Ultimate N/A M20 racing engine?
  • hasa
    • May 2013
    • 306
    What are the realistic limits of an M20 ?
    If you put 84mm crank, 12.5 cr pistons, H-beams, Rama roller cam kit, ITB's and proper headers... what can you expect about DIN-power from crank ? Anything like Euro S50B32 ? S54 level might be out of range ?
  • digger
    • Nov 2005
    • 6160
    yes, you can make S50B32/S54B32 power....the most important part is the cylinder head modifications
    • hasa
      • May 2013
      • 306
      So that it means bigger valves and some experienced wizardry on porting?
      I have a gut feeling that bone stock 885 could support max 300hp. They seem to give "theoretically 280hp amount of flow" on superflow scale which translates to about 10% more in real life in racing applications.
      • Kershaw
        • 11822
        I don't think I've ever seen a bone stock 885 head do that.
        AWD > RWD
        • FRODADDY
          • Feb 2012
          • 144
          who would be the company to go to for a top notch head?
          1990 kashmir beige BMW e30 327i
          1993
          muggello rot BMW e36 M3 Gruppe A Euro
          1990 GP weiss Porsche 964 C2
          1997 schwarz II BMW e36 328iS supercharged
          • ForcedFirebird
            • Feb 2007
            • 8300
            Just brows Rama's site, his m20 made something like 275whp. Knight did one with triple carbs that was around 300. I recently did a head for a 2.5 (not stroked) m20b25 with 288 Schrick cam, 12.5:1 and headers, made 208whp with the stock single throttle and manifold. I've also done a few ITB engines that are making well into the 200's non-roller cams.
            Go with someone who has a flow bench at least.
            john@m20guru.com
            Links:
            • FRODADDY
              • Feb 2012
              • 144
              What about the bimmerheads?
              1993
              • digger
                • Nov 2005
                • 6160
                no around 260 bone stock, its not very good.
                i personally wouldnt go with anyone who offers generic ported heads, or stage 1,2, 1001 type heads if you want s54 power. you really need a custom job and they will ask alot of quesions so they can tailor the work accordingly to suit the kind of engine you want, in truth its going to costs a bomb and yes they will use a flow bench to develop the port shapes, make sure the air speeds are acceptable and give you a flow sheet at the end so you know atleast know there is potential for the engine to make more power than with the stock head. If the porter is really good you'll probably have to wait several months for the work as they'll be in high demand
                even my MM rally ported head has all this grinding and smoothing done but it doesnt move any more air than a stock port at high lift so there are ported cylinder heads and well ported cylinder heads
                • 2mAn
                  Señior Mod
                  • 20864
                  Originally posted by ForcedFirebird
                  Just browse Rama's site, his m20 made something like 275whp. Knight did one with triple carbs that was around 300. I recently did a head for a 2.5 (not stroked) m20b25 with 288 Schrick cam, 12.5:1 and headers, made 208whp with the stock single throttle and manifold. I've also done a few ITB engines that are making well into the 200's non-roller cams.
                  x2 ... all of this....
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  -2006 Volkswagen Jetta TDI
                  Make R3V Great Again -2020
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5248
                    If I wanted big power from an m20, I would take it somewhere that has proven they can do it. As far as I know, Knight Engines in Aus are the only ones working M20 heads to that level, but you're sure as shit going to pay a premium for the service.
                    Originally posted by priapism
                    Originally posted by shameson
                    • dvallis
                      • Oct 2015
                      • 1474
                      Call Korman BMW. They know a lot about it. Were very helpful for me during Das Beast build.
                      BMW Performance & Tuning Since 1978   RESTORATION   The types of restoration we perform include daily drivers, hot street cars, vintage...
                      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
                      1987 E30 3L Turbo Stroker Das Beast
                      2002 E39 M5
                      • decay
                        • 5637
                        Originally posted by Andre3127
                        Bimmerheads.
                        i'm sorry, but no. for a top-notch head, the answer is Rebello.
                        past:
                        1989 325is (learner shitbox)
                        1986 325e (turbo dorito)
                        1991 318ic (5-lug ITB)
                        1985 323i baur
                        current:
                        • Dgerry
                          • Oct 2016
                          • 54
                          • 325e '87
                            • May 2017
                            • 503
                            I don’t think I’ve ever seen anyone comment on this Korman autoworks in the forum? They’re pretty close to me, just curious if they have a solid rep or not?
                            My son has the 1987 325e, 2 door, 5speed
                            I daily the 1989 325i, 4 door, 5speed
                              • 34841
                              They've been around for ages, no idea of their work these days. We used to have a member here who was the grandson of the owner, but I can't remember his name anymore (haven't seen him here for years).
