M42 turbo fact thread
  • MVincken
    • Sep 2015
    • 75
    #226
    how is the position between the wheel and the sensor?
    I don´t know if you changed it, but if it´s too far away it won´t send a signal
    • JRW21
      • Aug 2009
      • 190
      #227
      Position is the same. That's one thing I left alone.
      • JRW21
        • Aug 2009
        • 190
        #228
        Got it sorted out and RPM synced now. Does anyone have a solid base tune they wouldn't mind sharing?
        • JRW21
          • Aug 2009
          • 190
          #229
          1st start since complete engine rebuild...ms3pro!
          • elcoy
            • Jan 2011
            • 569
            #230
            http://vidmg.photobucket.com/albums/...psgqkwdxlf.mp4
            More vids!!
            Congrats, looks and sounds pretty f-in sweet.
            The Lineup in order of appearance:
            91 535i
            91 318is 5 Lug/E46M3 Brakes
            91 325is w/ S52
            88 Vert Plastic Bumper Swap
            88 M3 ;D
            91 325ix 5 speed
            89 Vert Royalblau Metallic
            73 2002
            1986 325es --> is swap Rallycross Car!!
            1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
            1993 525i Granitsilber Metallic Touring
            Need a 91 M5 bad but wife would shoot me...twice
            *UPDATE: got a 93 M5 and still alive
            1972 Jeep Wagoneer
            1975 2002 five speed
            Check out:
            Elhartspeedshop.com
            • jakeb
              • 1909
              #231
              nice man!!
              www.classicdaily.net
              1970 m42 swapped 2002
              1985 LS1/T56 Swapped e28 (557e)
              www.blunttech.com - For all your parts needs
              Follow me on Instagram for constant build updates @classicdaily
              https://www.facebook.com/ClassicDailyLLC
              • chodedub
                • May 2013
                • 56
                #232
                Wondering about FPR and what brand of injectors are recommended
                • BURKARD
                  • Mar 2017
                  • 2
                  #233
                  Hello guys, i been some time reading this forum, i dont have an E30 but i wanted to share my project.
                  Its an E21 with an M42 turbo on it
                  91 M42 B18
                  Stock Internals
                  Stock Gasket
                  Dbilas Dynamic Intake
                  Siemens/Deka 60LB injectors
                  AEM External fuel pressure regulator
                  VDO fuel pressure Gauge
                  Coil on Plug Conversion
                  Bavarian autosport coils
                  Spark plugs NGK Iridium IX BKR9EIX
                  Custom Exhaust manifold
                  Full 2,5" stainless steel Exhaust
                  T3/T4 .63 AR Turbine.
                  Tial MV-R 44mm Wastegate
                  Tial Q BOV 50mm
                  N75 boost control
                  Fueltech standalone ECU
                  Power 244HP at the Crankshaft
                  220 WHP
                  Boost 6,4 PSI
                  • 95tisofly
                    • Mar 2017
                    • 1
                    #234
                    Where would I get my ecu tuned for my turbo build? I'm from east stroudsburg pennsylvania. No one has been able to answer this question for me. I drive a 95 bmw 318ti
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      #235
                      Burkard, that is a beautiful setup. Don't see too many low mount turbo setups. With ITBs too...did you boost before ITBs and then add them later? Mostly curious how it affected throttle response and if it highlighted any shortcomings in the stock manifold setup.
                      95tisofly - unless there is a member on here close to you, you will more than likely just have to call around your local tuner/dyno shops to figure out how can help you.
                      Project M42 Turbo
                      • econti
                        • May 2014
                        • 1152
                        #236
                        I'm honestly impressed it doesn't blow all the boost out past the ITBs
                        • captain awesome
                          • Dec 2016
                          • 334
                          #237
                          So I bought this partial Mosselman kit and I'm getting some of the details figured out before I drop the motor back in. Unfortunately a ton of pics are going in the toilet due to photobucket and I'm figuring out where my oil drain should go. I see there's a fairly large bolt at the back of the block, can it be used? Also with this being a lowmount setup, how does it drain properly if it's on a lower plane than the drain does that require a scavenge pump or will a simple check valve be sufficient?
                          Untitled by hatchethairy, on Flickr
                          Look at this setzy thang.
                          • captain awesome
                            • Dec 2016
                            • 334
                            #238
                            Looks like I'm an idiot, as the bolt mentioned above is another drain plug for the coolant system. I'm either going to try to fit a bulkhead fitting to the higher point of the oil pan or have a fitting welded on. Still not sure if I'll need a scavenge pump or if a check valve would be sufficient from drain back into the turbo.
                            • varg
                              Florida Turbo Man
                              • May 2014
                              • 3439
                              #239
                              That depends entirely on how low the turbo hangs with that setup, it's tough to tell from a pic of just the manifold and turbo but it looks to me like it's very close to being too low to not be scavenged. If the turbo drain port is at or even slightly above the sump oil level, it's too low.
                              IG @turbovarg
                              '91 318is, M20 turbo
                              • BURKARD
                                • Mar 2017
                                • 2
                                #240
                                Thanks!, i did the swap with the Itb´s first, i never run the car with the stock manifold.
                                The itb´s run very well, but i was always fiddling with the idea of supercharge it.
                                The superchargers are not very common here, but there´s a lot of people, with a lot of knowledge with turbochargers, so i decided to run a low boost setup.
                                It is a very fast car, and can outrun a lot of big fishes.
