M20B25 Oil Capacity After Cooler Delete
  • NathanR
    • Dec 2023
    • 35
    I deleted my oil cooler over the weekend to make way for an intercooler. For reasons I cannot understand, a previous owner on this car removed the dip stick tube and plugged it in the block, so I don’t have a good way to check oil level. For those with an M20B25 without an oil cooler, how much are you filling your cars?
    https://www.instagram.com/shts_fkd_g...l4ZmRsajFlbjh2
  • It's Soda Not Pop
    • Jan 2022
    • 877
    I put in 5 quarts in my non cooler m20. You might want to see if you can put a dipstick tube back on it. I would.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • McGyver
      • 4637
      I put 5 liters (5.28 quarts) in my oil-cooled m20. I don't think the oil cooler drains much during an oil change.
      I would also see about putting a dipstick back in your car.
      • digger
        • Nov 2005
        • 6196
        The oil cooler volume is not a huge amount, so around 5 quarts to 5L will do the job. and the oil in the cooler doesnt drain out anyway when doing an oil change
        The figures you see stated for the m20b25 and m20b27 are the same and the b27 never came with an oil cooler. Admittedly they also state 4.25L when 5L seems to be more correct on the dipstick
        • varg
          Florida Turbo Man
          • May 2014
          • 3428
          Removed the dipstick tube and plugged the hole? Previous owner must have been a post E46 guy. "What is this weird tube with a plastic ring coming out of it? Time for weight reduction!"
          IG @turbovarg
          '91 318is, M20 turbo
          • reelizmpro
            • 9556
            Haha. It could be an E34 M20 which had the dipstick in the pan so the block was plugged/sealed.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
