Central Locking From DS Door
  • 88Sedan
    • Apr 2023
    • 260
    I am fortunate my cars central locking system works. From the trunk it works perfectly and easily. However my drivers side door requires an uncomfortable amount of effort to go to lock or 'double lock'. Is it safe to use graphite powder for locks in there? I'm afraid it will eventually snap the key, but it would be nice not to have to use the trunk all the time.
  • uturn
    • Dec 2010
    • 1004
    Now is a good time to install the alarm system to get the keyless unlock function.
    • 88Sedan
      • Apr 2023
      • 260
      In the meantime I guess I will use the trunk, which works flawlessly. I know this issue is common on e30s, I was hoping theres a fix for it-- even if it requires some disassembly.
      I just finished fixing up the motor, but soon I'll be tackling the front (then rear) suspension. When I get all that done, AC, keyless entry, stereo, cruise control and other small things are on the list.
      • reelizmpro
        • 9541
        Very common, that's why I stopped using the keys a long time ago and install alarms with keyless entry. You can rebuild the lock but it's a lot of work and I hear the kit is NLA.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • 82eye
          • Jan 2009
          • 2041
          the lock itself will be broken. there is no fix at the moment. the supplier has stopped making the repair kits. a lot of us are unhappy over it. it's component on 51211924903 that breaks. it is only available in repair kit 51219061343. there is an ebay seller making a printed part in the $300 dollar range. everyone is holding out for the kit, but it's not looking good.
          • varg
            Florida Turbo Man
            • May 2014
            • 3404
            My , do not "double lock" your E30. That feature was fine when the cars were new but now with worn out locks and linkages that you cannot rebuild because the parts are NLA, you risk locking yourself out any time you do that. I tried it once and I battled with the lock for a long time to get the key out of that position. Lubricating it, wiggling the key, tapping on the door, etc. before it finally moved and I felt like I was going to break something with the effort it required.
            Any kit recommendations? I disabled my lock actuators because there's something with the system that caused it to rapidly cycle the actuators at random and I didn't have time to deal with it, if I manage to fix that and can stop using the ever-tightening lock cylinders or lock/unlock from the trunk I would be happy with the result.
            IG @turbovarg
            '91 318is, M20 turbo
            • reelizmpro
              • 9541
              Not really, keyless kits have been around for decades. DEI, Omega are quality supported products that I have used. Really, all they do is provide a ground pulse to the central locking unit to lock/unlock. Quite simple, but obviously your factory central locking must work otherwise you'll need an aftermarket relay module kit to operate the actuators. It sounds like you have a short somewhere. Hopefully, it's within the module itself and you can repair or swap it out. I used to grab these for $5 at the junkyards.
              88 M3 - LACHSSILBER
              • uturn
                • Dec 2010
                • 1004
                FYI... the central locking module is in the left footwell. You'll need to pull the speaker to access it.
                • sna77
                  • Apr 2023
                  • 206
                  I bought this Omega REC-43T+ keyless locking system for $40 on Amazon. Works perfectly:
                  https://www.amazon.com/Proline-REC43.../dp/B00C92O5KS
                  These instructions:
                  1992 318i cabrio Alpinweiss 2
                  2006 ZHP cabrio Imola​
