PNW Chit Chat thread
  • AndrewBird
    The Mad Scientist
    • 11898
    #33496
    Dug into this a bit more. The E30 harness is completely self contained other than a power wire connected at the 25-pin accessory connector (C302) under the dash and a ground wire also connected under the dash (G200).
    E36 looks to be basically the same, power at X63, ground at X173 with an additional wire for the switch lighting coming from the headlight switch.
    So basically hook the wire from X63 into C302, ground X173 where G200 is and the light wire to the gray/red wire coming off the e30 light switch.
    Wiring diagrams can be found here:
    I used a 91 318is manual for E30 seats, a 94 3-series manual for E36 seats and an 88 325 manual for location views.
    Good luck!
    • Henna30
      • May 2012
      • 1494
      #33497
      I'll just leave this here.... Good for a laugh.
      • Savagefurai
        • Apr 2011
        • 970
        #33498
        1991 BMW 318i 4 Door - $1450
        Sent from my SM-G530T using Tapatalk
        Currently without an e30. Will probably die soon.
        • AndrewBird
          The Mad Scientist
          • 11898
          #33499
          RUST. No thanks.
          • Pdxseth
            • May 2012
            • 3124
            #33500
            Originally posted by Austin!
            ETA exhaust will be more restrictive than an "i" exhaust, but it will bolt up and function. Seems like you'd be downgrading, but I digress.
            I disagree my sedan (m20b25) had an eta mid section with 2" straight and I think it helped out quite a bit in the bottom plus it sounds awesome.
            • Pdxseth
              • May 2012
              • 3124
              #33501
              Originally posted by AbeSonic
              Fuckin A! Shit got really hairy when I couldn't pop the hood open with the release lever to fight the fire. Had to go through the front with a screwdriver.
              I've got an 86 eta harness
              • Pdxseth
                • May 2012
                • 3124
                #33502
                Finally got an o2 on the coupe it's so much better, much healthier and it's now on its 3rd oil change in less than 200 miles. This time the oil was mostly gas from running so rich, first time was busted pan, this car is killing me but it's getting there
                • e30austin
                  • 15382
                  #33503
                  There you go dude. Seems like you're starting to give a shit about it again.
                  • Pdxseth
                    • May 2012
                    • 3124
                    #33504
                    Well it's my only car now so I have to actually care about it.
                    • e30austin
                      • 15382
                      #33505
                      Fair enough.
                      • kid325e
                        • Sep 2007
                        • 6421
                        #33506
                        Pulled the M20 2002 out of the garage for the first time under it's own power tonight. Threw the car cover on it and will double check a few things before going on a run around the block tomorrow. Just wanted to update you all, the engine feels bad ass in this chassis.
                        clutchCTRL!
                        Move with a purpose.
                        - 1991 325iX 4dr/5spd
                        - 2000 323i AT
                        2016 Mazda CX3 Sport AWD
                        • Pdxseth
                          • May 2012
                          • 3124
                          #33507
                          It's too damn cold! Just finished swapping bumpers, cluster check panel, now I get to tackle the lack of heater and shift linkage issue and I may be able to sort of comfortably drive this pile
                          • Henna30
                            • May 2012
                            • 1494
                            #33508
                            Just in case anyone is interested.. If I had the room Id go for it. Looks like actually a pretty decent car! Someone get this!
                            • DER E30
                              • Sep 2013
                              • 2343
                              #33509
                              http://www.copart.com/us/Lot/37151265?searchId=59965459
                              Looks pretty good actually, why do I have class on Monday?!?!?!?
                              I'd totally go pick that up, I finally sold my jeep today
                              -Christian
                              • 4tDX
                                • Jul 2014
                                • 507
                                #33510
