PNW Chit Chat thread
  • shifty
    • Feb 2012
    • 107
    #10396
    Dude. Your car is cursed.
    • 5Toes
      • 9836
      #10397
      lol its not too bad of a leak. Just a drip drip.
      I bet snugging down that corner's headbolt a bit would stop it.
      Also my alternator/water pump belt has stretched a bit so I need to snug that up
      • 10Toes
        Me Father Was A Tree
        • Jan 2008
        • 61222
        #10398
        This will end well...
        • PNWDan
          • Feb 2011
          • 1326
          #10399
          What? Dude be sure you know where that drip is actually coming from. If its the head gasket then tightening a head bolt wont do anything for you.
          1987 Alpinweiß 325is
          Like the PNW E30 Local Crew Facebook page
          • 5Toes
            • 9836
            #10400
            I havnt done anything to it.. I traced the drip up to the front left corner of the headgasket.
            • george graves
              • 19998
              #10401
              I can't wait to see all the things you'll break doing a headgasket :up:
              Originally posted by Matt-B
              • 5Toes
                • 9836
                #10402
                Maybe I should sell my car while it works..
                • Jparkr
                  HR Admin
                  • Jan 2006
                  • 3494
                  #10403
                  ^like
                  1987 PRO-3 car /1990 325is (2.7i Concours)
                  • e30austin
                    • 15382
                    #10404
                    Andrew, quitting while you're ahead is not the same as quitting altogether. Put it up for $1500 firm and dump it.
                    • 5Toes
                      • 9836
                      #10405
                      Not a bad idea.
                      Then find a shitbox :p
                      • shifty
                        • Feb 2012
                        • 107
                        #10406
                        Sounds like a merry-go-round.
                        • 5Toes
                          • 9836
                          #10407
                          However, on a serious note.
                          IF the leak is from the headgasket, and the oil has no coolant in it, and the coolant has no oil in it... then what is there really to do about it??
                          • george graves
                            • 19998
                            #10408
                            Headgasket and machine the head, new upper gasket kit....plus what ever else you break during the process
                            • 5Toes
                              • 9836
                              #10409
                              When I did the headgasket I had the head machined as well as I sprayed the gasket with two coats of copper sealer.
                              Hmm Ill investigate this in depth tomorrow. I will use the chalk on the engine trick
                              • shifty
                                • Feb 2012
                                • 107
                                #10410
                                If it's truly a coolant leak from the proximity of the head gasket and there is no mixing of oil / water, there are a couple possibilities. I typically suspect a head or block crack, but sometimes you get lucky and that's not it.
                                It's harder to do on an e30 cooling system than others, but keep an eye out for unusual bubbles in the coolant. Those would be gases escaping a cylinder.
