PNW Chit Chat thread
  • 4tDX
    • Jul 2014
    • 509
    #35806
    Originally posted by EN318isPDX
    I should have a couple S52 ones. used but might be valid for a test
    Thanks!
    Pm'd.
    • djjerme
      • 5082
      #35807
      Originally posted by bruner
      Sup guys. Anyone have a set of rear seat belts from an 84 or 85? Text me at (360)920-8846 if so. I got cash or PayPal ready
      Sent you a text..
      2016 Ford Flex
      • delamaize
        • Nov 2013
        • 1463
        #35808
        Originally posted by der e30
        my steering rack is so tight
        $10,000 engine rebuild soooooooooooooooooooooon!
        Dumpster Fire Pilot
        • djjerme
          • 5082
          #35809
          Track day NO!
          speaking of things unrelated - when tha hell is someone going to organize a dyno day?
          2016 Ford Flex
          • Matt-B
            The Waffler
            • 3856
            #35810
            Any shops with decent parking and a dyno in pdx?
            Maybe add a BBQ? I can ask around.
            • MPLFoster
              • May 2013
              • 1490
              #35811
              M20 no start issue...anybody have any ideas?
              form.follows.function IG @mplfoster
              • Rennsport
                • 2139
                #35812
                Do you have spark? crank position and spark inductive sensor plugs mixed up? (they look the same, easy to do)
                m106 1990 e30
                e36 daily
                e32 cruiser
                • MPLFoster
                  • May 2013
                  • 1490
                  #35813
                  yup. good signal to and from the coil. CPS is connected to correct plug.
                  • Matt-B
                    The Waffler
                    • 3856
                    #35814
                    Pulled fuel line and getting fuel while cranking?
                    • MPLFoster
                      • May 2013
                      • 1490
                      #35815
                      yes, fuel line pressurizes up to spec.
                      • Matt-B
                        The Waffler
                        • 3856
                        #35816
                        Is there a ground on fuel rail like 24v? Sounds like injectors aren't operning. I keep a few spare injectors to plug in and crank.
                        Could be a bad relay perhaps, on the new harness?
                        • Matt-B
                          The Waffler
                          • 3856
                          #35817
                          M20 harnesses are also known to wear thru a small wire , or so I hear. And make injector harness not work
                          • djjerme
                            • 5082
                            #35818
                            just 24v swap it and be done with it..
                            The harness connector plug on the side of the block is a known failure point. Clean it with some contact cleaner, pack it full of Dielectric grease and check it. Often, I take them out of the factory bracket and just let it hang out.
                            2016 Ford Flex
                            • MPLFoster
                              • May 2013
                              • 1490
                              #35819
                              The injector harness plugs into the engine harness where it has a grounded pin. i checked the plug and all signals are good. injectors pulse while cranking.
                              I feel dumb for this but i hadnt thought of swapping the relays from either harness. i will try each relay in succession.
                              any idea which wire wears thru?
                              Intake side where the injector harness plugs into the main engine harness? i noticed it was a bit oily. i will clean it and get some dielectric grease in there. thanks for the ideas. i'll try these things and report back.
                              • MPLFoster
                                • May 2013
                                • 1490
                                #35820
                                and i wish i had the means to go 24v. would be nice but not in the cards at the moment.
