E30 Aerodynamics
  • whitebulat22
    • Apr 2014
    • 330
    #136
    Another thanks to pondhopper! I won't spoil the results in mpg gains from the articles, but I will definitely have to see how much I can replicate them on the 2.7i's OBC meter. I also like that the vgs were placed on the rear windshield and found working, this is probably better to help a spoiler work too.
    • squidmaster
      • Aug 2011
      • 2666
      #137
      Haha I love that string testing in the articles. Would love to see the results. Seems like you'll need quite the camera and maybe a chase car to keep up however.
      I'm going to look into building a multi-sensor pressure monitoring system to do some testing as well
      • ForcedFirebird
        • Feb 2007
        • 8300
        #138
        If you could meet us in Daytona, we reach terminal velocity twice per lap (laps are ~1:35min). Next race is April Fool's day...only have 5min between 2hr sessions in the pits, though. We have an e30 and a w210 MB you could play with.
        john@m20guru.com
        Links:
        • squidmaster
          • Aug 2011
          • 2666
          #139
          John, did you check out the articles pondhopped poster? Sounds like it'd be a perfect opportunity to toss on the yarn... twine.... tampons? whatever the proper name for thick wool string is.... You'd be able to record for a long time with good angles and stuff. I won't be back in FL until the summer
          • ForcedFirebird
            • Feb 2007
            • 8300
            #140
            I was offering up a test mule if you wanted to do pressure sensors. Unfortunately we have enough going on just top keep in-car cameras rolling, fueling the cars, changing drivers etc...specially if we have 2 cars :/.
            Read about the string a long time ago, but they would probably be easier at the next sprint race.
            john@m20guru.com
            Links:
            • squidmaster
              • Aug 2011
              • 2666
              #141
              I'll give you a shout when I'm in FL to see if you have any events going on. Will try to hobble together a data logger by then
              Cheers
              • squidmaster
                • Aug 2011
                • 2666
                #142
                I know no one gives a flying frisbee about gas mileage here, but I do. A lot. Anyway, if anyone is interested, I'm seeing a 30% (thirty percent) increase in highway cruising MPG with my vortex generators and tuning (sorry, still not on an e30, my e30 is currently on its way to california to have it built by bimmerheads)
                http://sssquid.com/v2/vortex-generat...013-wrx-hatch/
                • Panici
                  • Dec 2009
                  • 2419
                  #143
                  I care about gas mileage. Efficiency can never be a bad thing.
                  How are you doing the data capture and/or simulation? I've never modeled aerodynamics before, but I would be interested to learn.
                  '87 BMW E30 325is Turbo
                  '99 BMW E36 M3 - - - '98 BMW E36 328i
                  • squidmaster
                    • Aug 2011
                    • 2666
                    #144
                    The simulation is done in CAD programs and datalogging is done through OBD2
                    offering up beta sets of 8 for 30 shipped if anyone wants some
                    • Panici
                      • Dec 2009
                      • 2419
                      #145
                      Specifically which software package(s) do you use?
                      • squidmaster
                        • Aug 2011
                        • 2666
                        #146
                        blender solidworks and a little fusion 360
                        • Panici
                          • Dec 2009
                          • 2419
                          #147
                          You're doing the airflow simulation in Blender?
                          From some quick research, it looks like Blender is geared towards doing visual simulations for aesthetics, and it doesn't do accurate computational fluid dynamics (CFD).
                          Again, this is only what I gleaned after 5 minutes of googling.
                          • varg
                            Florida Turbo Man
                            • May 2014
                            • 3387
                            #148
                            Vortex generators are interesting and highly effective in some applications. You don't need big pieces of molded plastic to have a vortex generator, the ones you see on aircraft are mostly little pieces of bent aluminum installed at an angle with respect to air flow. They don't have to be very tall, since they only act to keep the boundary layer attached, I've seldom seen them more than 1.5" in height on private and small commercial aircraft. I have even seen them put on RC planes and have seen a noticeable difference in stall characteristics. When you look at the roofline of an E30 from the side, you can tell that there will be serious flow detachment on the rear window because of how steep it is. An A/B tuft test is simple, and some small vortex generators placed along the roofline in a manner similar to what you see on an old Mitsubishi Evo would most likely make a noticeable difference in air flow over the rear window. How much of a difference this would make on the track or for fuel economy would have to be seen. I suspect not much.
                            I've thought about putting them on my E30 before, just never got around to it, finding some cheap ones or fabricating my own.
                            IG @turbovarg
                            '91 318is, M20 turbo
                            • 2mAn
                              SeƱior Mod
                              • 20670
                              #149
                              the ones I got from airtab are cheap, though if squid had his when I was looking, I wouldve just bought his. I like supporting r3v
                              Simon
                              Current Cars:
                              -1966 Lotus Elan
                              -1986 German Car
                              -2006 Volkswagen Jetta TDI
                              Make R3V Great Again -2020
                              • squidmaster
                                • Aug 2011
                                • 2666
                                #150
                                Simon, how much did you pay for your airtabs? I've sold a couple of sets of my 3d printed VGs at $35 shipped for 8, and you get a credit for the injection molded product when it's finished with manufacturing
