Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #1831
    I dont have a swap guide, just learning as I go and whats on this forum.
    7speedshop.com
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #1832
      I'd get it. Provides some use full tips but you are pretty far so you may not need it. I am how ever 90% certain the capacity of the m20 rad isn't enough. Unless you be upgraded your m20 rad then idk
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • kamotors
        • Nov 2007
        • 7102
        #1833
        I'll just grab a mishimoto E36 later, for now I'll run the M20 rad.
        Just need to grab a hose barb so I can finish my expansion tank hose, run a couple wires and then it will start:) its full on compcams 15w50 break in oil.
        7speedshop.com
        • TheTacoMan
          • Nov 2011
          • 2308
          #1834
          My research says they are the same capacity. You should start it meow.
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #1835
            Lucky you. I'm waiting on my b35 intake manifold then I can finish up the motor harness and get it plugged in to the ecu I was lucky enough to find someone to make me m30b35 to early model harness adapter over on mye28. I gotta make mounting brackets so i get the rad secured in and then shorten my hoses as they are also way to long to fit the mishimoto radiator.
            Tacoman- Kamotors is some how getting this motor to go in so perfectly idk haha hasnt had to swap radiators or shorten his shift linkage. I on the other hand have had a hell of a time haha
            • TheTacoMan
              • Nov 2011
              • 2308
              #1836
              This tends to happen with most endeavors on the e30s and Ka, I cant think of any other instances of this but there has been alot where things and idea happen to work out perfectly.
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #1837
                Really wish that would happen for me once in a while haha
                • LJ851
                  • 7919
                  #1838
                  Keep it up Ka, nice work.
                  Lorin
                  The M30 is God's engine.
                  • RagtopE30
                    • Dec 2010
                    • 1869
                    #1839
                    NICE! Also wanted to throw my hat in the ring as one of those people that is using a completely stock e34 coolant hose setup without shortening and my shifter linkage is unmodified and works as if the factory did it that way. Looking good man keep it up and make everyone jealous.
                    450whp 524 lb-ft 1988 336ic In progress
                    http://www.r3vlimited.com/board/showthread.php?t=250709
                    • kamotors
                      • Nov 2007
                      • 7102
                      #1840
                      ^ you running 2.5" charge pipes?
                      7speedshop.com
                      • TrentW
                        • 2815
                        #1841
                        You must be giddy with anticipation.
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #1842
                          I just dont get it....for me without shortening my arm and linkage I had no bottom gears. r,1,3,5 would have been all.
                          • GAbOS
                            • Mar 2012
                            • 523
                            #1843
                            I still have a 3 core z3m rad locally for you. ;)
                            • IronFreak
                              • Dec 2012
                              • 3702
                              #1844
                              That and the inlets are different.
                              Wait do you have a mishimoto m20 radiator?
                              early and late model m20 radiators are different.
                              Instagram @rebellionforge
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #1845
                                I see. Guess I would of figured that out in a few days.
