E30 Aerodynamics
  • Digitalwave
    is a poseur
    • 6299
    #226
    Looks like bedliner.
    RISING EDGE
    • flier129
      • 2
      #227
      Originally posted by Motheye99
      is that coating proprietary? I really like your stuff
      Raytheon, yes the rocket company, does the coating on our splitters and wangs. NA/NB are the only splitters we have currently,we're looking into other markets as well. We also offer a PDF template for those who wish to DiY the splitter with their own material.
      It's pretty close to that, lol. Something relatively inexpensive, holds up to weather/sun, and somewhat durable. Bed-liner or similar polymer is pretty popular, which helps costs.
      Marcus @ Nine Lives Racing
      • Sh3rpak!ng
        • Jan 2014
        • 2667
        #228
        Originally posted by ian e30 318is
        Onshape is free and what I use. The only stipulation if you don't want to pay is that all your work is public and can be accessed/copied by others. I messaged you on IG (Saltybeast) and my offer still stands to share the models with you if you'd like.
        Thanks! I thought I saw a message from you, but now its gone I will PM you
        Originally posted by flier129
        Quick thought, what reasons are there to have that splitter so short and not go back further towards the front axle? The oil-pan is pretty low right, but you can cut around that. The reason I ask is because we've seen yuge gains on CFD data from extending the bottom of the splitter back as far as possible, on multiple chassis.
        We've(9LR) been testing several materials on our NA/NB miata aero packages. 1/2" polymer coated birch, 10mm alumalight, and tegris have seen the best results. We've settled on 1/2" birch coated with...... "rocket nozzle" polymer It requires less mounting points than alumalite and just a tad heavier. Not too far off weight after we did some stress-testing on the birch and removed the material...
        Also, very relevant to this post and forum. E30 wáng kits are actually ready: https://9livesracing.com/products/e30-big-wang-kit
        I do plan on continuing the flat underbody, so it'll connect to the splitter. I wanted to make the actual splitter separate so if/when it gets smashed I can just swap in a fresh panel. Also so I could play with lengths, mainly to make a shorter option for driving around town.
        Kinda reminds me of Line-x? I wonder how line-xed plywood would holdup... or is that essentially what you're doing?
        Yes big wang kits are definitely of interest... I was eyeing the "builders kit" as I'd like to make my own mounts when the time comes...
        Shadetree30
        • Motheye99
          • May 2018
          • 853
          #229
          Raytheon, yes the rocket company, does the coating on our splitters and wangs. NA/NB are the only splitters we have currently,we're looking into other markets as well. We also offer a PDF template for those who wish to DiY the splitter with their own material. It's pretty close to that, lol. Something relatively inexpensive, holds up to weather/sun, and somewhat durable. Bed-liner or similar polymer is pretty popular, which helps costs.
          That's super, I just met with a friend from Raytheon today oddly enough.
          91' 318is 90' 325is
          Originally posted by Sonny
          Buy the E30s, they ain't gonna last long
          E30 can make you, E30 can break you
          "He who controls the Nova's, controls the Boomers"
          • haaken675
            • Sep 2016
            • 601
            #230
            Already ordered mine!
            • dvallis
              • Oct 2015
              • 1474
              #231
              Necro-Bump for this thread. Anyone know the legal width for an E30 wing in NASA and SCCA?
              NASA Super Touring rules only have a width restriction for ST4. (We'll be ST3 by my calculations.) Height is limited to 8" over roof line
              SCCA GCR 2021 calls out 65-5/16" for most classes. Height seems to be all over the place.
              I measured the car width as 64.2". Internet sources call out 64.4" - 64.7"
              So, I'm thinking 64" wing from 9Lives with an adjustable mount, flush with roof (18" rise) or 6" over roof (24" rise).
              Thanks
              "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
              1987 E30 3L Turbo Stroker Das Beast
              2002 E39 M5
              • moatilliatta
                • 6151
                #232
                I wouldn't go over the roof, And that wing doesn't look to efficient posted above.
                Thoroughly tested and race-proven wing elements available in custom lengths with custom mounting tab design and spacing to fit existing wing uprights. Downforce and drag data for each wing design is published to help you make the best choice to suit your needs.
                @Zakspeed_US
                • dvallis
                  • Oct 2015
                  • 1474
                  #233
                  Here's some data on the 9Lives wing.
                  The price and availability of aerodynamic car wings are making them more common in crap-can endurance racing. You can buy a cheap extruded aluminum wing on eBay, Amazon, or other online retailers f…
                  2002 E39 M5
                  • Digitalwave
                    is a poseur
                    • 6299
                    #234
                    Talk to Johnny at 9 Lives, he runs with NASA a lot and can point you in the right direction. I agree, you probably don't go 6" above the roof with the wing.
                    RISING EDGE
                    • dvallis
                      • Oct 2015
                      • 1474
                      #235
                      I talked to Johnny. (Nice guy) They run the wing 65" wide and 16" above the trunk. Legal for NASA, SCCA and BMW CCA. Got mine on order.
                      2002 E39 M5
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #236
                        9lives has been a staple in the racing community for a while. Worth the price tag if you want to be competitive.
                        john@m20guru.com
                        Links:
                        • dvallis
                          • Oct 2015
                          • 1474
                          #237
                          I love my wing : - )
                          2002 E39 M5
                          • hasa
                            • May 2013
                            • 306
                            #238
                            Normally competition wings like this (not riceboy cosmetics) are attached to rigid places on car body, or supported with tubular constructions. Do you have some extra tubing under the trunk lid?
                            • Digitalwave
                              is a poseur
                              • 6299
                              #239
                              Nobody makes a "frame mount" wing kit for E30s unfortunately. The trunk seems strong enough to support this sort of installation.
                              I have a Bimmerworld V3 carbon wing (65" wide, 18" uprights) and it's mounted the same way. I can more or less hang on the wing. The trunk is pinned tightly (hood pins in front, latches in back) to take up any slack in the trunk seal.
                              RISING EDGE
                              • hoveringuy
                                • Dec 2005
                                • 2722
                                #240
                                What kind of "before and after" data do you guys have? cornering speeds? lap times? straight top speed?
