Backyard turbo setups?
  • soates4
    • Oct 2015
    • 33
    Id like to see, or read about some backyard turbo setups. cheaply done and somewhat reliable. if any of you have a forum link or personal builds id love to hear about them.
  • Kershaw
    • 11822
    Have you tried r3vlimited?
    It's a pretty swell site.
    AWD > RWD
    • Exodus_2pt0
      • 5943
      Wait.... I recognize OP's name from some great thread in the past....
      False alarm. Carry on.
      But OP, best bet is to read up on how a turbocharger system functions. They work the same regardless of vehicle, so your best bet is figure out what you need and how it will work. Then, start your project. Take your time and wait for used parts if you want to save money.
      Maximum Boost - Corky Bell.
      No E30 Club
      • mrsleeve
        • Mar 2005
        • 16387
        one of my brothers better builds. Both mine and my brothers copies of Maximum boost are very well loved grease stained and dog eared......
        IMG_7125 by mrsleeve, on Flickr
        Originally posted by Fusion
        William Pitt-
        • ak-
          • 12422
          There's no real cheap in f/i. You're going to end up spending the money anyways.
          That's why you never see these "Boost build! On the cheap!" build threads finished or even hear from them again afterwards..
          If you can't afford to do it right in the departments that require things to be done right, just take your time and research a lot vs. blowing stacks to get it all done before the next hawt car meet. You'll enjoy it more.
          1991 325iS turbo
          • Dj Buttchug
            • Jun 2010
            • 7683
            this
            also nearly every build featured on r3v is home brew. Backyard brew has no correlation to cheap btw
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • 325ix
              • Aug 2009
              • 7783
              Cheap, reliable, power, choose two. You may get a boosted engine that is reliable but, at that point, it may not be worth the money.
              • stonea
                • 2892
                That website sounds gay
                My Garage
                Feedback
                Instagram: Stone.Hopkins
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3417
                  Mine is as backyard as it gets, used turbos that cost less than a tire, harbor freight welder and fluxcore wire for fabrication, chopped up M50 manifold on an M42. Traps 103 in the 1/4mi poorly launched, it's quick enough for DD use and corners great.
                  There are plenty of successful cheap forced induction builds on forums across the web, some are downright impressive. You just have to find someone who knows what they're doing or at least takes the time to learn about the stuff.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • ak-
                    • 12422
                    You're right! I guess I was mostly referring to people on r3v/BMW forums and E30's.
                    It's a habit of seeing someone with a thread "GOING TURBO!" then disappearing.
                    Even the successful ones will tell you to double your budget all said and done. Researching is the key, though.
                    1991 325iS turbo
                    • Exodus_2pt0
                      • 5943
                      Honestly "backyard" is the only way to do it.
                      Either you spend a shit ton of money on a big name kit, or you spend a little money on an eBay kit.
                      Other option is "backyard". Figure out what you need, buy the parts you need, build what you can't buy, profit.
                      No E30 Club
                      • flyboyx
                        • 8371
                        oh, it is...
                        Gigitty Gigitty!!!!
                        • TobyB
                          • 5280
                          But if you can do the plumbing yourself, it doesn't have to cost a nut.
                          I found that the details could easily set you back nearly as much as the manifold and turbo itself.
                          But the single most critical element is tuning, and that can be driven by the ECU-
                          if it's easy to see what the ECU is doing and modify it to be nice to the internals,
                          then the 'build' has the best chance of success.
                          Because it's ALWAYS "try something, then fix or improve it" with this sort of thing.
                          t
                          • AbsorbantNut
                            Non faccio funzionare questa merda
                            • Jun 2010
                            • 2491
                            I had a backyard turbo build way back when. Like other's have said before me, research is key. All the info on how to do it is out there, and you can find it if you spend the time looking. There's quite a few threads that have well documented setups as well. Goodluck in your turbo quest!
                            '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
