Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #1951
    So this whole oil pan repair has become quite the project.
    It has snowballed into replacing the power steering pump, fuel lines, engine and trans mounts.
    Ive known my power steering was dying for a long time. Its the second used zf pump. New ones are NLA. Last time I tried to buy one there were no options. This time I stumbled upon a new AAE unit offered through bimmerworld, so I'll give it a shot. I also saw rockauto offers rebuilt units.
    Sent from my SM-S931U using Tapatalk
    Shadetree30
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      #1952
      Originally posted by Sh3rpak!ng
      Ill report back with some review.
      I also have ball jointed control arms. But running a normal guibo, and 5lb flywheel (clutch masters small twin disc).
      Sounds great. Turbo/WG/downpipe is all super tight, so any info you can gather on position delta would be huge.
      Forgot to include I'm on a cheap-o FX racing ""stage 3"" single mass/6-puck/Sachs HD setup. Lighter than an M20 flywheel but nowhere near 5lbs.
      I had the FW/PP balanced before install but they didn't remove much.
      Originally posted by priapism
      Originally posted by shameson
      • Chilezen
        I weld cats
        • Dec 2013
        • 1944
        #1953
        5lb flywheel, and what's the clutch pack weigh? I bought the lightweight kit from UUC and I was warned that the transmission would rattle due to less inertia, and they were right, the damn thing rattles every day once the car warms up. They said to fill up half the trans with a quart of thicker oil (I don't remember which exactly) to reduce the rattle. It's still pretty annoying. But it will stop once I press the clutch in. Kind of makes me think the TO bearing is junk.
        So I'm wondering, do you also have that problem with a lightweight setup? Transmission rattle when the car is idling?
        Currently building a badass coffee table
        Random stuff on insta @kevanromero
        • Sh3rpak!ng
          • Jan 2014
          • 2667
          #1954
          akg mounts shifted the engine about 1/2" to the passenger side
          Shadetree30
          • Sh3rpak!ng
            • Jan 2014
            • 2667
            #1955
            The whole unit is ~18lbs. And yes it rattles and vibrates like a mofo. Pushing the clutch in also quiets. Doesn't sound like anything wrong with your setup, especially if you don't notice any performance issues. Ive literally had a few people warn me that "my car is broken" Ha!
            Shadetree30
            • Chilezen
              I weld cats
              • Dec 2013
              • 1944
              #1956
              Well for most swaps, that means a little extra room for a brake booster.
              You have a chassis-mounted shifter, right? Does that setup have enough play to allow for the engine's shift? (pun intended)
              • Sh3rpak!ng
                • Jan 2014
                • 2667
                #1957
                Yea shifter will be fine. Ill probably have to adjust it though.
                Shadetree30
                • Sh3rpak!ng
                  • Jan 2014
                  • 2667
                  #1958
                  Originally posted by moatilliatta
                  Hey, I am going to recommend the high volume vac S54 oil pump.
                  Save you some time, and noisy lifters..
                  And for good lord, use the AKG swap mounts with Rouge trans mounts. Those Delrin rigs with buzz bomb the car apart. :)
                  I seem to be having fitment issues. Angles don't really line up. I followed AKG instructions. Set everything up loose. Still sits wonky.
                  Shadetree30
                  • amcp
                    • 489
                    #1959
                    Trans mounts are loose too?
                    The AKG mount isn't sitting flush on the crossmember. I had mine sitting flush then the arms wobbled in. I used a 2x4 under the oil pan to assist, made it a bit easier.
                    • Digitalwave
                      is a poseur
                      • 6302
                      #1960
                      ^^ That mount will tear in no time if left like that. No advice on why it fits like that, though.
                      How much NVH that comes from solid mounts is largely dependent on how well the flywheel and pressure plate are balanced, in my experience.
                      RISING EDGE
                      • Sh3rpak!ng
                        • Jan 2014
                        • 2667
                        #1961
                        Interesting. Both my previous revshift mounts, and the condor mounts, both had offset bolt positions side to side, vs these AKG mounts are symmetrical. I seem to be fighting this difference. Though I did manage to get them sitting more flat with much wiggling when settling. Still doesn't seem right. Gonna leave it for now cause I planned to drive it this weekend. Will revisit and reach out to AKG.
                        Shadetree30
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          #1962
                          I hear ya. No reason to believe there's any inherent imbalance with my rotating assembly. It was fully balanced years ago when I built the engine. Just figured "while I was in there" I would swap the mounts for something a touch softer and perhaps cut a bit of NVH.
                          Shadetree30
                          • Northern
                            • 5284
                            #1963
                            (pic)
                            Thank you very much! Saves me some money, or at least lets me know the level of effort is a lot higher than I was hoping.
                            Almost looks like that mount is 180deg out? Maybe just the viewing angle.
                            • s14brent
                              • Mar 2014
                              • 573
                              #1964
                              I had this issue as well with my AKG's. L/R were identical iirc so it didn't matter if i swapped them around or flipped them at all - it's been a LONG time since i addressed this though. I ended up throwing some washers under it to raise the motor for header clearance and it sat pretty flat, but I was never happy with that. I have some solid aluminum AKG's for 24v to go in next time, but have been 2nd guessing going solid mounts for quite some time now. I think custom motor mount arms might be the solution I need to use these properly - or just buy the revshifts. Last time I checked the motor mounts have been taking all the abuse I've thrown at it over the years drifting, but its still not an excuse for fresh production mounts to have this issue 10 years later..I'll check back to see what they say to you
                              89 325i 4dr s52
                              02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
                              21' Toyota Tacoma TRD OR 4x4 6 speed Manual
                              • almostacrayon
                                • Nov 2012
                                • 157
                                #1965
                                There is a trick to doing it. Are you using a load leveler?
                                Since there is so much weight on the driver side (rhd car) you need to use a strap or something to pull up the engine to get it to line up on the pas side. I do this with the driver side arm off.
                                Once the pas side is all in i snug the nuts up and then work on getting the engine mount and arm in and aligned then slowly lower it via the engine crane.
                                Since all the weight is on the driver side it is easier for it to fall into place
                                Not sure if that makes sense or not?
ID:	10143703 Click image for larger version
ID:	10143704 Click image for larger version
