My E30M3 S14B23 -> S50B32 -> RB26DETT. We are alive!! p.28
  • catuned
    • Jun 2011
    • 2324
    #121
    Amazing car! Keep the updates coming when you have them. See a lot of cars but yours stands out! :)
    Work We Do
    CAtuned Feedback Page|FB CAtuned Page
    http://www.catuned.com
    • Mr. Horsepower
      • 386
      #122
      Piced up RS's from the paint shop today, and assambled one of them! Result is staggering! Merry christmast to you all!
      1987 BMW E30 M3 RB26
      2016 VW Polo 1.2 TSI R-Line
      Originally posted by 5spoke
      Fucking norway and your sick clean ass e30's! Yes i am yelling!
      • catuned
        • Jun 2011
        • 2324
        #123
        Nice work :)
        Love it!
        Work We Do
        • cale
          • Oct 2005
          • 2331
          #124
          Great build! Love the bat too haha.
          • bernzpeed
            • 3917
            #125
            bling bling
            89 E30 S52
            Transaction Feedback.
            • Mr. Horsepower
              • 386
              #126
              BBS RC project!
              New CNC alloy nuts for the BBS RS project rims!
              Had to take her out for a wash!
              Removed the rear bumper in search for rust, and found some! As well as I noticed the left bumper hook has been changed to the new type. Probably have been damaged on the left side.
              Cables cables cables....I MUST sort this during the spring and build a proper looking and sounding stereo. It will be insulated with Dynamat as well.
              Removed the carpet, and as I feared....it was WET! On both left and right side. I welded the whole floor last winter, but it is still wet. Maybe it is because I don't have the rubber on my DTM mirrors or the water seal on the door trim. Any ideas?
              E36M3 3.2l EURO rear calipers, is to be sandblasted and powdercoated.
              Overhauling kit for calipers from Ebay
              And brackets for the rear calipers.
              Today I received new 500hp++ driveshafts from PPM Racing in Australia!
              • goarmy
                • Nov 2011
                • 622
                #127
                ultimate driving machine
                That is one very impressive machine great job brother
                • coop
                  • Mar 2005
                  • 65
                  #128
                  3 Questions;
                  -what did you use to get your motor that clean?
                  -what dye did you use on your carpet?
                  -what is your dash wrapped/covered in?
                  thx
                  • Jszy25
                    • 352
                    #129
                    amazing car...
                    91' 318is - OBDI M52/ZF swap w/ S50 cams
                    • dball4
                      • 560
                      #130
                      Mind = Blown.
                      1989 M3
                      2008 135i 6sp
                      • Mr. Horsepower
                        • 386
                        #131
                        Originally posted by coop
                        3 Questions;
                        thx
                        -I used a cleaner like the Loctite Super Clean, glass blasting and paint
                        -The dye I simply bought on a textile shop, did cost almost nothing
                        -Dash is flocked. Procedure for that is the dash is sprayed with epoxy glue and then electrically charged nylon threads are sprayed on. The charge makes the nylon stand when it hits the glued surface.
                        • Ant_e30
                          • 292
                          #132
                          brilliant looking car, love the on-going progress!
                          those driveshafts look pretty beefy. i've got my eye on them on eBay as i am considering getting them for when i do an SR20DET conversion.
                          • logie74
                            • Feb 2011
                            • 2
                            #133
                            Hi mate looks good!
                            How did you mount the front sway bar? Is it off e36?
                            Are you happy with your sump conversion?
                            Cheers
                            • Mr. Horsepower
                              • 386
                              #134
                              Swaybar is stock e30m3 mounted in the front, adjustable endlinks required. There is welded mounts in front of the engine subframe. Just chopped them off an old subframe I had.
                              I'm very happy with the whole swap. For me, there was no other way to get the engine in properly. Welding the oilpan was a must. You then get to keep the semi dry sump and you get the oilpan just 0.5mm lower than the subframe. If you use the E34 oilpan, the sump sits very low.
                              • MattAvino
                                • Jan 2011
                                • 2147
                                #135
                                your e30 m3 is crap...give it to me.
                                E30 buildy things
                                http://www.r3vlimited.com/board/showthread.php?t=195286
