M42 turbo fact thread
  • jntar
    • 459
    #181
    Originally posted by varg
    What's everyone here torquing their ARP head studs to?
    85ftlbs in 3 step intervals as arp recommends.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    • jntar
      • 459
      #182
      Contemplating a turbo upgrade in the very near future. I'm trying to decide between the gt2560r vs gt2860rs. Both spool pretty quick, the 2560 about 500 rpm quicker, but the 2860 has a better flow at the top end. I wont be running more than 12psi and still on stock motor (haven't even started on the new engine build).
      Thoughts on these two?
      M42 turbo build.
      • econti
        • May 2014
        • 1147
        #183
        Originally posted by jntar
        Contemplating a turbo upgrade in the very near future. I'm trying to decide between the gt2560r vs gt2560rs. Both spool pretty quick, the 2560 about 500 rpm quicker, but the 2860 has a better flow at the top end. I wont be running more than 12psi and still on stock motor (haven't even started on the new engine build).
        I suppose it depends what you want it for.
        I'm trying to decide between GT2554 and GT2560.
        My thinking is that I'm trying to supplement the powerband, not create it. So the 2560 seems like it should supplement the M42 powerband pretty well, and shouldn't run out of puff too much at the top end.
        For me at least, the 2860 would be a little big I think.
        Good part about those turbos is that flange size is the same for all T2s. So it's pretty easy to change between them.
        What sort of power are you after?
        • jntar
          • 459
          #184
          I found an s15 240sx t28 locally I'm thinking about. It's pretty close to the 2560 spec. I'm fine with 200whp, but my current td04h-15g greddy turbo has a large drop on top end above 5k rpm. I'm looking to get something that spools similar, but pulls to redline.
          M42 turbo build.
          • ccsdo5
            • Mar 2013
            • 708
            #185
            ^^ This is the same turbo I am trying to get from my friend. It's apparently pretty awesome on the sr20's. I know T25 with an hks wastegate (about 1 bar of boost) is somewhere around 200-250 I think for my friends 240sx. I think it'll be a good buy!
            How/ where are you guys running coolant lines to the turbo? I am doing the mess under the intake stuff as well so can I get it from coolant pipe (the teal colored line in the picture below) and then return it to the cylinder head (also the teal line pictured below).
            -Dee
            5-lugged turbo 318is Barn car
            IG: @deebelmont
            • elcoy
              • Jan 2011
              • 569
              #186
              So I decided against the S52 swap, and am going to keep the M42 and go turbo! Looking to get some advice/predictions on my build. I have read several build threads and am meeting with a local engine builder hopefully this week, because if I am really going to do this the Engineer in me has to do it as close to correct the first time as I can. Thoughts on the following setup for reliability/hp?
              Compression goal: 8.5:1
              Forged Pistons
              Performance Valves and Springs
              Polished and Balanced Stock Crank and Rods
              Turbo Cam
              Ported and Polished Head
              ARP Hardware
              MLS Gasket
              Turbonetics Ball Bearing T3/T4 5 Bolt Turbine .63 a/r (High teens psi?)
              SDS Stand Alone (Already Purchased)
              Stay tuned for a build thread!
              The Lineup in order of appearance:
              91 535i
              91 318is 5 Lug/E46M3 Brakes
              91 325is w/ S52
              88 Vert Plastic Bumper Swap
              88 M3 ;D
              91 325ix 5 speed
              89 Vert Royalblau Metallic
              73 2002
              1986 325es --> is swap Rallycross Car!!
              1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
              1993 525i Granitsilber Metallic Touring
              Need a 91 M5 bad but wife would shoot me...twice
              *UPDATE: got a 93 M5 and still alive
              1972 Jeep Wagoneer
              1975 2002 five speed
              Check out:
              Elhartspeedshop.com
              • MF DOOM
                • Apr 2012
                • 944
                #187
                Forged Pistons
                Turbo Cam
                ARP Hardware
                MLS Gasket
                Sounds like a promising build. You should give MM a call about a head. Might as well go with one of theirs and rev to 7700.
                • wazzu70
                  • Jan 2005
                  • 1143
                  #188
                  Whats your power goal? 9:1 compression would probably be better IMO.
                  Why such an ancient turbo choice? Are you getting it used for cheap??
                  -Nick
                  M42 on VEMS
                  • RedReplicant
                    • Oct 2009
                    • 270
                    #189
                    Is anyone still making a Megasquirt PNP unit for the M42?
                    91 318is - Gone
                    16 VW GTI
                    07 Aprilia Tuono
                    • jntar
                      • 459
                      #190
                      Yes And no. There is a company that sells an unauthorized version. I own one. However, they are not good. Mine is near impossible to tune and I wish I had built my own.
                      M42 turbo build.
                      • elcoy
                        • Jan 2011
                        • 569
                        #191
                        Ideally I am shooting for 300+
                        I guess I didn't know that was an ancient turbo, what would be a better choice?
                        91 535i
                        91 325is w/ S52
                        88 M3 ;D
                        91 325ix 5 speed
                        73 2002
                        1972 Jeep Wagoneer
                        Check out:
                        Elhartspeedshop.com
                        • RedReplicant
                          • Oct 2009
                          • 270
                          #192
                          That's too bad. I guess the best option is to buy a used harness and make my own MS harness from it.
                          91 318is - Gone
                          16 VW GTI
                          07 Aprilia Tuono
                          • Dj Buttchug
                            • Jun 2010
                            • 7678
                            #193
                            Theres really no need to modify or make your own harness. You use the OEM 88 pin harness when you build a PNP unit.
                            Turbo M42 Build Thread :Here
                            Ig:ryno_pzk
                            I like the tuna here.
                            Originally posted by lambo
                            • RedReplicant
                              • Oct 2009
                              • 270
                              #194
                              Are you cutting apart a stock ECU (they are expensive, relative, used) for the connector and making a breakout board? How are the coils driven?
                              91 318is - Gone
                              16 VW GTI
                              07 Aprilia Tuono
                              • gwb72tii
                                • Nov 2005
                                • 3864
                                #195
                                I just picked up a 1991 318i and I'm going to mod the motor somehow.
                                So the choice i think for me is a typical M50/M52 twincam, or turbo the M42
                                So you that drive you M42 turbo all the time, how is it? other than more horsepower, how's living with it everyday? This will become a daily driver for me.
                                “There is nothing government can give you that it hasn’t taken from you in the first place”
                                Sir Winston Churchill
