I recently installed a spec stage 3 clutch kit along with a jbr aluminum flywheel , everything ran fine for about 200 or so miles until I was started having trouble getting into gear , there was a lot of resistance and eventually it didn’t get into gear at all , I thought it was going to be my throw out bearing but when I dropped my transmission the other day this is what I found , the slave cylinder was broken along with the pressure plate ( springs unpacked ) but my throw out bearing was still intact , I have warranty on my clutch so I’m sending it back but here’s my next concern , does my flywheel also need anything done or is it still good ?
Does my flywheel need to be replaced or resurfaced ?
You could probably keep running it it, but now that it's apart, you should probably refresh it. That thing looks like it got pretty hotsigpic
Taking a transmission off is a pain in the ass. Any time I'm in there I replace what might need it. That looks like it's resurfaceable, but if not it's a replaceable steel plate so I'd do it.
IG @turbovarg
'91 318is, M20 turbo
[CoTM: 4-18]
'94 525iT slicktop, M50B30 + S362SX-E, 600WHP DD or bust - updated 3-17
Originally posted by AWDBOB View PostCall JB first and ask. I just sent that same flywheel in to JB to be refreshed because it was out of the car, like yours, and they refused to put a new plate on it and shipped it back.sigpic
Originally posted by McGyver View Post
Why'd they refuse?
Huh, so the consensus is to not use them? Why did you guys go with their light flywheel instead of turning a stock one?
I've just got an lightened regular flywheel, which I've been happy with. I think I'm around 8 lbs?sigpic
Originally posted by McGyver View PostHuh, so the consensus is to not use them? Why did you guys go with their light flywheel instead of turning a stock one?
I wouldn't use JB again due to the aforementioned. I would use RHD again. I think a lightened stock flywheel is best, though, if you have access to a machine shop familiar with lightening/balancing them.
