2.8L M20 9.8:1 stroker build: my 323i reincarnated
  • betz
    • May 2016
    • 317
    #436
    Originally posted by digger
    Ignition to control idle is thing. If you imagine using a butterfly or other valve to control airflow there is a lag. Ignition is as instantaneous as it gets but the range of adjustment is limited using ignition so still need to have butterfly setup correct. Also don't want too much heat out exhaust with excessive retard
    Would that would be Megasquirt's idle advance option? I got the idea to flatten idle ign from browsing through this thread:
    https://www.r3vlimited.com/board/for...hread?t=390283
    I don't think mine is excessively retarded, relative to those in the thread. I'm at 15 where idle occurs. Before I think it was set into the low 20s.
    I'm going to try letting idle advance control idle ignition, and keeping my idle ignition table values flat. This morning I saw the flaw to my methodology since I have it idling higher on start, it was out of the range of my 'valley', and started hunting again. But once it dipped back into the 'valley' when the car was warm, it stabilized.
    EDIT: I ended up advancing ignition. With the idle advance, it seemed to idle better after it kicked in. But it would pin it to 30 deg. Advancing the tables, it goes directly to idling well and the idle advance hardly has to do anything. Here are my current tables that are giving me a very nice idle.
    Click image for larger version  Name:	yzLZPY5.png Views:	0 Size:	377.6 KB ID:	9884958
    And, digger , what vacuum would you expect to see from my motor at idle? 45 kPa when warm too little? It seems to go as low as 41 and I've seen as high as 50 kPa I've got 274 cams. I'm debating whether I should still check for vacuum leaks.
    '86 Burgundrot 325 2.8 stroker.
    Other cars:
    2000 Porsche Boxster
    2006 Subaru Outback XT 5MT
    1972 Porsche 914
    • digger
      • Nov 2005
      • 6198
      #437
      45 seems ok to me
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4506
        #438
        How did you set your VE tables?
        • betz
          • May 2016
          • 317
          #439
          45 seems ok to me
          Ok cool, it was actually pulling like 37 at idle today so I think I've ruled out any major vacuum leaks for sure. If it idles higher too, it would be getting less vacuum.
          How I set it up or what are they? Why not both lol.
          Once I got idle to be good enough, I ran the autotune live feature that comes with the paid tuner studio. Worked super super good. My AFRs at part load, full throttle, up hill, cruising, are all just dialed in it seems. I think my req_fuel might be slightly off because I'm not sure what the pink top S52 injectors lb/hr is on a 3 bar FPR, there's mixed information since OEM is 3.5bar. I have it set as 20 lb/hr. But to my understanding, if you adjust the fuel tables proportionally and you're not swapping injectors it shouldn't matter.
          Here is my current VE table. The only values I really edit myself are idle, usually. If my idle is wonky at all the autotune is likely to mess up those values.
          Other cars:
          1972 Porsche 914
          • e30davie
            • Apr 2016
            • 1788
            #440
            I just looked at my VE table and its basically itenticle to yours. mine is all done with auto tune as well except for idle, so yours should be on the right track.
            For what its worth my m20 seems to like idling around 19deg. (m20b23 9.8:1). you are on the right track in making sure that the ignition advance stays constant at all idling conditions. How have you set your idle control? if you change it to advanced and use PID contrl it makes a big difference. There is a bit of playing around to get the PID values right, but i think its going to be better than the "simple" method or whatever they call it.
            • betz
              • May 2016
              • 317
              #441
              Great to know! And I've been messing with that, I'm sure I'll get it dialed in. I did adaptive advance and tried both added and table, I really just need to spend more time on it though.
              Alright guys. I'm not the show off-y type, but I've gotten enough requests for videos, that I've finally done it. Hope you enjoy.
              In car
              From stop
              "Swing it bro!"
              Other cars:
              1972 Porsche 914
              • e30davie
                • Apr 2016
                • 1788
                #442
                That looks fun:) i like the color of your car:)
                • 2mAn
                  Señior Mod
                  • 21031
                  #443
                  love this car.... whens the dyno time?
                  also, is this now the funniest car of the group?
