M42 turbo fact thread
  • Dj Buttchug
    • Jun 2010
    • 7685
    #121
    im running no catch can routing my crankcase vent directly to my turbo intake.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Leon T. Trout
      • Oct 2009
      • 130
      #122
      That's what I was thinking about doing in the mean time. I know when I pull off the breather hose hose there is a fair amount of oil in the hose. I assume that there is no problem for this small amount of oil to go through the turbo?
      • Dj Buttchug
        • Jun 2010
        • 7685
        #123
        Even tho you have some residual in the hose its probably not enough to even make it all the way through the hose into the turbo. But then again you could do a catch can setup inline to stop that.
        If It were me I wouldnt want oil going into my turbo but my case is different than most. my engine is brand new and my crankcase vent is bone dry and as clean as it was the day i started the engine.
        Ig:ryno_pzk
        • Northern
          I like cupcakes & sh!tboxes
          • 5275
          #124
          Mahle provent.
          Originally posted by priapism
          Originally posted by shameson
          • MF DOOM
            • Apr 2012
            • 944
            #125
            Heres one. Vacuum lines. How are you guys routing yours? Last time I drove the car it sounded like I had some compressor surge and noticed some excessive shaft play on the old turbo. I dont know if its my bov thats bad or if its my vacuum routing. I plan on testing the bov next time I have some spare time to work on the car and ill grab some flicks of my vacuum lines
            • e30guydownunder
              • Jul 2008
              • 874
              #126
              I have all mine ported directly into the base of the manifold, separately. But 666Fab manifold was very easy to drill and tap :D
              I'm booked into dyno Saturday, stay tuned for complete pics and vids!
              Here is a teaser
              - Chris
              Project M42 - 255 @ 19 psi
              • MF DOOM
                • Apr 2012
                • 944
                #127
                :D oh yes. post engine specs as well
                • Peattie
                  • Apr 2013
                  • 260
                  #128
                  ^^ thats nice!
                  • Dj Buttchug
                    • Jun 2010
                    • 7685
                    #129
                    the intake I want to know more about.
                    Ig:ryno_pzk
                    • e30guydownunder
                      • Jul 2008
                      • 874
                      #130
                      The intake is a 666fab unit (bought before he closed up shop). There are some details about it that are less than optimal (plenum shape, runner taper) but it is going to get me going for now. We are working on a new design which will include a Billet runner section into a fabbed plenum.
                      The car has started, just need to sort out a few leaks and the cam sensor timing is wrong, along with a host of other things for the start up tune, but it runs :)
                      Engine specs are still as my previous post.
                      - Chris
                      • wazzu70
                        • Jan 2005
                        • 1143
                        #131
                        Looks great Chris! Is your engine in the std E30 position? Looks further back than normal.
                        What paint did you use for the bay? Ive been considering white as well.
                        -Nick
                        M42 on VEMS
                        • e30guydownunder
                          • Jul 2008
                          • 874
                          #132
                          It Work
                          - Chris
                          • MF DOOM
                            • Apr 2012
                            • 944
                            #133
                            :up::up::up:
                            • e30guydownunder
                              • Jul 2008
                              • 874
                              #134
                              The engine has been moved back roughly 90mm and rotated 15 degrees clockwise. I am running a custom rear sump and (soon) front sway bar. 325i driveshaft fitted perfectly with this and the G260 Getrag.
                              It's just white 2 pac, no particular colour. I had in mind the car was going to be resprayed white. At this point a re-shell is looking more likely though.
                              For reference guys, 265kW @ 20psi, the engine is in no way struggling to achieve this, EGT's are very reasonable, no stupid amounts of ignition etc. Time to have some fun :)
                              - Chris
                              • MF DOOM
                                • Apr 2012
                                • 944
                                #135
                                thats 355hp for us americans. posting that so not everyone else has to google a conversion like i did :p
                                Great numbers man! Makes me motivated to finish my car before we get anymore snow here... or at least get some work done on it.
                                Did you end up going e85?
