Nonsense Thread
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #4936
    Nonsense Thread
    Originally posted by TeXJ
    I got here at 8am...been on a few calls/cases/incidents... For the most part it's been pretty easy.
    I take it you’re in law Enforcement?
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • flyboyx
      • 8371
      #4937
      i worked today. i finished this morning at 8. after my commute, i was home by 2. just in time to watch the lions lose.
      Gigitty Gigitty!!!!
      • TeXJ
        • 1914
        #4938
        IT, I help people with their Firewalls.
        1990 325is
        m52b28
        3.73lsd
        g260 (1987 325is 5spd tranny)
        • TeXJ
          • 1914
          #4939
          And I volunteered to work today. They give you a nice bonus for working holidays and off days. I also worked Monday too. I'm usually Tues-Sat.
          1990 325is
          m52b28
          3.73lsd
          • Exodus_2pt0
            • 5943
            #4940
            If we don't have plans, working holidays is a great way to get extra cash for me as well. Holiday pay plus overtime rate for the whole day. Makes for a pretty lucrative 8 hours.
            No E30 Club
            • mrsleeve
              • Mar 2005
              • 16390
              #4941
              I had turkey day off for some stupid reason. We really should have worked it. Oh well still get my 8 hours holiday pay . Will be working the rest of the weekend though
              Originally posted by Fusion
              William Pitt-
              • supermansocks95
                • Feb 2016
                • 756
                #4942
                I think I'm finally getting the x-brace for the e30 for Christmas. Then, come taxes, I'm gonna have that trailing arm and suspension swapped, and she'll be good to drive! Body work maybe in the next couple of years and a tune up/intake gasket replacement this summer hopefully.
                88 325i Cabrio
                04 Neon SRT-4
                If R3v was a dude, it would pick up a tinder date naked, with a raging boner, drunk, in an e30 with a shitty interior, a missing sunroof panel, explaining how its a classic while staring at the tinder date's tits.
                • rturbo 930
                  • Dec 2005
                  • 2629
                  #4943
                  Okay R3V, lend me your insight.
                  Several years ago, I refreshed the front end of my E30. E30 M3 bushings, new control arms, tie rods, strut mounts, etc. Took it to be aligned, caster was 9.2 on both sides. Car drove straight.
                  A couple years ago, I was driving, hit a bump (well, a dip), car suddenly drives kinda strange. I just had the car aligned, and sure enough, caster is 9.1 on driver's side, 8.7 on pass. side. Drives better now that the total toe is good, but pulls to the left. Turns easily to the left, harder to the right.
                  What will bend first in the suspension? I'm really hoping it's the control arm. I still have the old ones, just need new ball joints. Also makes sense since I have less caster now.
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #4944
                    Could a bent tie rod
                    • MrBurgundy
                      R3V Degenerate
                      • Mar 2012
                      • 5616
                      #4945
                      Yeah... I'd look at that outer tie-rod.
                      • rturbo 930
                        • Dec 2005
                        • 2629
                        #4946
                        Hmm. So a tie rod can affect caster? I would've thought only the control arm (or control arm mounting locations) or strut top could do that.
                        Looking at the two alignment sheets, I also see that the driver's side camber was, and still is, 2.1*, whereas the pass. side was 2.0*, and is now 2.2*.
                        • MrBurgundy
                          R3V Degenerate
                          • Mar 2012
                          • 5616
                          #4947
                          Nonsense Thread
                          I’d also look at where the control arm sticks out of the cab and see if there any noticeable difference in the length sticking out
                          Tbh; I’m not too familiar with what will cause that lol ;p
                          • rturbo 930
                            • Dec 2005
                            • 2629
                            #4948
                            I think this might be it. Looks like the pass. side arm isn't quite in all the way, about a 2mm difference. I measured my old control arms, and the ones on the car, from the center of the outer ball joint, to a point near the CAB to see if it was bent inward. Same measurement. Honestly, if it was bent, that'd be pretty shocking since it wasn't that big a bump. I could maybe see it being enough of a hit to dislodge it from the CAB slightly though.
                            I'll have to do some math to see if that ~2mm is enough to cause 0.4* difference in caster. Doesn't seem like it should be.
                            • varg
                              Florida Turbo Man
                              • May 2014
                              • 3439
                              #4949
                              Offset CAB? If it's poly it's possible to rotate them in the carrier, that will affect caster. You'd have to take a serious hit to bend the suspension and steering components, but the poly CABs are pretty easy to rotate if you push up on the control arm where it goes into the bushing, so I could see it rotating with a good bump.
                              IG @turbovarg
                              '91 318is, M20 turbo
                              • rturbo 930
                                • Dec 2005
                                • 2629
                                #4950
                                Not poly, OEM M3 CABs. That did occur to me that they could have rotated, but it doesn't look like they did.
