PNW Chit Chat thread
  • Matt-B
    The Waffler
    • 3856
    #40801
    I thought AKG had there stuff made from a company in INDIA, i have heard this many times. I forget the plastic companies names
    • Rennsport
      • 2139
      #40802
      Does anyone have experience with Wa state patrol VIN checks? I saved a e32 from the scrappers last night and I'l need to have a VIN check prior to registering it. I'm slightly worried that the flashing SRS light will cause me to fail the inspection.
      m106 1990 e30
      e36 daily
      e32 cruiser
      • Metallated
        • Dec 2016
        • 1074
        #40803
        I have no idea, but I thought about registering two lachs cars under one registration/set of plates.. never ended up doing it though.
        If someone could give me a hand welding a nipple to the oil dipstick for my obd2 ccv that would be much appreciated.
        • e30austin
          • 15382
          #40804
          Pull the bulb...
          • Preyupy
            • Oct 2012
            • 73
            #40805
            If you have the title and it matches the VIN on the car that is all they look at. You don’t even have to be able to drive it in, you don’t need to turn on the ignition. If it is a salvage title there are other hoops you might have to jump through but a flashing SRS light won’t be your biggest problem.
            • Rennsport
              • 2139
              #40806
              Originally posted by Austin!
              Pull the bulb...
              I've been told they put the key in to make sure the srs light comes on at start up. Otherwise it would already be out.
              m106 1990 e30
              e36 daily
              e32 cruiser
              • 2mAn
                Señior Mod
                • 21017
                #40807
                Does the car still have the airbag wheel?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • Rennsport
                  • 2139
                  #40808
                  Yes. It pulled about 4 codes, front crash sensors and front crash sensor wiring. I noticed on the plugs was loose. Fixed it and reset the codes. airbag light came back on.
                  m106 1990 e30
                  e36 daily
                  e32 cruiser
                  • MikeM
                    • 583
                    #40809
                    Alright based on some research I think this should all work fine, however I've never bought aftermarket wheels and I'd like some sort of assurance before I buy new wheels/tires. See below
                    Car: 1990 325i Coupe
                    Suspension: FA 500 coilovers
                    Wheel: TRM C1 15x8 et20 all corners
                    Tire: 205/50/r15
                    Can someone confirm this will work without any rubbing? Do I need spacers??
                    Thank you!
                    1990 325i Coupe
                    ///PNW e30 CREW
                    • ncsubowen
                      • Nov 2013
                      • 1012
                      #40810
                      Your best bet is to ask other with those wheels or a similar setup. If you have coils and you cut off the spring perches then you're not likely to have an issue, et20 is *usually* good enough on an e30. If you don't want to roll your fenders you can always set the coils a bit higher.
                      4 doors.. so much room for activities!
                      IG @bluebombr
                      Transaction Feedback:
                      http://www.r3vlimited.com/board/showthread.php?t=323622
                      • TobyB
                        • 5293
                        #40811
                        If the car just needs a VIN check for registration, it will probably be ok. They look
                        at the various VIN tags, fill out a statement of fact, and send you on your way.
                        If it needs an inspection due to being 'insurance destroyed' or otherwise 'rebuilt' you will need to have
                        a functioning SRS light. It has to come on with the engine off, key on, and then
                        go out within 5 seconds of the engine being started. I went through this with a ti a few years ago-
                        fortunately, it was the occupancy mat, and the clear held long enough to get it inspected.
                        The Bellevue WSP is pretty painless- they are 3 or 4 car guys who are happy to not
                        be rolling drunks. If you show up with your paperwork in order, they really do try
                        to make your life no harder than the law requires. I built a trailer years back, and they
                        were very helpful with the whole process.
                        And the ti inspection was pretty easy, too.
                        t
                        • Rennsport
                          • 2139
                          #40812
                          Thanks Toby, I believe it just needs a VIN check since there's no signs of it ever been in a wreck. I think I'll make an appointment and see how it goes.
                          m106 1990 e30
                          e36 daily
                          e32 cruiser
                          • Matt-B
                            The Waffler
                            • 3856
                            #40813
                            Tire: 205/50/r15
                            Thank you!
                            Lower your car....... theeeen look at wheels
                            But as long as your not going dirt nasty low and installing
                            Turbskis you should be ok
                            • MikeM
                              • 583
                              #40814
                              Check ✔️
                              Coilovers arrive this Thursday. Wheels/tires to be purchased in a couple of weeks. It won't be going dirt nasty low. Thanks!
                              1990 325i Coupe
                              ///PNW e30 CREW
                              • ahrensNW
                                • Mar 2015
                                • 1716
                                #40815
                                Tire: 205/50/r15
                                Thank you!
                                I had 15x8 et 20 trm c1 on my car last year with 225 50 kuhmo ecsta ast. I think I had a 5mm spacer on the front. No real rubbing issues.
                                And I'm probably lower than you lol.
                                Hank Ahrens
                                1984 Alpine Coupe
                                1978 911sc
