M42 turbo fact thread
  • Dj Buttchug
    • Jun 2010
    • 7654
    #136
    fuuuuuuuu I need to finish my intake so I can up the boost!!!
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • e30guydownunder
      • Jul 2008
      • 874
      #137
      More Info:
      Better pics and such when I have time, busy preparing it for the Mattara Hillclimb this October long weekend. I am running in the club day event on the Monday because all my mates are but anyway.
      So Basic Specs:
      BMW M42 (1.8L 4 Cylinder)
      CP Pistons
      ARP Rod Bolts, Main Studs, Oversize Headstuds
      O-ringed Head and Block, Copper Headgasket
      Cat Cams, VAC Motorsport Springs and Retainers
      Custom Rear Sump
      Garret GT3076R, 0.63 Rear Housing, Tial MVR 44 on custom Manifold
      DTA S60 still running the show
      Fuel Cell, 2 x 044's, 1600 Bosch Injectors and a bunch of other supporting mods.
      I have changed to a Getrag G260 (325i trans) overdrive transmission and a 3.46 rear end, this is good for a touch over 200 in 4th and should mean I don't have to change to 5th at Wakefield.
      There has been a whole pile of background developments but they are for later. Right now I am going to drive the wheels off this thing and put the development program on hold, I am well sick of wrenching.
      - Chris
      Project M42 - 255 @ 19 psi
      • MF DOOM
        • Apr 2012
        • 944
        #138
        high five dude
        EDIT: Your thread name is hilarious!
        • e30guydownunder
          • Jul 2008
          • 874
          #139
          Yeah I figured it might get some reactions that way :p New video in my thread
          - Chris
          • Dj Buttchug
            • Jun 2010
            • 7654
            #140
            ^extremely well done man, and very impressive
            Ig:ryno_pzk
            • ccsdo5
              • Mar 2013
              • 707
              #141
              Howdy so I figured this thread gets more traffic than my silly project thread. I just got through pulling my motor and what not so now is the time to decide what I want to do with it. My goals are 250-300whp, but I would like to know I could maybe go a little more in the future so I wanna just build my motor up now while it's already out. Here is what I was thinking:
              -85mm overbore
              -Arrow precision forged H-Beam connecting rods
              -CP 8:5:1 forged pistons
              -MLS head gasket (.70)
              -ARP Head stud kit
              -One piece forged stainless steel valves (7mm)
              -Steel alloy retainers
              -Dual interference springs
              -Spring seats
              -Polished and balanced OEM crank
              -Ported and polished head
              My biggest concerns are should I use the same camshafts? Or is it totally worth it to get the VAC camshafts for turbocharged motors.. Also what should I be looking at for main bearings and rod bearings. Does anyone know if there are acl racing bearings for the m42 or a good set I could get.
              Here are the links to everything I was looking at from VAC:
              The M42 turbo kit which includes
              -Pistons
              -H-Beam connecting rods
              -MLS gasket
              -ARP head stud kit
              The valve kit I'm looking at.
              The valve spring and retainer kit which has
              -springs
              -valve retainers
              -spring seats
              Duration (Degrees): 269 / 269 "Sport" Grind; 280 / 274 "Hot" Grind; 260 / 242 "Turbo" Grind; Custom Grind (please call or Email).
              -M42 performance turbo camshaft set
              Thanks for your help in advance!!
              -Dee
              5-lugged turbo 318is Barn car
              IG: @deebelmont
              • MF DOOM
                • Apr 2012
                • 944
                #142
                You pretty much just described my engine. Cams would be worth it. I see a noticeable drop off after 6k and its almost not worth revving passed 6.5k. Talk to them about how much boost you plan to run. When I talked to them last they were getting a quote for me for some custom cams, they never got back to me btw, but depending on boost level and how high you want to rev they can set you up with more desirable cam specs than what is listed.
                • Dj Buttchug
                  • Jun 2010
                  • 7654
                  #143
                  fwiw ccsdo5, you dont really need to fork out extra money for rods. Stock m42 rods are insanely strong.
                  Ig:ryno_pzk
                  • MF DOOM
                    • Apr 2012
                    • 944
                    #144
                    And I have some low mileage ones i'll sell you :)
                    • wazzu70
                      • Jan 2005
                      • 1143
                      #145
                      The VAC cams will definitely spool faster and add more power than the wimpy OEM cams. Our factory cams are pretty weak sauce!
                      -Nick
                      M42 on VEMS
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        #146
                        Man, I've been perfectly happy driving my turbo M42 the way it is, and now you all have me wanting to start fiddling with it again and try to get more power...
                        Project M42 Turbo
                        • pantelones
                          • May 2011
                          • 533
                          #147
                          ^^^ There is soooo much more that goes into a turbo cam than that!
                          Custom cams, custom cams, custom cams...
                          Back-pressure, RPM range, boost level, target horsepower, A/R of turbo, turbo frame (T3, T4, T6/Thumper), head flow, cubic inches, and even location of turbo...etc. All of these factors are extremely important in determining the cam that best suits your needs. There is no rule of thumb with a turbo cam. There are too many variables and the only way to get the right cam is to take all of those your parameters into consideration, and only then can a proper cam be selected.
                          http://www.forcedinductions.com/help.htm
                          In truth, Godbold says 99 percent of Comp Cams' turbo grinds should be custom profiles because "pressure differential can be all over the place. The reason we don't have a lot of catalog turbo cams is because there are not a lot of catalog turbo systems." Every turbo installation is unique.
                          http://www.hotrod.com/pitstop/hrdp_1...s/viewall.html
                          And for shits and giggles, put your calculus skills to work?
                          A man chooses, a slave obeys... Would you kindly?
                          • bmwm42
                            • 6300
                            #148
                            What about attitude atmospheric pressure outside air temp density of fuel all this shit impacts your turbo build and should be considered when deciding your cam grind for your build
                            Originally posted by bmwm42
                            PNW vulture pm me for parts
                            Strategic nw e30 command
                            • ///digitalme
                              • Dec 2009
                              • 2088
                              #149
                              Hi guys I'm new to this turbo thing. I'm getting to the point where I want my car to be. My engine is healthy. Full timing overhaul im thinking of getting it turbocharged. What's a realistic number of cost. My goal is atleast 160-190hp. Sorry about my noob questions lol also trying to keep cost low using stock internals.
                              • wazzu70
                                • Jan 2005
                                • 1143
                                #150
                                See how cam design is different for turbocharged engines compaired to natural aspirated build. Only at www.hotrod.com, the official website for Hot Rod Magazine.
                                http://www.tildentechnologies.com/Cams/index.html
                                This is true of atmo cams. If you want it to be perfect it needs to be custom ground for your specific application. Even then, you can buy sport, rally, ect cams.
                                The VAC turbo grinds are a great all around grind that will work with most setups. Like all turbo cams you need a free flowing exhaust to really make them shine (no log mani, no rediculiously small turbine housing). The grinds aren't 100% perfect for all applications but its still leauges ahead of using stock garbage :)
                                -Nick
                                M42 on VEMS
