Bought a POS, this is R3Vs fault
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4503
    #181
    Originally posted by 2mAn
    SO what else is needed for this to work?... (1) Plug it in, after finding the hole and routing the wiring to the connector, (2) Who knows! ... that might be it! ...(3) fix more broken stuff and find the homes for all those loose wires...
    Check the clutch switch- if your car was auto factory and manual swapped, the cruise harness clutch switch plug will already be looped. But worth checking as that's what causes no workie cruise most of the time
    Post a pic of the top of your clutch pedal/pedal box
    • max.rodriguezzz
      • Sep 2024
      • 78
      #182
      My life the last few weeks of working on the e30 has been underdash wiring... lemme know what questions you have, also all my connectors are labeledm (ive used a lot of blue tape the last few weeks...) , next time I swing by the car I'll double check which connector is which and answer your questions.
      also.. still need that cruise control module?
      • calvino
        • Feb 2025
        • 102
        #183
        Some cruise control modules go bad - the electrolytic caps dry out, I had to desolder all of them and replace them with new ones from digikey to get mine working.
        • max.rodriguezzz
          • Sep 2024
          • 78
          #184
          Yes, no reason to buy several...
          Cross-posting this here, but made its own thread just in case someone actually searches for similar answers down the road. Basically, the never-ending project of trying to un-fuq the E30, I am trying to identify a bunch of various connectors.
          Group 1 is behind the dash in the glovebox area.
          This group sort-of looked like it would go behind the HVAC panel, but the blue connector should be for the Cruise Control Module, the others... no idea.
          Pretty sure I have a few of these identified. 2 wires for glovebox light, rectangle connector for the flashlight, but the rest?...
          Finally theres this. No clue at all. These wires/ connector are literally coming off the ECU!
          Now we switch to under the hood. This group is on the passenger side. I believe the boot-ed 2 pin connector is for the coolant that would've gone on the side of the radiator IF mine had the original early model setup, but mine has the late model radiator and reservoir. The long-ish chewed up connector SHOULD be for the exterior temp sensor, yes?
          Those 2 wires Im holding... no idea?... Notice anything else?
          Now, switch to the driverside. Similar connector to the pass side, but theres a bridged connector too...
          and after a few minutes of searching around via links provided by AWDBOB, and some more browsing on ebay, I found an actuator and it turned out to be SUPER local to me... went and got both the actuator AND the module for $80 which seems like the right price...
          Starting from here:
          We move under the dash to this connector.
          The other side is under the engine bay right now, but I still need some more time to find the hole in the firewall I need to feed it through...
          So for now, it sits here...
          The Actuator connects to here and basically heads to the throttle body. Notice the tight fit to the garagistic strut bar... yes, I broke the plastic trying to bend the metal.
          Theres the module which is mounted in the glovebox area to the blue connector pictured above. Here it is "mounted"
          What I can confidently answer for you right now -
          passenger side engine bay:
          - those 2 brown = washing fluid pump
          - that 2 spade pin whote connector = the pressure switch from the drier receiver into the chassis harness
          - that circular singular black one = proboaby ac compressor related? or maybe ambient air temp sensor?
          the radiator temp sensor 3 wires are = black, green/black, brown/black
          - pin 1 = green.black
          - pin 2 = brown/black
          - pin 3 = black
          • 2mAn
            Señior Mod
            • 21017
            #185
            - pin 3 = black
            Thanks for that. The passenger side is pretty well solved. Makes sense too since the A/C has been removed, same with the washer reservoir... as for the driverside, I am very curious how my temp gauge is wired because mine works and registers, but if those are the wires and they aren't connected to anything....
            One of the few things I want to figure out is the coolant reservoir light. Early model would've been on the pass side somewhere and needs to be run to the driverside since my car has a late model reservoir.
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • max.rodriguezzz
              • Sep 2024
              • 78
              #186
              The radiator temp sensor is for the aux fan.That aux fan is meant to turn on when the A/C is on, and that radiator temp sensor is meant to force that aux fan on if needed, like in an overheating condition.
              The gauge cluster temp sender (to the gauge cluster) is the brown sensor on the tstat housing.
              • 2mAn
                Señior Mod
                • 21017
                #187
                Makes sense... especially since there is no aux fan on the car haha
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5283
                  #188
                  These have really grown on me.
                  But if ever there were a car to slam into a wall, one of these would be it. I mean financially it isn't ideal, but you'd probably be fine and could go right back to the dealer and buy another.
                  Originally posted by priapism
                  Originally posted by shameson
                  • 2mAn
                    Señior Mod
                    • 21017
                    #189
                    Ended up going with these two pics from CAL-Photography... kinda disappointing the quality of the pics but whatever... Got my trackside pics.
                    In other news, the Mid-City gtg was Friday night, so I used that as an excuse to finally wash the car again. Was good meeting ya calvino
                    Good turnout as usual.
                    This was my choice of vehicle to take a pic of... anyone know this color? I didn't see the owner so couldn't ask him. Bahama Beige?
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • grandeswag
                      • Oct 2020
                      • 150
                      #190
                      Luxorbeige?
                      https://www.youtube.com/@DekadentGarage
                      • Hrodebert
                        • Nov 2021
                        • 23
                        #191
                        Are those the RML Big bottlecaps ?
                        • max.rodriguezzz
                          • Sep 2024
                          • 78
                          #192
                          Good pics XD I thought about going to the mid town meet but I was worried I wouldn't see anyone I knew. No friends + no bmw at the bmw meet, I was nervous lol. Shoulda known you'd be there.. next time
                          • Northern
                            • 5283
                            #193
                            I think they look like it.
                            I like the idea, but I think they need to make some in 15x8 with a decent offset and weight. I can't deal with 16" tires anymore.
                            • s14brent
                              • Mar 2014
                              • 571
                              #194
                              yess!! trackside pics ftw! hope you're hooked!
                              89 325i 4dr s52
                              02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
                              21' Toyota Tacoma TRD OR 4x4 6 speed Manual
                              • MrBurgundy
                                R3V Degenerate
                                • Mar 2012
                                • 5604
                                #195
                                dude for real.
                                it’s slim pickings right now for 16s…
