Broke diff. mount.
  • LowR3V'in
    • 4209
    Broke diff. mount.
    e30s suck and are weak.
    E30 diff mounts suck by jet jones, on Flickr
    Weak e30 mount by jet jones, on Flickr
  • TobyB
    • 5290
    You can retrofit an e36 setup with 2.
    2002= 2 mounts
    anemic E21 = 1 mount
    E30 = 1 mount, breaks off, therefore,
    E36 = 2 mounts, works great, therefore
    E46, whole subframe breaks off, because, if you have something that works great,
    why not improve it?
    hee
    t
    • varg
      Florida Turbo Man
      • May 2014
      • 3428
      Drifting?
      IG @turbovarg
      '91 318is, M20 turbo
      • LowR3V'in
        • 4209
        in a way. but na, just street driving.
        • JGood
          • Jan 2004
          • 7959
          Mine cracked there as well. I was able to get in there with a wire wheel to clean it up, and mig weld it back together, without removing anything. It's held up for a few months so far behind an m60. My plan this winter is to drop the diff and weld a long piece of steel angle on both sides of that beam, and probably do the Garagistic 2nd diff mount.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • LowR3V'in
            • 4209
            this would be optimal
            • JGood
              • Jan 2004
              • 7959
              Agreed! I considered that as well, but it's more of a project than I want to dive into at the moment. Sure looks solid though.
              • dsphil
                • 495
                The crack is mostly due to worn rear subframe bushings combine with hard driving and body rolling too much. 2 mount designs, poly bushing, or solid bushings will make it even worst as the rotating torque has to go somewhere. In some cases that is where the diff mount bolts start to tear off.
                327is
                325es
                325es
                318is
                Fiesta ST
                E46 M3
                • TobyB
                  • 5290
                  whut?
                  We break them not uncommonly in racecars with solid subframe bushings...
                  t
                  • Ceeker
                    • Sep 2009
                    • 2821
                    e36 M cars were tearing their diffs off the mounts as well. We were welding re-inforcement plates to the floor then bolting the diff back to it. it was caused by too much dumping of the clutch and hard shifting.
                    • e30austin
                      • 15382
                      Quoted "dsphil" for total truth, but a new pair of poly bushings is better than a pair of completely roached, 350k mile, original subframe bushings. I'm pretty hard on my red shop rat, but luckily, I rebuilt the whole rear end, before the differential body mount failed.
                      • e30davie
                        • Apr 2016
                        • 1788
                        Attack with wire wheel to remove all the paint and goop, weld it back together, inspect and replace bushes. Get back on the road and forget about it.
                        • moatilliatta
                          • 6152
                          I wonder how much worn subframe bushings play into this.
                          @Zakspeed_US
                          • LowR3V'in
                            • 4209
                            i just welded the face of it because my car was catching on fire too much.
                            The diff mount broke again on a 2nd gear pull. What are men to do..
                            To do it right the the diff needs to come out so f it, it's staying hanging like that.
                            • LowR3V'in
                              • 4209
                              you think this would fix it or na?
                              Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.
