Kamotors E30-Turbo to ITB M20
  • ak-
    • 12422
    #1966
    Originally posted by kronus
    FWIW our NA M30 runs at 180 with an e28 radiator, and around 200 with a e36 one. It's possible that the e28 unit just has more cooling capacity.
    WAT.
    What is this wizardry? How different are the dimensions?
    1991 325iS turbo
    • kronus
      • Apr 2008
      • 13032
      #1967
      Is the e36 a 3-core?
      it was a 2-core i think
      ak, the e28 radiator definitely takes more water.
      cars beep boop
      • ak-
        • 12422
        #1968
        I researched a bit and see that people are using them in their m30 swaps.
        You reckon they can be used in m20's? Looks like there is just a lower passenger hose problem as well as an overflow tank issue(?) from my google detective work.
        1991 325iS turbo
        • kronus
          • Apr 2008
          • 13032
          #1969
          Their inlet/outlet setup is the same as late model e30, upper left and lower right. you might need to improvise a lower hose, but the radiator itself drops right in.
          cars beep boop
          • Good & Tight
            • Apr 2004
            • 2057
            #1970
            Originally posted by kamotors
            So the coolant res. tank definitely sits a bit lower than the bleeder screw on the M30. I unhooked and raised the tank a good 3-4 inches and started squeezing hoses and had a ton of large air bubble come out so I have hope it will run a bit cooler this time around.
            What temp gauge are you using?
            Mine runs in the 188-89 range, 200 when in boost then settles back down. Have one large pusher fan in front of the radiator, I think it's 2300cfm, it's the largest one from Discount Auto.
            As long as it's not overheating you should be fine.
            Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
            ____________________________
            E-mail Panayiotisx2@gmail.com
            Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
            • kamotors
              • Nov 2007
              • 7102
              #1971
              PROBLEM#1
              soo tired of this cooling issue, I worked on this car ALL day. I dont even think any of the original coolant is left I've bled so much. Running on water wetter now and its EXACTLY the same. 198 on freeway, 200-205 cruising, 215+ driving sporty.
              NO amount of airflow cools this down, I cruised at 100mph for a couple miles lowish rpm and it only dropped down to 187.
              I have done every bleeding method I've read and heard of, its not a bleeding issue, I'm starting to think my thermostat is messed up or something.
              PROBLEM #2
              LOTS of overboosting, when running a 10.5psi spring it hit 20+ and kicked on overboost protection. I swapped to a 9psi spring and deleted the boost controller and its exactly the same. Even upped the vac line to a huge 8mm I.D. hose still the same.Not motivated to pull the exhaust off for the 3rd time today and put a softer spring in.
              7speedshop.com
              • Dj Buttchug
                • Jun 2010
                • 7686
                #1972
                what temp gauge are you using
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • kamotors
                  • Nov 2007
                  • 7102
                  #1973
                  using tunerstudio and the stock gauge. Both show the same. this is with a 71c thermostat
                  7speedshop.com
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #1974
                    Kamotors 325i Turbo build+M30 build
                    Need more cooling capacity? Lower temp thermostat? Just throwing shit out.
                    Nvm see you are already running low temp therm
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • Dj Buttchug
                      • Jun 2010
                      • 7686
                      #1975
                      Interesting. Had issues with my tuner studio temp reading 10-14 degrees hot constantly as well however my OEM gauge never read past half way. I installed an aftermarket temp gauge which reads correctly.
                      Not sure if there is coincidence here but you can tier temp readings in TS to compensate for variations. ????
                      Ig:ryno_pzk
                      • barbierij
                        • Sep 2012
                        • 1294
                        #1976
                        Possibly an ignition timing problem?
                        Sent from SPACE using Tapatalk 2
                        FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
                        Saab/GM tech2 programming
                        My for sale thread
                        1990 325iX for sale or part out
                        Did you buy something from me? Please leave feedback!
                        Originally posted by K20RI_211
                        And I have to ask if you make a hobby out of thread-bombing with retarded questions?
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1977
                          how so?
                          7speedshop.com
                          • barbierij
                            • Sep 2012
                            • 1294
                            #1978
                            It might be advanced too much under boost
                            My for sale thread
                            • LJ851
                              • 7919
                              #1979
                              Sounds like you need more radiator. Do you have a temp gun? I'd be curious to know what kind of temp drop you are getting from inlet to outlet on the rad.
                              Lorin
                              The M30 is God's engine.
                              • delamaize
                                • Nov 2013
                                • 1463
                                #1980
                                ditch the thermo, see if that makes a difference.
                                I'd also pull off the bumper and lip, see if that makes any kind of significant difference.
                                you might think about having a custom rad built for it. it will be expensive, but probably worth it.
                                Also, is their an aftermarket water pump that flows more fluid? maybe a overdrive pulley system? or an electric water pump, a la Nascar?
                                My gut feeling this is a flow issue, both coolant and air, eliminate one at a time, and see what happens.
                                As for the overboosting, I'm not really up on forced induction, Frankly most of what I have learned, came from this thread. but I do know a little about metals, and I wonder if the location of the BOV is too hot, and maybe effecting the strength of the spring? Like I said, I'm kinda stabbing in the dark here.
                                Dumpster Fire Pilot
