Kamotors E30-Turbo to ITB M20
  • delamaize
    • Nov 2013
    • 1453
    #2521
    Not to question your decision, but IMHO, the extra 10 lbs of the Alpina wing is worth it. I don't think your car would look right without it....
    Dumpster Fire Pilot
    • Alpina
      • Oct 2004
      • 838
      #2522
      The shield is stunning........
      Sveinbjörn Hrafnsson
      E30 CABRIO V12 M70B50 ///
      ALPINA B10 BITURBO 346 @ 507
      E34 550 V12 JML
      Finnish wisdom : If you want to Win,, hire a Finn
      http://alpina.123.is/pictures/
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #2523
        Originally posted by kamotors
        Were talking like 10lbs here, nothing drastic
        True.. you should get a zender wing would look good. I plan on getting a custom carbon fiber gurney flap made for mine
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • kamotors
          • Nov 2007
          • 7102
          #2524
          just enjoying the good weather. 1080p60FPS
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #2525
            The aftermath noise....
            7speedshop.com
            • Miuge
              • Feb 2015
              • 201
              #2526
              I think 10lbs at back end isn't a big deal if you have a turbo M30 in front.. :D I like the current looks, very clean!
              Facebook - MRT Engineering
              eBay - MRT Engineering
              Instagram - mrtengineering
              YouTube - miugemrt
              • sayed ali
                • 762
                #2527
                Nice videos :) still didn't fix the tranny issues?
                M20B28 Turbo
                My Build Thread
                http://www.r3vlimited.com/board/showthread.php?t=255839
                • kamotors
                  • Nov 2007
                  • 7102
                  #2528
                  tranny seems fine, not sure what this new decel noise is still, to busy working on the IX today for some reason the transfer case is puking everywhere.
                  7speedshop.com
                  • Bimmer_man
                    • Jan 2013
                    • 1477
                    #2529
                    If you need any help on the ix man I'm happy to help.
                    Float like a cadillac sting like a Bimmer!:)
                    • LJ851
                      • 7919
                      #2530
                      An exhaust making contact with a hard part during decel can make that noise...
                      Lorin
                      The M30 is God's engine.
                      • kamotors
                        • Nov 2007
                        • 7102
                        #2531
                        Exactly what I was thinking, passenger motor Mount seems to of let my engine sit closer to shock tower may of melted it, my pass trans mount has also melted and deformed.
                        7speedshop.com
                        • Bimmer_man
                          • Jan 2013
                          • 1477
                          #2532
                          Time for some solid motor mounts Haha.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #2533
                            So condor motor mounts and new wastegate tube finished/installed. As I was installing I discovered a corner of a gasket under the hood, I did some further Inspection and discovered the turbo to manifold gasket completely exploded, its frayed, has torn metal edges etc looks like a bomb went off! Tried to pull off turbo but the bolt closest to oil drain backed out a few mm then completely seized and when I went to use more leverage of course it stripped...... im so sick of this.....
                            Pros-new mounts, better clearance exhaust.
                            Cons-turbo has half a gasket, bolts stripped with no room to sneak a dremel or other tools in there.
                            7speedshop.com
                            • Bimmer_man
                              • Jan 2013
                              • 1477
                              #2534
                              Damn dude ever since you installed that m30 you've been having nothing but issues. I hope you're close to the end of the issues man.
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #2535
                                To much booooost haha
