Kamotors E30-Turbo to ITB M20
  • delamaize
    • Nov 2013
    • 1453
    #2416
    Get that tranny out Bruh! I'm curious if the flywheel came loose.
    I talked to a mechanic friend and showed him the death rattle video, he said to check out the slide the throwout bearing rides on, he said that if it's quite a bit smaller than the bearing it will rattle like a motherfucker also, and he also agrees with others that have said it may be a loose flywheel, and it could be a fuckered input shaft also.
    I know I'm curious as fuck, that's for sure.
    Dumpster Fire Pilot
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #2417
      Originally posted by kamotors
      truth:( buuuuut i may get another E30 this week. so I'll have 5 car, 2 subies and 3 E30's lol
      how come your getting another? Should get this one running like top first. Specs on the 3rd one?
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • kamotors
        • Nov 2007
        • 7102
        #2418
        so Delamaize was right!loose flywheel, seems I was missing that load plate
        but things got nasty in there
        gouged things pretty bad, not sure why the gouge got so deep on each side though? just vibrations and metal particles grinding away I guess.
        so going to debrur crank, replace everything else, get missing parts etc and put back together, no way am I replacing the crank.
        7speedshop.com
        • LJ851
          • 7919
          #2419
          I don't see any loctite in there unless the flash is hiding it. I don't care what anyone else says, i red loctite all my flywheel bolts and have had exactly zero flywheels come loose ever.
          Make sure all the high spots are off the crank end and you should be good.
          Lorin
          The M30 is God's engine.
          • ForcedFirebird
            • Feb 2007
            • 8300
            #2420
            What did you torque them to? Couldn't tell you how many FW's I have done and never had one come loose, never used Loctite, but always to torque them to factory spec. BMW bolts need sealant to keep the thread from leaking oil, though.
            john@m20guru.com
            Links:
            • whodwho
              • Jun 2008
              • 1547
              #2421
              Blue Loctite works to keep them tight and sealed ;)
              My M20 Frankenbuild(s)
              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
              • jntar
                • 459
                #2422
                I knew that was the problem. Glad you're getting it fixed. Like I said, don't forget the loctite this round since you removed the OEM thread lock.
                M42 turbo build.
                http://www.r3vlimited.com/board/showthread.php?t=301330
                • kamotors
                  • Nov 2007
                  • 7102
                  #2423
                  I ordered more new hardware so they come with that yellow sealant/lock on them.
                  120nm was the torque, the thing was the bolts werent that loose, they had just backed off a very slight amount which let the thing pivot side to side.
                  not sure why this happened, I've done like 5 or 6 flywheels and non have had issues except this one.
                  ALL hardware was brand new, and the flywheel bolts had the yellow lock on them and was torqued down, not sure how this happened, only thing I can think of is its the missing torque plate, spacer caused this issue
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #2424
                    here is a pic of the clutch, that tcd wouldnt give me info about.
                    I looked up the number, just seems to be a regular stage 3? part number shows an fx300 yet todd said its good for over 500hp
                    [IMG]20141206_130230 by kamotors@y, on Flickr[/IMG]
                    7speedshop.com
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #2425
                      Wow got nasty in there. Missing load plate will definitely cause that.
                      • LowR3V'in
                        • 4209
                        #2426
                        Take pictures of the disc.
                        segmented kevlar is "stage 3"
                        good for 500hp unless it's on a diesel 700tq 300hp.
                        • MatRacer
                          • 562
                          #2427
                          Dont remembrer if your flywheel is made of aluminium, but if yes, the load plate is important... Even if its from 6061 T6...
                          E30 now S52
                          2008 Suburban LTZ (Family and TT hauler)
                          325xiT (Sold)
                          • kamotors
                            • Nov 2007
                            • 7102
                            #2428
                            It's steel
                            7speedshop.com
                            • Good & Tight
                              • Apr 2004
                              • 2057
                              #2429
                              Good thing you stopped driving it, you wouldn't want that flywheel letting go on WOT pull.
                              Some liquid teflon sealant on the threads or loctite is all you need. Another thing to check is the correct flywheel bolt length.
                              Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                              ____________________________
                              E-mail Panayiotisx2@gmail.com
                              Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #2430
                                Length is a reason more than one car has come in for "engine is locked". :(
                                The look on their faces when they see the short invoice to change a few bolts is priceless, though lol.
                                john@m20guru.com
                                Links:
