a crazy piece of history to just be casually hanging out in a garage in Indiana. very very cool to see, thanks for sharing. this thread delivers, as per usual.
        • prisonerofdoom83
          • May 2013
          • 520
          #514
          Must refrain from making jokes about neighbors bbq skills
          • e30m3s54turbo
            • Jun 2010
            • 3212
            #515
            I would like to collect thoseGerman emblems, I’m a big fan of WWi and WWII.
            • 82eye
              • Jan 2009
              • 1916
              #516
              wild to see that.
              • AWDBOB
                • Aug 2013
                • 4393
                #517
                Glad y'all found that as cool as I did- just hanging out next door for 40yrs. They're going to send me the auction link when it's live, I'll post it here.
                Daily driver madness is still kicking my ass.
                Had to do front uprights on the Xterra, engine mounts, outer tie rods, and then a full clutch hydro line/component replacement.
                Finally got it all buttoned up and the drivers exhaust manifold fully broke off at the flange. My guess is it wasn't long for this world and jacking up the motor to do the engine mounts did it in.
                So now I have a full exhaust job from manifolds back to figure out, meanwhile keeping her Outback and my daily sedan hoopty on the road. The Outback got front uprights, front swaybar bushings/endlinks, rear 02 sensor, trans fluid flush with Idemitsu Type HP ATF, and other odds and ends to hopefully remedy the final check engine light of the cali to fed emissions conversion project.
                The things I do to avoid having car payments.....
                Tapping xterra engine mount threads 1/8 turn at a time
                Billys, new springs, and shock mounts installed with new Moog outer tie rods.
                Sedan hooptie has been getting hotter than I'd like despite me putting in a new tstat when I did the timing belt, so I bought a Mahle 80* tstat and tried out the $80 alloy ebay radiator since this thing is essentially a rolling parts car at this point.
                Core is thinner than stock, construction appears to be surprisingly decent. Don't love the drain plug design, everything else checks out.
                Car is now much happier. Was getting some belt squeal so I swapped belts out. That didn't change anything, so I may need to remove/wire wheel the drive pulleys. Belt alignment is fine, not sure what else it could be.
                • AWDBOB
                  • Aug 2013
                  • 4393
                  #518
                  Ever since I got the '87 Sedan Hoopty on the road it has had manual brakes and a fading MC under consistent brake pressure (see: pedal fade at stop lights).
                  I assumed the booster was bad, made sure the check valve was good first which it was, so it was indeed a bad booster.
                  All of the cast iron ATE MCs/Boosters I pull off of parts cars are rusty messes, but I have a few good late Girling spares.
                  The '87 325i is one of the cars with the weird horizontal pressure regulator (1156716) that mounts to the MC studs and hangs out under the MC. On the '87, both F/R lines run into this valve.
                  RealOEM says this valve is used from 7/86 to 6/87.
                  I grabbed a known good late Girling MC/booster and bolted it up. Brake line fitting sizes were the same, ATE brake master res mounted up the same, etc.
                  However, I noticed that the late Girling MC front port was stamped 17, and rear was stamped 22 (Front = Vor/V, Rear = Hinter/H).
                  On the 87 ATE MC the front port was stamped 20, and the rear 17, indicating the F/R lines may be switched on this MC.
                  I grabbed a spare ABS unit from an '89 and made sure the 87 and 89 ABS unit ports had the same inputs and outputs, which they did.
                  WHICH MEANS the '87 MC has reversed F/R ports. Following the flow in the horizontal pressure regulator I realized the regulator redirects the flow to the ABS unit.
                  All of the p/n's for early cars with ABS seem to be lumped under 1154918, but this means there are two early MCs, one with reversed ports for the 7/86 to 6/87 cars that received the weird reversed pressure regulator, and one without. As far as I can tell, the reversed port early 7/86 to 6/87 MC with weird pressure regulator is 1154405 and the normal port early MC with ABS without weird valve is 1154918​. Despite that p/n on bimmerworld being listed for cars "without ABS", 1154918 is listed on RealOEM as "with ABS". I verified the ports are the same as the late MC on the 1154918 early ATE MC without the weird pressure regulator.
                  I now have boosted brakes and a strong MC, but I kept the '87 pressure regulator which is reversing the flow, so I have a 17mm front bore MC and a 22mm rear bore.
                  Brakes feel incredible compared to the non functional old setup, but they still feel very weird with this switched.​
                  Anyway, I wanted to post my findings about this "one year" MC that I had no idea exists (which, fun fact, uses the same ATE MC reservoir as I've seen on some '88 cars).
                  Another '87 I had on the shelf with cut lines
                  The 1154918 ports
                  All done
                  • moatilliatta
                    • 6121
                    #519
                    Curious if you get the Billy Bounce.
                    Transportation trifecta.
                    @Zakspeed_US
                    • AWDBOB
                      • Aug 2013
                      • 4393
                      #520
                      I am anti front billy hd/sports, but I don't mind the stiffness in the rear. Helps drown out the destroyed trailing arm bushings lol
                      edit: I drove my buddies car last month that was refreshed by Ben Thongsai in Chicago with B4s all the way around and OE Sports and it felt great for daily spec. Plush and supportive like a nice bra, but without the typical Billy harshness.
                      This car has OE sports and KYBs up front, 50406 sports and B8s in the rear and its great for a rolling parts car. I did texas holdem this way too and it was good.
                      Granted, this is no comparison to OG hoopty with touring GC plates/coilovers, konis and spring rates that feel just right, but it's a fine affordable setup for a daily.
                      I'm still battling our DD struggles.... Xterra needs ball joints badly, so I wanted to get hooptie sedan daily-able in the meantime so I can take the xterra off the road to fix. Once it's all finished up and aligned I'm going to list it for sale and see if I can't get into a 6MT crosstrek or something.... if i can find a blown up first gen crosstrek I'll FB25 swap it. I'm over the body on frame cube 14mpg SUV life, and keeping it on the road past 200k when our other vehicle is a needy 05 outback seems futile. I can do one daily shitbox, not two. I need AWD/Manual/10yrs old, and Subaru is really the only thing holding down the fort on that these days, as much as I don't like them.
                      Turns out when you use your nastiest rusty pulleys and don't clean them up you get poor results. I was 99.9% sure I cleaned all of this up before install but I didn't.
                      Nothing but the best $4 belts for my rolling parts car. Cleaned everything up and it's happy. AC quietly blasting on the way to bike this evening
                      • AWDBOB
                        • Aug 2013
                        • 4393
                        #521
                        Blower fan exploded yesterday- installed one I pulled off of a parts car that looked to have been recently replaced. Adjusted the new belts while I was in there.
                        Replaced an expanding nut (what firewall rust?).
                        Hooptie daily life! Steering still feels super weird, pretty sure it's the rack or a USM bearing.
                        • AWDBOB
                          • Aug 2013
                          • 4393
                          #522
                          I was downtown tonight and the sky was prodigious
                          • Northern
                            • 5095
                            #523
                            I'll take your word for it
                            I didn't know second(?) gen Xterras had coil springs up front. Drastic change from the first gen's weird torsion spring thing. I just assumed it was the same vehicle underneath because Nissan.
                            Originally posted by priapism
                            Originally posted by shameson
                            • AWDBOB
                              • Aug 2013
                              • 4393
                              #524
                              They got coil springs starting in '05- the same year the Pathfinder got IRS! IRS on the Xterra would make it a better vehicle.... but so would 20mpg.
                              Sedan hoopty has always taken 4-5 seconds to start, and I finally got around to diag. Ohmed out the blue top and compared it to others at the same ambient temp, all good.
                              Installed a check valve in the fuel feed at the rail and it was better, still inconsistent, until it stopped helping and car reverted back to original symptoms.
                              Finally got around to swapping FPR, assuming it was bleeding off pressure, and the issue appears to be resolved.
                              I need to remove the check valve to verify the one in the pump is still good with the FPR fixed, and if not, reinstall it down by the external pump so there is more fuel in the line to allow the pump to catch up quicker for a smoother start up transition.
                              I should probably clean my injectors too, but that's for another day.
                              Pet a neighboring outside cat too much and made a pal
                              • mjweimer
                                • Dec 2015
                                • 649
                                #525
                                Everyone needs a good shop cat...keeps out the critters. Did you name the cat hoopty?
