Bring a Trailer Auctions, E30 edition
This is a sticky topic.
  • bradmer
    • May 2016
    • 362
    #4231
    also this one slipped through somehow and closes tomorrow
    1989 325i Convertible
    https://bringatrailer.com/listing/1989-bmw-325i-65/[/QUOTE]
    Looks like a 1988 with the aluminum bumpers pushed in, the vin # shows 8/88 on realoem.com
    Pulled from auction...
    • 2mAn
      Señior Mod
      • 21031
      #4232
      WTF, its withdrawn now haha
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5604
        #4233
        wow, that wagon is retarded fast... holy bols
        • varg
          Florida Turbo Man
          • May 2014
          • 3429
          #4234
          I wish there was a 1/4mi time slip for it.
          IG @turbovarg
          '91 318is, M20 turbo
          • dmanb2b
            • May 2018
            • 367
            #4235
            Me too! Similar sedans I have seen with that particular tune are capable of 11's. A stock turbo car with a good tune will run mid 12s all day, with mid to low 12s on slicks. Meth and even nitrous would help that effort. Brad is a very meticulous person and the car is still not at it limits in terms of making more power.
            1991 318is
            2004 330ci
            2011 335d
            • Stanley Rockafella
              • Aug 2011
              • 4062
              #4236
              Is this what causes all the premature turbo failures? Or is it some other factors?
              Seems like they changing turbos on these late model BMW's are as common as timing belts on an M20
              • djjerme
                • 5082
                #4237
                It's not even that - my buddies turbo on the 1M died after the first track day in it. He had to warranty it out, but said he sees it all the time. And his 1M was bone stock.. It's just these motors are so stressed from the factory, it's not hard to find the limit on the stock setup. I think before he sold the car two years ago, he had warrantied the turbo at least one more time.
                2016 Ford Flex
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3429
                  #4238
                  In order to get those super broad torque delivery and minimal lag you get with modern twin turbo engines you have to heavily optimize the setup, using the smallest possible turbo for the given mass flow goal requirement while staying within a good efficiency range. Nobody actually instruments the turbos on these aftermarket tunes, they're probably spinning them past maximum rated shaft rpm. As for stock cars killing turbos, there are a lot of reasons a turbo can fail when you're pushing it hard. Who knows?
                  IG @turbovarg
                  • Motheye99
                    • May 2018
                    • 853
                    #4239
                    That was a N54 after all, they weren't really suited to sustain the stress those cars see. That said I was very surprised when I learned for ECU tuned F8X track taxis that the turbos where a wear item at around 40K Kilometers.
                    91' 318is 90' 325is
                    Originally posted by Sonny
                    Buy the E30s, they ain't gonna last long
                    E30 can make you, E30 can break you
                    "He who controls the Nova's, controls the Boomers"
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #4240
                      The turbos have problems with the internal waste gate flaps coming off, usually the reason they are changed - they rattle something fierce before completely failing.
                      john@m20guru.com
                      Links:
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3429
                        #4241
                        That's stupid. How did they manage to screw that up? Even cheap chinese aftermarket wastegate housings last with no issues. The mitsubishi turbos with angled turbine exits that they put on Volvos are the most similar design to an N54's turbine housing that I'm familiar with, I have never heard of any of those failing.
                        IG @turbovarg
                          • Aug 2011
                          • 4062
                          #4242
                          lower quality components would be my guess.
                          • dmanb2b
                            • May 2018
                            • 367
                            #4243
                            Maybe on the gassers. M57 stock turbos are stout and failures are rare. I have 140K on mine pushing 36psi and drive it like it stollen. Hybrids, which this wagon has, are even better, with upgraded internals.
                            1991 318is
                            2004 330ci
                            2011 335d
                            • 2mAn
                              Señior Mod
                              • 21031
                              #4244
                              1991 318i Sedan
                              Bid for the chance to own a No Reserve: 1991 BMW 318i 5-Speed at auction with Bring a Trailer, the home of the best vintage and classic cars online. Lot #21,565.
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • laidback93
                                • Nov 2016
                                • 435
                                #4245
                                Originally posted by 2mAn
                                1991 318i Sedan
                                I really like this even though it's a sedan. I would daily the crap out of it.
                                Wonder where it's going to end up at.
                                90 Bronzit 325is
                                16 Black Sapphire 340i M Sport
