Markert Motor Works Dyno Thread (many inside)
  • Jb325is
    • 2137
    #121
    Yes, I did a bad job making my exhaust. I think I am going to build something like the Bimmerworld race exhaust next so I can at least keep one of my mufflers
    - '88 m54 coupe
    <3
      • 34844
      #122
      You could leave the axle back portion 3.5", making the first section smaller is going to make the biggest difference.
      • LJ851
        • 7919
        #123
        It would be nice to tone it down a notch...
        Lorin
        The M30 is God's engine.
        • digger
          • Nov 2005
          • 6194
          #124
          i wouldnt copy bw, just build your own
          • e30polak
            • 6136
            #125
            Originally posted by digger
            if you put the y-pipe that merges to 3.5" in the right spot you dont lose the bottom end anywhere near as much. seems to be more about length than size in this area of the exhaust.
            just maintain the twin secondaries (collector) far enough before using a Y or X and you'll be sweet
            Correct. The merge is very important, and that's what ruins most s54 exhausts.
            This. BW's exhaust still has consistent dynos showing poor bottom end torque, their merge is too close to the headers.
            INSTAGRAM: @UNDR8D_EMPIRE
            • 328ijunkie
              • May 2007
              • 3961
              #126
              6/10/15
              Another E46M3, this one bone stock. 125k on the clock...
              Progression:
              Also Tuned a WAR Chiped OBD1 S50. Ended up ripping out war chip and just throwing a regular 413/chip in there when all was said and done. Car had nice headers/midsection, intake and stock other than that.
              Check Us out on Facebook
              Full Product Line Tuning
              • ForcedFirebird
                • Feb 2007
                • 8300
                #127
                Originally posted by 328ijunkie
                ...Ended up ripping out war chip and just throwing a regular 413/chip in there...
                Told 'ya so. ;) :p
                john@m20guru.com
                Links:
                  • 34844
                  #128
                  wow.. the installer of that WAR chip must have wired it wrong. ;)
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #129
                    Dave hit me up about the WAR, and just happened the day before I ripped one out of a turbo m20 e30 and put in MS. I got fed up with it as well.
                    john@m20guru.com
                    Links:
                    • squidmaster
                      • Aug 2011
                      • 2666
                      #130
                      Whoa that's a funkkkky graph
                      nice numbers on the m3!
                      • amcp
                        • 489
                        #131
                        246 from a OBD1 S50??? color me intrigued.......
                        Any details on it?
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #132
                          Just had generic Intake/3.5MAF/24lb injectors (Stock cams) some nice headers and exhaust.
                          • 328ijunkie
                            • May 2007
                            • 3961
                            #133
                            To continue S54 Exhaust Discussion:
                            Stock S54 E46 M3 vs JB's S54 E30
                            Also ironically: BW race Exhaust car (and highest ive ever dyno tuned) vs JB's E30 S54:
                              • 34844
                              #134
                              man, don't make him feel bad about it! lol
                              but, 344whp is insane. let's presume that the drivetrain loss % decreases as HP goes up (because it's not linear). if it were 10% instead of 15%, that's still 382bhp from 3.2 liters!
                              • 328ijunkie
                                • May 2007
                                • 3961
                                #135
                                I was simply showing the coorelation in exhausts and low end torque....
