PNW Chit Chat thread
  • Pdxseth
    • May 2012
    • 3124
    #21571
    Got the hood to fully latch on the e28....now it won't open and my coolant light is on fml
    • HarukoE30
      • Nov 2011
      • 1057
      #21572
      Originally posted by Austin!
      Never had any issues getting them on. Use a hammer if necessary.
      This is pissing me off, It's halfway through the rubber, but doesn't want to budge with hammering away at it.
      Originally posted by James Crivellone
      1) The internet is NOT serious business.
      • bmwm42
        • 6300
        #21573
        If your using stock rubber jay good luck I had to use a press if your using poly etc it should be easy
        Originally posted by bmwm42
        PNW vulture pm me for parts
        Strategic nw e30 command
        • EN318isPDX
          • Oct 2007
          • 4373
          #21574
          Lube always helps!
          • MT325is
            • May 2012
            • 1103
            #21575
            Originally posted by EN318isPDX
            Lube always helps!
            That's what she said!
            1989 BMW 325is (SOLD)
            1992 BMW 325IC (SOLD)
            1991 BMW 318IS (STOLEN!)
            2017 BMW M2 (WEEKEND WARRIOR)
            1989 BMW 325IC (PROJECT(
            2002 FORD ESCAPE (DAILY)
            • HarukoE30
              • Nov 2011
              • 1057
              #21576
              It's rubber Lemfoerder & it's looking like my control arms need to come off, which means no meet tomorrow.
              Soap and hammering the left side has it to the end of the rubber, but I just can't get it to go on. The right side is dripping with lube and doesn't budge beyond the front part.
              edit: Going to see if Autozone has a press tool I can use to ratchet the bushing on. Fucking pissing me off missing the DUKE game!
              Edit Edit: Autozone doesn't have anything...
              • e30austin
                • 15382
                #21577
                Try a oreillys. Nobody else rents tools. Maybe baxters. I never have had that much of an issue getting them on. Only removing them, which I just cut them off with a cut off wheel.
                Hope you can figure it out. Haven't seen you in a while.
                '70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
                • Pdxseth
                  • May 2012
                  • 3124
                  #21578
                  Fuck. Got the hood to a point where it worked a little better then the fuckin handle broke inside
                  • e30austin
                    • 15382
                    #21579
                    Hahahajahahaha
                    • HarukoE30
                      • Nov 2011
                      • 1057
                      #21580
                      Nah I'm out for tomorrow. There comes a point where you have to know when to stop & this is something that needs a press.
                      • EN318isPDX
                        • Oct 2007
                        • 4373
                        #21581
                        vattozone rents tools
                        • MT325is
                          • May 2012
                          • 1103
                          #21582
                          Hey you guys think that using 5w-40 oil.. Would make the oil pressure light go on at idle? Cuz ya mine started doing it!
                          • e30austin
                            • 15382
                            #21583
                            Change to 20w50. Could be that you have a bad oil pressure switch on the block, though. Or you did something wrong during assembly.
                            • EN318isPDX
                              • Oct 2007
                              • 4373
                              #21584
                              Why are you running 5w-40?
                              Change to 20w50
                              • MT325is
                                • May 2012
                                • 1103
                                #21585
                                It wasn't doing it before I took it apart. And when I drove it yesturday with 5w-20 or 5w-30 I forgot which one. And today poured this new stuff in and it turns on now.
                                I actually used to to try it out. Go thinner at hot... But I don't think it works well.
                                The previous one I had I ran 5w-50 just because I felt like it. But then again... My dash lights were not working on it.
