Kamotors E30-Turbo to ITB M20
  • ForcedFirebird
    • Feb 2007
    • 8300
    #3181
    Originally posted by Good & Tight
    All I hear is pure sex when I listen to those videos, surge..??lol
    Sometimes you hear it with a bypass even :)
    john@m20guru.com
    Links:
    • e30 gangsta
      • 3877
      #3182
      https://www.youtube.com/watch?v=LPxpliUiNwI
      I should paint my bay black, It looks so clean lol
      • kamotors
        • Nov 2007
        • 7102
        #3183
        hartge rep rear valance from poland, less than 4lbs, perfect fit and excellent finish? win-win
        sits lower and wider, just need to finish up a few things and paint and mount
        but of course I have to modify it just for fun. making a rivet-on exhaust delete panel
        20151028_121516 by kamotors@y, on Flickr
        7speedshop.com
        • Bimmer_man
          • Jan 2013
          • 1478
          #3184
          nice hartge rep. Where did you get it?
          Float like a cadillac sting like a Bimmer!:)
          • Bearmw
            • 1323
            #3185
            Looks good from that angle.
            • kamotors
              • Nov 2007
              • 7102
              #3186
              some photos from the weekend
              [IMG]E30tyleredit by kamotors@y, on Flickr[/IMG]
              e30tyler by kamotors@y, on Flickr
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #3187
                7speedshop.com
                • Blake B
                  • Feb 2015
                  • 150
                  #3188
                  Where'd you get the DTM wiper?
                  1990 325i Cashmere Beige
                  "I don't like question marks. They're like exclamation points, but think they're fancy because they're curved. I won't tolerate it." -MNChiefsan
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3189
                    So took off rear wheels to mount the hartge valance and discovered both rear wheel spacers broke. So stay away from dsx brand
                    Sent from my SM-N920T using Tapatalk
                    7speedshop.com
                    • LJ851
                      • 7919
                      #3190
                      How thick is that spacer?
                      See how little meat there is where the spacer comes back over the top of the center of the hub? Writing off the entire line of spacers because one of them is poorly designed seems excessive.
                      Any spacer that thin that is hub centric would have similar strength issues, the wall thickness is just gets too thin.
                      Lorin
                      The M30 is God's engine.
                      • kamotors
                        • Nov 2007
                        • 7102
                        #3191
                        10mm that are sold specifically as e30 wheel spacers, but clearly don't fit the rear, most brands like h&r don't put a lip on the 10mm spacers. So I guess just avoid there 10mm spacers, they were likely bottomed out on the center hub and not even making contact with rotor mounting surface so repeated tightening of the wheel likely broke them.
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #3192
                          winter plans-
                          Install my new fx400 clutch
                          paint the hartge rear valance
                          finish exhaust setup to exit at the rear
                          800lb rear springs
                          Koni rear shocks
                          new disks
                          renewed rear calipers
                          Ultra wide rear flares(maybe)
                          build a decklid from either FG of CF.
                          Mount my 2gallon Methanol tank less janky
                          Already started ducting the FMIC better
                          20151023_160533 by kamotors@y, on Flickr
                          and hiding my front poke a bit
                          20151023_160553 by kamotors@y, on Flickr
                          7speedshop.com
                          • Coyote_ar
                            • Sep 2009
                            • 175
                            #3193
                            10mm spacers are really the problem. they are too thin so theres not enough material to clear the hub.
                            ---E30 320i Hennarot 1984 Sedan---
                            • kamotors
                              • Nov 2007
                              • 7102
                              #3194
                              New clutch in today, everything went super smooth. Drives nice, soft pedal feel and almost no chatter.
                              Still need to make a finished exhaust setup.
                              7speedshop.com
                              • efficient
                                • Feb 2012
                                • 3312
                                #3195
                                Dang you tear this car apart pretty fast
