Markert Motor Works Dyno Thread (many inside)
  • hoveringuy
    • Dec 2005
    • 2751
    #151
    ^ 234hp out of an N/A M54 is fantastic!
    • NC325iC
      • Mar 2004
      • 6565
      #152
      Originally posted by ForcedFirebird
      Nice power from that 2.8! I am always telling people to use the 2.8 and just cam them, but they all go for that extra displacement.
      Well sometimes the extra displacement is just more available...
      • ForcedFirebird
        • Feb 2007
        • 8300
        #153
        Of course, but also at an extra cost. Compare a purchasing a 2.8 with m3 cams and buying an s5x.
        john@m20guru.com
        Links:
        • NC325iC
          • Mar 2004
          • 6565
          #154
          I did... Came out about the same (varying mileage)
          • 2mAn
            Señior Mod
            • 21043
            #155
            I love my M52 with M50 intake and S52 cams. Nearly as much power as what my friends S52 made (225whp vs 234whp)
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • 328ijunkie
              • May 2007
              • 3961
              #156
              Added a customers SC E92 M3 we assembled. Is *currently* running a BPMsport tune...
              S65 E92 M3 Pre and Post Supercharger. 6.5psi intercooled, BPMSport Tune... No other changes... 2 Best runs.
              Check Us out on Facebook
              Full Product Line Tuning
              • JGood
                • Jan 2004
                • 7959
                #157
                Interesting. That's a very small, peaky, high RPM gain. Not the steady, linear increase from idle to redline I'd expect. You guys going to tune it?
                Good example of a 100whp gain sounding great on an advertisement, but not so great on the street.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • 328ijunkie
                  • May 2007
                  • 3961
                  #158
                  Will be looking further into the car sometime late this week to go back over everything and make sure we dont have any crazyness with vac/boost leaks or anything before looking into the tune. We may be retuning it but it is *currently* outside of our expertise as of today.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #159
                    Just another quick comparison:
                    S52 w/M50 manifold otherwise stock ZM3 vs E46 330 with intake/headers/exhaust:
                    • 328ijunkie
                      • May 2007
                      • 3961
                      #160
                      Tuned a E90 M3 today! Bone stock 30K mile car. Test Pipes coming next.
                      • e30polak
                        • 6136
                        #161
                        Then Tuned a E46 330i, Car had headers, AFE Intake, and muffler. DISA changeover could use some love.
                        Wow, that would be a blast in an E30! This is a non-ZHP? If so any idea how much ZHP cams or Schricks would add to this?
                        INSTAGRAM: @UNDR8D_EMPIRE
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #162
                          Correct, non ZHP. Per BMW the ZHP cams add ~10hp. not confirmed this myself....
                          • The Dark Side of Will
                            • Jun 2010
                            • 2796
                            #163
                            That's exactly what a centrifugal supercharger does.
                            That's what a constant displacement blower like a Roots, Eaton, Lysolm, Kenne Bell, AutoRotor or Whipple does.
                            Automotive product advertised to be better than reality? Say it isn't so...
                            Centrifugally supercharged cars can be VERY fast, but just like anything else, need more than 5 psi of boost to do so.
                            • digger
                              • Nov 2005
                              • 6198
                              #164
                              There is something wrong with that car. That's not how it's supposedto work
                              • 328ijunkie
                                • May 2007
                                • 3961
                                #165
                                After some diag on the seemingly simple PnP kit.... Car is at 4psi at redline. Customer bought kit used. Previous owner of kit 'added' the intercooler to the VF stage 1 plenum and it leaks like hell as it turns out. Will be posting new results once we either figure out a proper way to seal IC or replace plenum with a real stage 2 one.
