Kamotors E30-Turbo to ITB M20
  • cleanasse30
    • Jan 2014
    • 436
    #3166
    If I'm not mistaken that white car has a shit load of compressor surge every time he lifts off the throttle. Does it have any kind of blow off or bypass valve on it?
    2.7i Stroker Turbo Build Thread
    90 325i | 95 Miata
    • IronFreak
      • Dec 2012
      • 3702
      #3167
      It has no BOV or bypass, hence the noise it makes.
      Instagram @rebellionforge
      • cleanasse30
        • Jan 2014
        • 436
        #3168
        That makes sense. Why run without a bypass or BOV?
        90 325i | 95 Miata
        • IronFreak
          • Dec 2012
          • 3702
          #3169
          I believe it's a low boost setup. Like 3-7psi? You'll see a lot of auto boost setups that don't run them either.
          • econti
            • May 2014
            • 1147
            #3170
            Don't need one if you have a good quality turbo as there's no ill effects
            • IronFreak
              • Dec 2012
              • 3702
              #3171
              Not entirely true.
              • ForcedFirebird
                • Feb 2007
                • 8300
                #3172
                Premature bearing an seal wear.
                john@m20guru.com
                Links:
                • ak-
                  • 12422
                  #3173
                  Loadin' up them bearings.
                  1991 325iS turbo
                  • ccsdo5
                    • Mar 2013
                    • 708
                    #3174
                    Yup but I will say most journal bearing turbos take a ton of abuse plus rebuild kits for some of these turbos are cheap. I think I spent like $50 for a T25 rebuilt kit..
                    -Dee
                    5-lugged turbo 318is Barn car
                    IG: @deebelmont
                    • kamotors
                      • Nov 2007
                      • 7102
                      #3175
                      Guyz its a $150 cxracing turbo with more miles than all my recent builds combined lol. it's only been at around 9lbs its whole life. Its been like 3 or 4 years without a BOV and it doesnt burn oil or have excess shaft play.its been auto-xed, rally'd, Daily'd and raced without issue. if he has to spend $150 every 5 yrs for a new turbo he doesnt mind.
                      Its literally the go anywhere E30.
                      7speedshop.com
                      • efficient
                        • Feb 2012
                        • 3312
                        #3176
                        I need friends like you that turbo e30s for fun
                        • TeXJ
                          • 1914
                          #3177
                          Originally posted by efficient
                          i need friends like you that turbo e30s for fun
                          +1 ;d
                          1990 325is
                          m52b28
                          3.73lsd
                          g260 (1987 325is 5spd tranny)
                          • mikebloco
                            • Feb 2015
                            • 190
                            #3178
                            How much power is that white car making on only 9 lbs
                            • Good & Tight
                              • Apr 2004
                              • 2057
                              #3179
                              All I hear is pure sex when I listen to those videos, surge..??lol
                              Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                              ____________________________
                              E-mail Panayiotisx2@gmail.com
                              Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                              • kamotors
                                • Nov 2007
                                • 7102
                                #3180
                                Id say 280ish, I really dont know. its on WAR chip so we cant run a virtual dyno to get an estimate. My Subaru WRX made 290whp on a stg 3 protune and this car was faster.
                                It has similar motor to me, 280/274 cam, HD rockers, 7lb flywheel, 42lb injectors
                                7speedshop.com
