Emma Watson and 2 E34's (Low Mount Turbo M50 Project)
  • Dj Buttchug
    • Jun 2010
    • 7688
    #616
    Many things have happened in the past few months.
    More tuning and some lovely time plots revealed that I have a pretty serious fuel pressure drop under boost. System is a 255lph, stock lines stock rail (now with 870cc injectors) Green giants have been replaced as they are too small for my goals. I later installed a 340lph and still the same results
    With a 10-15psi drop in fuel pressure it was clear the stock wiring was overheating. I made my own bulk head and upgraded the wiring. While I was in there I installed a 400lph pump and converted the fuel lines to -6AN. Stock fuel filter went in the trash. Modified the factory hanger to mount a Porsche threaded filter with fittings. I hard wired in a relay to control the pump and pulled power directly from the battery.
    Here are a few pictures. A simple OEM relay does the job perfectly.
    With the pump and lines sorted I could now move on to other problems I ran into. Including dyno rolling we have about 1500 miles or so driven.
    Exhaust leak the header developed on cylinder 1 and the engine sounded like a tractor.
    To get to it is a major ordeal so yet again the car is back in the air with the exhaust and turbo completely torn down.
    Here you can see where the gasket has failed.
    So, While we are in there its time to do something Ive always wanted to do but had no idea how to do it other than what Id seen online. Bought a cheap spot welder off amazon and let it rip.
    All previous attempts at wrapping exhaust with fiberglass based material has failed. Turbo blanket fell apart in my hands during removal and all the exhaust wrap is shot.
    Here is the blanket completely destroyed from heat cycling.
    Using 1/2 inch cilica based insulation and stainless embossed steel sheet to build a better quality heat barrier should hopefully last longer and work better.
    Note: I still have heat problems in the engine bay. Dyno session 3 with new injectors melted more of my firewall insulation. Yay. Smells like burning crayons.
    The new insulation on all exhaust system parts will handle a 2200 degree constant heat exposure. The manifold and main section of the exhaust still needs to be done. The process is very time consuming. I have probably done over 50,000 individual spot welds so far.
    Here is the result. There are a few areas I am not happy with. This is my first time doing this.
    Replacement manifold gaskets and T3 gasket will now be solid copper. My previous heat shielding made from embossed sheet will no longer cover the exhaust manifold. The block shielding will stay in place as extra insurance.
    A while back I ordered a Radium fuel rail with plans to install it with new injectors. Removing the stock rails meant changing all fuel lines to AN 6. The stock radium rail designed for m50 does not fit. The mounting was incorrect and I could not get the rail to sit correctly without being cockeyed. I didnt want a fuel leak to burn my car to the ground so I returned it and found this no name ebay setup that worked exceptionally well. It was less expensive too.
    Shots of Raduim rail fitment (overpriced junk)
    Heres a couple of the new injectors in the new rail. The only downside with the new rail is the fitment of the fuel rail beauty cover. I will have to fabricate some custom brackets to mount it as I want to keep the stock fuel rail cover.
    Ignore the copper DET can custom knock sensing hardware. (This works great BTW) Stick a tube on the end of it and pipe it into the cab with some cheap stethoscope ears. Best way to hear the ringy ding dinggiess of death.
    Turbo Manifold and exhaust center section should be done soon. From there I will put the car back together and continue my journey toward a properly working high HP E34.
    Some positives to note:
    The engine is staying cool. (at least I think it is) I do want to add a rear coolant take off to the back of the cylinder head. Jury is still out on a final decision. I started a general discussion thread on the idea.
    The engine runs well on the 800cc injectors, and it was fairly easy to remap the car as I have most of the important settings already correct in the LINK ECU. Current boost @ .8 bar shows about 56% duty on the new injectors. Sweet.
    I found the source of my wideband issue dropping full rich. Turns out it was not the wideband unit or the gauge controller. I had a sliced vacuum signal line going to the ECUs map sensor. The leak was causing my injector PW to go nuts.
    The CCV system with 3 AN 10 vents is working very well. The rear main seal is not leaking anymore (for now), and the oil scavenge system is working. There are no more small puffs of blue smoke out the exhaust under load. Adding additional venting to the crank case solved the problem.
    Although I still have no updated HP numbers, I feel the next (and hopefully final round) of tuning will give good results. Due to the fuel pressure drop issue I couldn't safely run more than .8 bar of boost. Assuming the boost levels are the same as before the HP is still in the 330-wheel range. We made this during dyno session 2. I had a slew of problems including a big boost leak during that session. I feel with those issues sorted the engine would have made closer to 400 hp.
    The hot summer months are here in southern Utah. With temps well over 110 into August and September It is likely I will not mess with boost levels until it starts to cool down. By October things are cooling off so for now I will enjoy low boost with proper fuel pressure until then.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Dj Buttchug
      • Jun 2010
      • 7688
      #617
      A few shots of the SPA manifold shielding finished. Still have exhaust center section to do from the downpipe to the resonator. I had to recess each runner so the exhaust studs will clear the insulation.
      Ig:ryno_pzk
      • 2mAn
        Señior Mod
        • 21075
        #618
        Looks awesome
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • varg
          Florida Turbo Man
          • May 2014
          • 3437
          #619
          I really should get around to logging my fuel pressure one of these days. Nice work on the heat shielding/lagging. I recently did this to the downpipe on my FD and it's kind of a pain in the ass.
          IG @turbovarg
          '91 318is, M20 turbo
          • Northern
            I like cupcakes & sh!tboxes
            • 5284
            #620
            Heat shielding looks spectacular.
            Originally posted by priapism
            Originally posted by shameson
            • Dj Buttchug
              • Jun 2010
              • 7688
              #621
              Thanks dudes. Big time pain in the ass for sure. Very time consuming. Hoping to have the E34 back running here soon. Serious lack of motivation lately ha
              Ig:ryno_pzk
              • Dj Buttchug
                • Jun 2010
                • 7688
                #622
                Manifold and turbo exhaust housing back in with some help from my 10 month old.
                Yes my car is sitting on cinder blocks.
                Yes its sketchy.
                Yes its also ghetto.
                Ig:ryno_pzk
                • 2mAn
                  Señior Mod
                  • 21075
                  #623
                  Yes its sketchy.
                  Yes, thats what winning looks like.
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • Northern
                    • 5284
                    #624
                    jeeeeesus why are the blocks sideways? At least rotate those things 90deg so they're not on their sides. Not sure how I missed this in the earlier post
                    I'm sorry if I'm coming across as a dick but that is super sketchy and I don't want this thread to suddenly stop getting updated.
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      #625
                      Was only temporary as I need to move the steering arms to the right to install the turbo charger.
                      Agreed, very sketchy.
                      Thread will continue as we are off the blocks now and the car is running again.
                      I do appreciate the concern. Yes I may be a questionable parent for allowing my child underneath.
                      Ig:ryno_pzk
                      • Northern
                        • 5284
                        #626
                        we're all questionable parents in some respect.
                        Better than an ipad.
                        • Dj Buttchug
                          • Jun 2010
                          • 7688
                          #627
                          Finally got around to cleaning the underside. Before
                          And After
                          Not dry-ice quality but the amazon special degreaser and a cheap electric pressure washer got a good bit of the road grime buttholes off the underside.
                          Ig:ryno_pzk
                          • LateFan
                            • May 2013
                            • 4436
                            #628
                            What is the cylindrical finned bit on the front cross member? Is that an oil cooler?
                            Also - there are no Emma Watsons posted..
                            • Dj Buttchug
                              • Jun 2010
                              • 7688
                              #629
                              That is a secondary engine coolant cooler. Oil cooler is mounted in front directly behind the center vent cutout.
                              The Watson content is slim these days. R3v was a different place many moons ago.
                              Ig:ryno_pzk
