N52 Swap
    • 34844
    #106
    Originally posted by hoveringuy
    Just in the cylinder head:
    -machined ports
    -one piece head casting (stiffer, no separate front cover)
    -super-simple and elegant VANOS. No more splines and cups. Huge range.
    -hollow cam
    -cam carrier
    -variable lift
    I'm probably missing a few things...
    tapered rods, composite magnesium block, crank girder, electric waterpump..
    the VANOS is pretty much indestructible BTW. At worst you might have to clean the solenoids once in a while or replace the screens if your engine is full of sludge.
    • ForcedFirebird
      • Feb 2007
      • 8300
      #107
      Unlike the e36 engines lol
      john@m20guru.com
      Links:
      • Victell
        • 1083
        #108
        The VANOS might be durable and able to withstand slacked oil maintenance but from Dan's video it looks like the VANOS piston rings are prone to digging into the groove on the intake side and ruining the head if there's poor maintenance.
        This doesn't matter to me though as I wouldn't have maintenance issues.
        I think the N52 is the bees knees, I just dont see whats so radical about it. The only BMW engine I'd rather have in my 318is other than the N52 would be the N20.
        • AWDBOB
          hooptie connoisseur
          • Aug 2013
          • 4488
          #109
          240whp with headers, intake and tune!
          • wazzu70
            • Jan 2005
            • 1143
            #110
            The bedplate design for the crank case is a huge advantage for an I6 engine. Im surprised it took BMW so long to implement. Without the nose of the crank dancing around at higher rpm there is much less chance destroying the oil pump (let alone main and rod bearings).
            -Nick
            M42 on VEMS
            • DesertBMW
              • Aug 2011
              • 1038
              #111
              At the wheel, so about solid 260 hp with basic bolt ons, but it is not the HP that is impressive, it is the flat torque that starts way early
              • 2mAn
                SeƱior Mod
                • 20877
                #112
                Thats an impressive 8% drivetrain loss....
                Ive been tempted to get a 128i lately because I really dont want to do swap the motor
                Im guessing the 128i would need the intake manifold right?... I almost bought one a few years back but it was the SULEV which I think is different enough to be labelled a N53 or something
                EDIT: Correction, its a N51
                Simon
                Current Cars:
                -1966 Lotus Elan
                -1986 German Car
                -2006 Volkswagen Jetta TDI
                Make R3V Great Again -2020
                  • 34844
                  #113
                  lol. Stock N52B30OL is 255bhp, 265bhp in 3.0si form..
                    • 34844
                    #114
                    I offer a free tune for 128i to 130i (3 stage) swaps.
                    • 2mAn
                      SeƱior Mod
                      • 20877
                      #115
                      This is the difference between a 128i and the others that are 3.0si? or is there more to it
                      Is it hard to find the 3 stage manifold?...
                      this is the kind of stuff that I do when I WANT a distraction... Im supposed to be studying
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • Caperix
                        • Feb 2018
                        • 194
                        #116
                        I would not say indestructible, the early engines used tamper proof aluminum bolts to hold the gear to the adjuster that break off. There was a recall to replace the bolts with standard torx bolts. The crank is not keyed so the crank can spin out of time from the cams. The early cam seals had a fragile clip that could break and damage the head/exhaust cam carrier. The n52 is not a bad engine it just has its own unique issues. I'm not a fan of the electric water pump, but I think the only solution to that is a s55 block.
                          • 34844
                          #117
                          The engines are identical. Its just a different tune.
                          No, they arent hard to find. I paid $150 with DISAs.
                          • 2mAn
                            SeƱior Mod
                            • 20877
                            #118
                            From what I've read the N51 has lower compression and comes with the DISA already... seems like an oddball
                            Simon
                            Current Cars:
                            -1966 Lotus Elan
                            -1986 German Car
                              • 34844
                              #119
                              The N51 only came in SULEV 328's. But its good for harvesting the 3-stage from. :p
                              • digger
                                • Nov 2005
                                • 6167
                                #120
                                the bed plate wont stop the crank torsionally flexing but the new oil pump drive system will dampen out the vibrations so the pump doesn't see as much of the vibrations
