This is a sticky topic.
    16x8.25 offset et25 lowered on HAndR with bilstein sport . Well in progress . Wheels spacer? Also 205-50 or 225-50 tires . I get confused with so many posts on here . Any guidance would be nice TIA
      I just wish there were more options for the 14". I have been debating on grabbing a set of the toyo proxes r888 in 205 50 14. Anyone run these on a street car?
        I haven't run them on 14", but they've been my "street" tires on the E30 since like 2009.
        They are loud though, and stiff. Don't expect 50,000 miles either.
          do they hook up ok? the noise I can live with as its 3in from turbo back with vibrant resonator and muffler. Im running a cheap 195 65 14 right now and if im not paying attention 2nd and 3rd gear are useless.
            Very noobie question here. I have an '87 coupe with 14' bottle caps. Tire size is 215/70 R14. I am looking to get an e30 sedan, also with 14' bottle caps. Those tires are 195/65 R14. Are these wheel/tire sets interchangeable? Thank you.
              Yes. If you Google tire size calculator there are a few good ones that will give you max and min tire sizes for a given wheel size.
              those will fit
                Thank you very much for the help!
                  Is anyone else here running the new ground control full coil over kit and if so what wheels and tires are you running? I just installed the kit and took it to the track and it was awesome but I am still running on 16" redrilled wheels and conti street tires. Want to go to the widest tire I can am open to 15, 16 or 17's. I do like the Apex wheels but I know they will be heavier than say a slipstream. Yes I have tried searching but can't find my exact combo.
                  https://www.driftshop.com/rota-slips...tin-black.html
                  looking these
                  https://www.apexraceparts.com/shop-b...c-8-wheel.html
                  or these
                  Either with a Toyo R888R in as wide as I can go. Probably 225 square right?
                  The guy I bought the car from says the fenders are rolled front and back but I have no idea how much.
                  Brilliantrot 1991 325-1995 BMW S50 Engine S50 intake-headers Borla Pro XS- 318is Radiator Spal 16 pusher fan Cone filter Tuned by RK- Bilstein Sport dampers with IE springs -Z3 steering rack- 16 style 5 from E32 Wilwood 4 piston Dynapro calipers -EBC pads Volkswagen Corrado rotors stainless steel lines-E32 M5 master cylinder, 325iX brake booster, 2002ti remote reservoir-1996 325i driveshaft Z3 3.15 Torsen LSD Z3 1.8 shifter IS lip and spoiler Antenna deleted Euro Grilles
                    Is it possible to get e34 basketweaves to fit on a e30?
                      With an 18mm 4x100 to 5x120 adapters they will be at an offset of +2, you can make it work with fender work and narrow tires but it will be really tight. They wont fit as is. The will fit pretty perfect if you do a fill and drill.
                      Euro Delivery Thread///E30 Project Klaus