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • betz
                    • May 2016
                    • 317
                    #444
                    The E30.. is the most fun. Funny? Lol sure. The 914 has that potential for sure though. I've got the engine for it now (4A-GE 20V blacktop) but I'm trying to decide whether to get it painted (maybe in Tijuana??) or to just swap the motor in and fix it up to drive then do the paint later. It's kind of in a state where paint now would make me feel better though.
                    The Boxster.. is the most fun when you're going really fast. It's a great car but I feel the E46 took some of it's daily driver thunder away from it. Mainly because it's a better daily driver. Not that the Boxster is a bad daily by any stretch, I truly did not anticipate how great a daily the E46 is. I really love the Boxster still but it would be the first to go at this point. No harm in holding onto it for a while, for now though. Going for a blast in that thing is still amazing. It's just, you know, newer Porsches are even better :p. And so are some of older ones...
                    Dyno time.. well this time I'm probably not going to Mann engineering. Might have the hookups this time. Guessing it will be a less nice facility but that's kind of want that just so I can be there in the room while it's getting dyno'd haha. And take a badass video. Mann puts it in this chamber and I had to look though a little window. Which is cool, but also, for sissies. I'll hopefully know by this weekend
                    Other cars:
                    1972 Porsche 914
                    • AWDBOB
                      hooptie connoisseur
                      • Aug 2013
                      • 4506
                      #445
                      thanks!! I’m compiling all of the info I can before I set my MS2 up. The car sounds fantastic in those videos. It seems like it really pulls hard.
                      also, I had this saved in my notes regarding s52 injector flow rates.
                      • 3.00 Bar/ 43.5 PSI --- 22.50 lbs/HR --- 236cc/min
                      • 3.50 Bar/ 50.7 PSI --- 24.30 lbs/HR --- 255cc/min
                      • 4.00 Bar/ 58.0 PSI --- 25.98 lbs/HR --- 315cc/min
                      • 2.50 Bar/ 36.3 PSI --- 20.55 lbs/HR --- 216cc/min
                      • wworm
                        • Dec 2016
                        • 1719
                        #446
                        sounds so damn good
                        1984 Delphin 318i 2 door
                        • betz
                          • May 2016
                          • 317
                          #447
                          It pulls like a freight train now. And the car feels much more like it has an OEM tune, at the same time. Just more solid and consistent all around, I love it!
                          And thank you so much for those flows haha. That is very very useful.
                          Other cars:
                          1972 Porsche 914
                          • betz
                            • May 2016
                            • 317
                            #448
                            COVID-19 update:
                            No dyno time yet
                            I've finally fixed the odometer
                            Finally got my steering wheel back
                            Finally installed a new lower dash
                            Also have it on the original whodwho base tune, idling perfect running perfect. Confused about ignition though, seemed much more conservative than the DIYPNP base tune, yet, out of the box it was knocking more than ever before. Not a huge deal since I still tuned it out, but a head scratcher for sure. Also wondering if I might be losing power because of timing. It feels good though.
                            Since I'm not out of the house nearly as much these days... my E30 has become my 'daily' driver. Best condensed driving enjoyment of all my cars :)
                            Time to get started on that 914 tho... just been sitting while I collect parts but it's time has come!
                            Other cars:
                            1972 Porsche 914
                            • luckybk
                              • Jan 2019
                              • 127
                              #449
                              still jealous of these seats
                              • betz
                                • May 2016
                                • 317
                                #450
                                Got a pretty cool pic taken of it at the auto x the other day. Haven't anything too significant lately, it got an MTech-1 spoiler and matching trunk torsion springs. I modified the headlight relay for the smileys finally. And planning on running a variable TPS very soon.
                                Just been driving and enjoying- the stroker has been very solid and runs smooth. And most importantly... it's a blast!! It feels very fast. It's gonna be at least 200hp I think. I've been looking into some places with dynos- I think my last post in this thread will be the dyno result whenever I get around to it. I may have given up on ITBs... But only cus my 914 will be getting it.. in a stock 4A-GE blacktop. Which I now have as well as all the parts to get it installed.
                                Other cars:
                                1972 Porsche 914
