Kamotors E30-Turbo to ITB M20
  • ST1G
    • Oct 2012
    • 6689
    #1876
    Finish it and then tell the guys from Drive to comeback haha
    Would love this.
    • RagtopE30
      • Dec 2010
      • 1869
      #1877
      You will be at 500ish for sure.
      450whp 524 lb-ft 1988 336ic In progress
      http://www.r3vlimited.com/board/showthread.php?t=250709
      • kamotors
        • Nov 2007
        • 7102
        #1878
        finally got the M30 bled, its running at a steady 188degrees while sitting which I feel is a bit hot once I boost it. My M20 ran at 170degrees until it was beat on a lot and even then 190 was about as hot as it would ever get. keep in mind both cars ran a 71c thermostat, I'm thinking I need a better electric fan all ready. what flow rate are others running?
        Mine is rated at 2300cfm and is 12", would I benefit going to a 2300cfm 16" fan or would the difference in size not make a huge difference since flow is he same?
        I can also fit another 10" fan on the front of the intercooler than does 1800cfm but I'm not sure it would help being mounted 3" away from the rad.
        since my fan is a pusher its only about 80% efficient so its not even moving 2300cfm that means as well
        let me know what you guys think.
        7speedshop.com
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #1879
          Probably need a bigger fan. If that doesn't help then try and bigger rad
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • kamotors
            • Nov 2007
            • 7102
            #1880
            another Q how will increasing diameter of the fan and keeping equal flow effect my cars cooling?
            bigger surface I'd think would help cool more of the fluid but at the same time I'm not sure it would make as big of a difference as adding a small fan to the front of the intercooler and or a really small fan as a puller on the opposite inside corner of the rad.
            7speedshop.com
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              #1881
              It would pull more air across a bigger surface area. I would try and find a 16 inch fan with a bigger flow rate. Your small fan idea may work better though cause that would increase the flow a lot more.
              • LJ851
                • 7919
                #1882
                Are you sure your 12 inch fan is 2300 ? That is a lot for a fan that small.
                Edit: just found it at Summit. The same fan in 8 inch is even higher CFM.
                Even if those numbers are somehow correct, i think a larger fan would help a lot. When the fan is on, you only have airflow where the fan is. The rest of the rad is stagnant. It would be like blocking part of your rad as you are traveling at speed, it makes a big difference.
                Lorin
                The M30 is God's engine.
                • kamotors
                  • Nov 2007
                  • 7102
                  #1883
                  Ill try and get a 16" fan I think permacool really over rates there fans.
                  7speedshop.com
                  • kristov
                    • 222
                    #1884
                    That would change with proper fan shrouding, yes?
                    • Rdreas
                      • Aug 2013
                      • 164
                      #1885
                      Another awesome swap! I just saw the m20 turbo youtube feature and it was epic! keep up the good work.
                      • Luis325
                        • 3847
                        #1886
                        Cant wait to see her done Kameron!
                        Its looking good!!!!!!!
                        1986 "C2 2.7 Alpina" Sedan
                        1987 325ic Black Vert
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1887
                          finally got to drive it, revshift guibo was perfect for the job.
                          stage 5 clutch is pretty much perfect.
                          7speedshop.com
                          • AwakenNoMore
                            • Dec 2010
                            • 1291
                            #1888
                            I can only imagine how loud that was, looking good man.
                            1991 325i - "Scambles" The Daily Driven lightly modded.
                            1988 Mazda RX-7 TII "Mako" The Free Dorito
                            bacon by Jared Laabs, on Flickr
                            • kamotors
                              • Nov 2007
                              • 7102
                              #1889
                              sounds awesome lol
                              7speedshop.com
                              • purple haze
                                • 51
                                #1890
                                Love the build, have spent like an hour going through it.
                                Where did you get the alpina valance?
