Pistons for m20 Stroker
  • zaq123
    • Jul 2016
    • 1466
    #61
    Originally posted by apostate
    Turbo charged or not, doesn't matter. What matters is the revs.
    It is the revs that put an enormous load on rods, pistons and pins. Not the boost. Period.
    i suggest to go and read some more..
    • apostate
      • Feb 2012
      • 148
      #62
      That's my point too.
      Internet is a great place to learn from but there are people there who know a thing or two about alloys. And about metallurgy science.
      Otherwise, it is great to learn from the internet. :)
      • apostate
        • Feb 2012
        • 148
        #63
        Suggestion redirected back to you. :D
        • zaq123
          • Jul 2016
          • 1466
          #64
          Originally posted by digger
          Andrew, it is a 2618 piston if its JE and it's turbo charged imo I base this on the forging they used
          Je diagnosed it as inorrect install saying the locks came out of groove and pin moved out of position. It doesn't look like good fi pin imo looks very thin wall so the pin flex works the piston bosses.
          Regardless of the alloy on any part the geometry has to be appropriate
          improper circlip install was my first thought as well. Unfortunally pictures in that post were not good enough to focus on areas of interest for telltail signs of circlip failure: opposite/undamaged side piston balcony area, rounding of the edges on the broken side, circlip marks on the side of the wrist pin or the lack of, etc.
          • zaq123
            • Jul 2016
            • 1466
            #65
            I'm not the one with PERIOD after each statement. But yes, I'm still learning
            • apostate
              • Feb 2012
              • 148
              #66
              Each statement? No.
              Only after the RPMs statement and I stick to it. :)
              • digger
                • Nov 2005
                • 6072
                #67
                ned this before (30K miles)? I guess you sold quite a lot of pistons of this alloy while working for IE?
                To play the devils advocate if 2618 wasn't strong enough maybe none of us should contemplate building engines anymore....
                There is a thread on here where guy tightened an Arp head stud and it broke must be the wrong material for the job
                • apostate
                  • Feb 2012
                  • 148
                  #68
                  I guess someone with 2618 has to make an input. Cause you guys are only 4032 gathered here. :)
                  • apostate
                    • Feb 2012
                    • 148
                    #69
                    Digger, make up your mind once you write on. It's hard to follow all of your edits.
                    Cheers.
                    • zaq123
                      • Jul 2016
                      • 1466
                      #70
                      no one here is trying to convince you of anything, 4032, 2618, 4018, 2632, shitcake....whatever floats your boat.
                      • digger
                        • Nov 2005
                        • 6072
                        #71
                        One only needs to use their powers of observation for what works and what doesn't.
                        • SkiFree
                          • Jun 2011
                          • 2766
                          #72
                          @SkiFree - while you are being generous about the 2618 alloy, how come you never mentioned this before (30K miles)? I guess you sold quite a lot of pistons of this alloy while working for IE?
                          Fair enough question. I went over pros/cons with whomever asked for my input.
                          Best of luck finding what is right for you.
                          ADAMS Autosport
                          • apostate
                            • Feb 2012
                            • 148
                            #73
                            Fair enough answer. It is just disappointing that you didn't share your "thoughts" earlier on this forum or somewhere else.
                            Because 30K miles limit is important and it is quite a while that you are not working for IE as I understand.
                            Active user like you on this forum should have shared his observations to the wide public a bit sooner, don't you think?
                            Don't get me wrong, but helping a community doesn't contribute much with yours or Digger's earliest posts.
                            Or may be all of us around here are not at your high level, so we all have to take your posts for granted without explanation whatsoever...
                            Cheers.
                            • digger
                              • Nov 2005
                              • 6072
                              #74
                              I'm sure I've seen him mention Itva couple years ago atleast, iirc in a thread about the new IE mahle ms Pistons one of the driving reasons behind it. It may have been in his build thread
                              • apostate
                                • Feb 2012
                                • 148
                                #75
                                Sure.
                                I don't mind a bit, it was just for the folks that are "learning" from you, clever guys. :):)
