Kamotors E30-Turbo to ITB M20
  • GAbOS
    • Mar 2012
    • 523
    #1846
    As an FYI, the Mishi z3m (MMRAD-CON-99X) is setup like the M30 unit.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #1847
      Yea that's the mishimoto e36/e30 radiator
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • the imitator
        • May 2013
        • 1006
        #1848
        Negative ghost rider, Z3M unit is quite thicker.
        z3 radiator MMRAD-CON-99X: is 2.97'' thickness
        e36 m3 radiator MMRAD-E36-92: is 2.07'' thickness
        • RagtopE30
          • Dec 2010
          • 1869
          #1849
          Originally posted by kamotors
          ^ you running 2.5" charge pipes?
          Yes
          450whp 524 lb-ft 1988 336ic In progress
          http://www.r3vlimited.com/board/showthread.php?t=250709
          • kamotors
            • Nov 2007
            • 7102
            #1850
            ready for a quick start to make sure everything wired correctly and then I'll clean up and add a few things.
            stock wiring harness works excellent,just need to extend TPS wires, and get a new coil pack and re wire it.
            who wants my current wasted spark setup with spark plug wires?
            IMG_0945 by kamotors@y, on Flickr
            notched out the battery tray for downpipe clearance
            IMG_0944 by kamotors@y, on Flickr
            plenty of rad clearance
            IMG_0941 by kamotors@y, on Flickr
            IMG_0937 by kamotors@y, on Flickr
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #1851
              And it starts and idles perfect....
              7speedshop.com
              • RagtopE30
                • Dec 2010
                • 1869
                #1852
                Why wouldn't it? Good job man! Now you officially have the power of Thor under your hood!
                • kamotors
                  • Nov 2007
                  • 7102
                  #1853
                  Also revshift still hasn't shipped my guibo, everything I've ever ordered from them takes forever to ship:(
                  7speedshop.com
                  • TheTacoMan
                    • Nov 2011
                    • 2308
                    #1854
                    Do you even lift bro.
                    But for real revshift is slow.
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      #1855
                      Also in for video of m30 noises.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #1856
                        Want to hear this beast....
                        • Coltoyup
                          • Jan 2014
                          • 29
                          #1857
                          ill take the wasted spark for the right price. ill pm you. keep up the good work!
                          • stinkydriverx
                            • Jan 2008
                            • 501
                            #1858
                            I like how fast you work.... I will need a review on that clutch once you get a chance! I have a stage 2 spec and I'm hoping it will hold my turbo power but I'm skeptical.
                            Turbo m30 drift car build.
                            500whp or bust.
                            http://www.r3vlimited.com/board/showthread.php?t=256525
                            • tig welder
                              • May 2014
                              • 75
                              #1859
                              Couldn't you run the injector of the other side of the intake, ala M20, to clean up the turbo side as that'll be very busy on the passenger side fender area ...?
                              • delamaize
                                • Nov 2013
                                • 1453
                                #1860
                                Originally posted by thetacoman
                                also in for video of m30 noises.
                                this
                                Dumpster Fire Pilot
