Ultimate N/A M20 racing engine?
  • hasa
    • May 2013
    • 307
    I'm riding on the old topic: What would be the best bottom end for racing?
    I'm considering purchasing either IE 3.1 stroker kit with 12.5 compression pistons or building my self a custom 2.9 kit around a M50/52 84mm crank ( which fits to block without complications and is happier to rev properly )
    • digger
      • Nov 2005
      • 6196
      the best wont come in "kit" form from the well known places. are you talking about a proper race only engine that never sees the street? or a street car you take to track on occasion?
      • hasa
        • May 2013
        • 307
        Just pure racing. I know the absolute best comes only by deep knowledge and extensive development. But I would be happy to solve the basic choise between 3.1 and 2.9. 3.1 brings more torque, but does it bring problems due bad rod ratio or torsional vibrations etc. ? In my case the engine could operate in quite narrow powerband as I use race geared dogbox. So I think the mid-range torque is not so much important. Sent from my iPhone using Tapatalk
        • digger
          • Nov 2005
          • 6196
          Most forms of racing you see teams use biggest bore and shorter stroke length to achieve a given displacement. so a sub 3L will be better choice as you are limited in terms of power by the head. Please don’t use generic pistons from the “usual places” there’s a bit more to it than just finding something that has the right compression height and compression ratio.
          • TobyB
            • 5290
            This is one of those things:
            unless you HAVE to keep the 12v head for rules reasons,
            why beat yourself up doing so?
            Breaking the 300 hp level's not so hard that way.
            t
            why push it by hand if you can use wheels?
            edit: would not race an E30 engine that came from that
            workshop in Duarte without doing a thorough measurement
            of it by myself beforehand. Because Furry Camel.
            • hasa
              • May 2013
              • 307
              If generic pistons from ”usual places” are no-go, what an average tuner can do? Nothing... I understand clearly your point digger, but I don’t have your contacts, engine design skills and cad-skills. I like the simple design of the M20, but also understand that staying away from S54 is not clever. Sent from my iPhone using Tapatalk
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4501
                He’s saying don’t buy off the shelf pistons that aren’t matched perfectly to your setup. “The ultimate racing engine” doesn’t come from off the shelf parts.
                There is one set of really good off the shelf pistons that will get you close to where you want to be. Those are the 2.9L Mahle ultimate street pistons from IE, perfectly designed to work with an 885 head and m52 crank and rods.
                An average joe can get custom pistons spec’d by a company like Top End Performance. They just made me custom 86mm pistons to work with a 731 head an S52 crank/rods, to whatever compression you desire. The same price as the off the shelf stuff and perfectly made to match your setup, had them here in a few weeks.
                I would spend money on head work/ITBs and just use the ultimate street 2.9L IE pistons I mentioned above.
                • digger
                  • Nov 2005
                  • 6196
                  yeah i mean dont just get off the shelf pistons that dont suit the combustion chamber. the Mahle MS 2.9L suit the 885 head but they are 10:1 CR a fair bit lower than you stated that you want
                  Alternatively if you take the dome of a 9.7:1 OE B25 pistons and translate it to 86mm with 84mm stroke and proper squish the CR works out roughly 11.5:1 (11.3 with 85mm bore if you prefer OE gasket) depending on valve reliefs which depend on the cam. top end can do this, if you want a much higher CR they have a dome that retains the squish but much less dish which is what was used in the 14:1 CR 2.8L race engine on webers AFAIK.
                  • hasa
                    • May 2013
                    • 307
                    Thanks for the responses! For some reason I have forgot the "Racetep" as a source. So this is what you are talking about:
                    https://www.racetep.com/automaker/bm...-oemcrown.html
                    I've never thought that the combustion chamber at piston side would have a big effect to power (unless a huge dome prevents the proper ignition flame traversal).
                    Okay.. now I think I'd have a concept:
                    Racetep 86mm pistons
                    Early 84mm forged crank "C38"
                    = +2.9 litres of displacement
                    Ported head
                    RHD valvetrain
                    42mm ITB setup
                    suitable headers
                    end results depends much on the headwork
                    • digger
                      • Nov 2005
                      • 6196
                      The dome is a certain shape to create squish which means the piston squeezes the air fuel mixture against the head. This creates additional mixture motion resulting in a faster burn and better knock resistance. At lower rpm this is absolutely critical for reducing knock as the port speed is slow you need all the mixture motion you can.
                      A lot of custom pistons or off the shelf ones don’t achieve this. The m20 885 head is different to many other heads in that a flat top creates no squish it needs a specific dome like those racetep pistons which is a copy of the OE.
                      you want the 9.7:1 style dome not the 8.8 style which still won’t get you to 12:1 unless you deck the head but will be still pretty high
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        I concur about the piston shape. Doesn't matter what MFGR you go with, the m20 highly benefits from the angular squish band. At TDC the design forces the combustion to the center of the dish in the piston, away from detonation prone area. There are several companies that have pistons mimicking the stock shape - just stay away from the generic flat top type pistons (or with a pent shape dome on top).
                        john@m20guru.com
                        Links:
                        • zaq123
                          • Jul 2016
                          • 1560
                          What are the realistic limits of an M20 ?
                          to sum this all good advice in this thread and to answer your question,,,,the realistic limits of an M20 are in a direct proportion to the realistic limit of your wallet.
                          To do this correctly, look for a shop with a "proper" flow bench and the engine dyno.
                          Bench needs to be able to see the velocity, swirl etc....not just the flow. Engine dyno is needed to match the head to your engine: best performer head on the bench doesn't mean that it would be such when bolted to your engine.
                          cha-ching
                          not affiliated but here is an example of a properly equipped shop you are looking for
                          • Rtalatief
                            • Jun 2017
                            • 7
                            350+ bhp is attainable IF you can get the head to flow at least 240 CFM. And 8500 rpms of course :)
                            • digger
                              • Nov 2005
                              • 6196
                              around 210CFM at max valve lift (probably atleast around 13mm) is actually enough if everything else is correct. A 2.7 or 2.8L might need need 8000-8500 rpm but a bigger stroke engine like >3L 7000-7500 is enough.
                              • Rtalatief
                                • Jun 2017
                                • 7
                                Yep, its always about the bhp/L number and VE , 120 bhp/L from a 2.9 L m20 with 84mm stroke needs 8500-9000 rpm, high duration cams, lightweight rods, custom lightweight pistons and pins. Of course 11.5 CR. A 3.1 L engine only needs 110bhp/L to achieve the same hp numbers.
