E30 Aerodynamics
  • RoccoB517
    • Jul 2013
    • 320
    #181
    This is the only one I can find. This happened at approx 175 mph as the car transitioned into the downhill braking zone leading into turn 10a at Road Atlanta. I had the wing for 3 years with no issues, but that is the first time the car has gone this fast. The wing was a plain weave carbon leading edge with two layers of unidirectional carbon followed by 5 layers of fiberglass cloth, cured under vacuum. I didn't notice and stress cracking or anything following the event, and had recently done shake down testing up to 140 or so without issue. My gurney flap you see there is 1/8" thick aluminum angle, and it bent like it was nothing. The top plates on the wing upright are bent also.
    Next wing will have solid carbon spars and will be several layers of carbon twill over uniweave. Live and learn.
    sigpicLevel Motorsport: www.levelmotorsport.com
    Instagram: https://www.instagram.com/levelmotorsport/
    Facebook: https://www.facebook.com/LeVelIndustries/?fref=ts
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #182
      Jesus christ that's wild. Also crazy fast in an e30
      Sent from my SM-G920T using Tapatalk
      Shadetree30
      • squidmaster
        • Aug 2011
        • 2666
        #183
        That's intense. Was the wing normally more inclined?
        Sent from my Robin using Tapatalk
        • 2mAn
          Señior Mod
          • 20740
          #184
          Damn 175mph!?! Going where no E30 has gone before...
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • LateFan
            • May 2013
            • 4404
            #185
            Who knew one of these bricks could go that fast?! Ever consider racing old Volvos?
            Did it try to take off at that point?
            I remember as a kid reading my road & track, when the Ferrari Daytona came out it could do 175 stock out of the box. "NO. F-ing. Way." we all said to each other.
            • RoccoB517
              • Jul 2013
              • 320
              #186
              No, I typically have run a low angle of attack. The straight line speed is what I seem to need in this chassis. The tires have always done the work in the corners. I am changing the profile and going slightly larger this time. I can afford a little more drag now. ;D
              • RoccoB517
                • Jul 2013
                • 320
                #187
                The aero really helps. Before the flat bottom and diffuser !45-150 was hairy. It is pretty stable over 160 now, but it still feels like something you shouldn't be doing. At any rate, the limiter in 5th doesn't lie. I had more than 50 yards of track left, so with lower gearing, who knows? I'm not going there, though. Especially living that 4 lug lyfe.
                • TheDirtyS54Thirty
                  • Dec 2016
                  • 88
                  #188
                  you're crazy ha! PS: what brakes set up are you running?
                  E30 S54
                  • RoccoB517
                    • Jul 2013
                    • 320
                    #189
                    Uhhhhhh.......UUC fronts and stock rears with G-loc pads......LOL.
                    Talking to Lee at Massive right now about upgrade options. She doesn't stop well.
                    • LateFan
                      • May 2013
                      • 4404
                      #190
                      Stopping is good.
                      • TheDirtyS54Thirty
                        • Dec 2016
                        • 88
                        #191
                        Dude I feel your pain, I have rx7 calipers and stock brakes in the rear and I can barely stop with just the S54.
                        E30 S54
                        • RoccoB517
                          • Jul 2013
                          • 320
                          #192
                          Lee at Massive is getting me all set up with his kits to accomodate Wilwood 4 piston rears and 4 piston radially mounted fronts on 11.75x1.25 rotors all around. Those, some G-loc pads, and a big ass new wing and we'll be in business.
                          • AirDoc
                            • Sep 2006
                            • 29
                            #193
                            Rocco - massive progression on your car..nice. What kind of times can you get at Rd Atl?
                            Nitin G. Shanbhag
                            BMWCCA #101510
                            76 2002, 88 M3 Racecar, 88 M3 2.5, 95 M3 Slicktop, 96 E36 Trackbeater , 97 M3/4 Slicktop
                            • RoccoB517
                              • Jul 2013
                              • 320
                              #194
                              Thanks, it's been a ton of work. No clean laps, unfortunately. I'd like to know what it can do as well. I think I ran a 1:39 on an outlap.
                              • Digitalwave
                                is a poseur
                                • 6298
                                #195
                                Bump.
                                Anyone have any updates to share? This thread was great.
                                RISING EDGE
