M54 Madness, the remix
  • shanehutton
    • 26
    #61
    Will the connectors clear the runners? I forgot to go look before I left home this am.
    E30 Widebody 325is - M54b25 in progress (Track / AutoX)
    E39 Wagon 528i (with a clutch the way God intended)
    Toyota MR2 (Ice racer)
    • shanehutton
      • 26
      #62
      Originally posted by ForcedFirebird
      What?
      http://www.fiveomotorsport.com/catal...2172_c_600.jpg
      Zoom in and look at the nozzle. It shoots out on an angle instead of straight. It wouldnt really shoot up the runner but it wouldn't be aimed where intended unless you spin them so the connector side faces the runner instead of the head.
      • mike25
        • Jan 2014
        • 27
        #63
        Originally posted by hoveringuy
        ............my head should be getting dropped at machinist today (22.12.2014).
        Any update?
        • hoveringuy
          • Dec 2005
          • 2754
          #64
          Originally posted by mike25
          Any update?
          Cylinder head is at the machinist, exhaust valve guides were marginal so they're being replaced. The exhaust port are being tapped to have 4 exhaust studs per port. It's getting a good valve grind and a surface skim, I should have it back in a week.
          Then I'll need to install cams. Anyone want to sell me a set of Schrick cams?
          • 2mAn
            Señior Mod
            • 21083
            #65
            Are you doing that so you can run the Euro headers still?
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • hoveringuy
              • Dec 2005
              • 2754
              #66
              Its easy for the machinist to drill and tap for a few extra studs. I'm not committed to keeping the euro headers, but I'd like to keep the option open.
              • 2mAn
                Señior Mod
                • 21083
                #67
                Smart move.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • MGH
                  • Jul 2010
                  • 5
                  #68
                  hello. Another M54B30.
                  I am running a M54B30 on the bmw 413 ecu with hoveringuys vanos board.
                  I have made a lot of changes on the board like controling the cam
                  angle from the ecu. I started with a TRM chip but never got it running
                  right. The problem with the TRM chip is the way he rescale for the
                  bigger fuel injectors. After i figure out the rescaling it was just
                  like tunning a megasquirt (i have change the code in the 413 ecu so i
                  have datalogging). Now it runs so smooth, idle nice with a light
                  flywheel. pulls hard from 2000rpm lose breathe at 6200rpm.
                  I am very happy with it.
                  I'll just add that I run with 540 MAF and ebay headers
                  • hoveringuy
                    • Dec 2005
                    • 2754
                    #69
                    Update. Head is finally back from machinist and bolted back on. Machinist didn't do anything radical, but replaced the exhaust guides and completed a firs- rate valve cut. He also drilled the exhaust ports so I have 4 studs per port.
                    I have not yet installed cams because I'm going to hold-out for Schrick cams. Anyone have a set to sell me??
                    Next up is mailing the oil pan and subframe to Tyler for mod.
                    • hoveringuy
                      • Dec 2005
                      • 2754
                      #70
                      Tyler sent and update with this picture.
                      • mike25
                        • Jan 2014
                        • 27
                        #71
                        Steve
                        Presumably this is tyour e39 sump carved open?
                        Are you having the e39 sump re-worked?
                        Would it be easier to get an e36 sump altered (M50B25), as the oil pick up is then at the rear avoiding the cross support? - and presumably would be a straight forward fit into your e30?
                        Mike
                        • hoveringuy
                          • Dec 2005
                          • 2754
                          #72
                          Steve
                          Mike
                          You may be correct, but I haven't compared the e36 pan with the e39 pan. I can say that the oil pump and pickup tube is unique to the M54. The e36 pickup wouldn't work with an M54 pump.
                          Tyler has my oil pump and pickup tube and will need to extend the pickup slightly to clear the subframe.
                          I'll have more detailed pics in a few weeks to show his modifications.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #73
                            Steve
                            Mike
                            There are a lot of advantages to having a rear sump, specially in a swapped e30.
                            john@m20guru.com
                            Links:
                            • mike25
                              • Jan 2014
                              • 27
                              #74
                              Do you have any photos to show why?
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #75
                                I
                                Photos? No, but I work on e30's every day for a living and have replaced/welded stupid amounts of oil pans.
                                They last longer if they aren't the first thing besides a lip to hit something.
                                john@m20guru.com
                                Links:
