Putting a m42 head on m44?
  • kickinindian
    • 2327
    I need help and r3v has helped me more than anywhere else involving cars, anyways, my Ti needs a new head it's a 98' auto obd2 m44 but I can't find a new head that does not have cracks around the spark plug holes I've pulled 3 so far but I see alot of m42 that seem fine and they also have more metal cooling pipes than the m44 so I know they bolt on but what is the specifics of updating an m42 head to obd2 ?thanks guys
  • irish44j
    • 2763
    Put the whole M42 in. That way you get the better internals.....
    Stage rally/rallycross e30 build/competition journal
    Track/street e21 build
    visit Condor Speed Shop
    visit Motorsport Hardware
    [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
    • kickinindian
      • 2327
      Can't really do that in cali I still Want to retain obd2 I just want to know how the wiring and cooling etc. Would work.
      • bmwman91
        • Oct 2004
        • 3134
        It isn't easily doable. The M44 uses a totally different cam setup with different durations and lifts, so for one the ECU would need a custom tuning job. Second, the cam position triggering system is also completely different and I am not sure if you can even swap on the trigger wheels to the M42 sprockets (or if you can swap M44 sprockets onto the M42 cams). The M44 cam sprockets are a different PN than the M42 ones.
        As far as oiling and cooling passages, I think you are fine. My built up M42 uses an M44 head gasket. RealOEM shows a weird pipe conector thing being mounted on the back of the head, and I am not sure what that is or if it would fit on the M42 head. As far as the coolant temp senders go, I believe that the holes are the same.
        Get on www.car-part.com and call some wreckers. In the end I think that it will cost you a lot less time and money to find a clean M44 head than to be the first to try to run an M42 head on an M44.
        Transaction Feedback: LINK
        • kickinindian
          • 2327
          thats what i was thinking would be the hard part is the hydraulic cams in the m44 probably are different to run than the m42 the back pipe is a shitty coolant plastic pipe that the m42 had cast as a reliable metal piece.
          but your probably right just hate that the m44 had a bunch of plastic cooling bits and the m42 is mostly all metal
          • DER E30
            • Sep 2013
            • 2349
            Could you not move ALL the parts from the M44 head onto the M42??
            If the head casting itself is the same then everything should bolt right up??
            -Christian
            • kickinindian
              • 2327
              I don't think the casting is the same different styles of lifters
              • bmwman91
                • Oct 2004
                • 3134
                The castings are pretty different on the top end. Cams and lifters are definitely not interchangeable.
                • Josh1254
                  • Sep 2013
                  • 426
                  The heads are quite different and not really interchangeable.. Plus the sensors/wiring are a different design too.
                  • Dj Buttchug
                    • Jun 2010
                    • 7678
                    internals are also different. m42 pistons and rods are forged. m44 internals are cast
                    Turbo M42 Build Thread :Here
                    Ig:ryno_pzk
                    I like the tuna here.
                    Originally posted by lambo
                    • benz-tech
                      • Jan 2011
                      • 366
                      The M44 head weighs prob 10lbs less than an M42 head. Wonder why they crack?! The sprockets are interchangeable (cams are not) and you need the front cover from your M44 head to use the correct cam sensor setup and fits perfectly on the M42 head. It runs off the opposite cam from the M42 so you could just change the on sprocket.
                      Only the crank is cast,
                      the rods are forged 5mm longer versions of an s52 rod. Lighter/better than M42 IMO.
                      You say "Where are your other two cylinders?"
                      I say "Where's your other camshaft?"
                      Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
                      • ghalee30
                        • Jul 2011
                        • 614
                        just in case some were wondering, you can switch the heads.
                        ive had success with swapping a m44 head on to a m42 block. just needed to convert everything over, including cam sprockets.
                        i dont see why it wont work if swapping vice versa
                        • varg
                          Florida Turbo Man
                          • May 2014
                          • 3405
                          I don't know about that.
                          Left to right: M42, M44, M47, S50
                          IG @turbovarg
                          '91 318is, M20 turbo
                          • benz-tech
                            • Jan 2011
                            • 366
                            Its possible that one on the right is a euro s50. I had us s52 rods in my hand that were nearly identical (minus 5mm) to my m44 rods, the caps being slightly different. I dont know about the alloy content of course but they were a good match by eye.
                            And back to the op, I'm running an M42 on an M44 block currently, but he probably figured that out already since this thread is nearly a year old.
                            • TobyB
                              • 5266
                              Heebers, look at that M47 pin diameter....
                              t
