1990 325is restomod project aka "Klaus"
  • Staszek
    • 2533
    #271
    Ok last update of the weekend. I feel like I got a lot accomplished and almost nothing accomplished at the same time :roll:
    So I traced back the gnawed on, it did go to the evap system and was still connected, I pulled the cover off to get to it and I have never seen so much corrosion coming out from behind the cover. I am assuming it was partially rust and maybe some hind of coating, I have no idea, but all that stuff on the ground around the hose is from behind the panel covering it.
    It was a bitch to get out, I hope that was because of the corrosion, hopefully the new one will slide in easier.
    I cleaned up the wheel well and painted it with rust inhibitor, I will be doing the Wurth this week.
    Last but not least, moved over all the tubes which were in good shape, fuel pump, sensors and grommets to the new tank. I ddnt install it yet, I ordered some new rubber fuel lines and that evap line I will install it all together. Love having a clean tank with no dents!
    Oh and I degreased and power washed the bottom of the car today so I have a nice clean surface for the Wurth underbody spray.
    Im exhausted and it feels like I still have so much work to do just to get wheels back on the car.
    • MCreally?
      • Apr 2017
      • 52
      #272
      Door panels
      Great work so far! Where did you get those door cards?
      • Staszek
        • 2533
        #273
        Thanks! I bought them from a guy in Germany.
        https://www.ebay.com/usr/design-part...p2047675.l2559
        • Staszek
          • 2533
          #274
          So onto the rear wheel bearings so I can strip and paint the trailing arms.
          First off, I should have at least taken these off before they were off the car, what a pain in the ass without the weight of the vehicle.
          Anyway got the clip off and the hubs off with a little leverage from a large tamper bar and some lug nuts.
          Used the same lug nuts to remove the hub.
          Of course the bearing was stuck in the trailing arm. So I used a contraption I saw on a youtube video to remove the bearings. 3' to 4" PVC coupler, 5/8" threaded rod, a few nuts and washers and my 46mm socket.
          It worked fantastic on the first one, bearing came right out with a lot of turning.
          • alistairolsen
            • Jul 2017
            • 191
            #275
            Looking great so far, love the new interior!
            • brokecollegekid
              • Aug 2015
              • 158
              #276
              I've been waiting to see updates on this. Can't wait to see it done if you take it to car shows around the Chicago area.
              • Staszek
                • 2533
                #277
                The engine should be in and done in the spring. The paint sometime next year hopefully if I have time and cash:)
                • 2mAn
                  Señior Mod
                  • 20989
                  #278
                  I shouldve looked through the entire thread before my PM. sorry about that
                  This thing is coming along quite nicely. Keep the recipts, but never EVER add them up!
                  I think I have the same headunit, I got my phone synced and its quite nice
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • bradnic
                    • Jul 2012
                    • 3554
                    #279
                    I have a harbor freight bearing puller if you need one
                    HOWTOs:
                    DB vert plastic bumpers
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • Staszek
                      • 2533
                      #280
                      Thanks! I did finally get the thing out, I cut a little to release the pressure and pulled the second one out.
                      I think I was drinking last night because after all that work I decided to trade them in for the Garagistic reinforced trailing arms. I shipped them out this morning and I am waiting for my matching set to go with the new subframe.
                      I should hopefully have everything buttoned back up in a week or so when it comes in.
                      I ordered new brake lines and a bender plus a new T. They were not horrible but the parts were cheap enough to just replace while I had everything down.
                      • Staszek
                        • 2533
                        #281
                        Started painting the chrome trim today. I did three coats of SEM Primer after I sanded them down. Need to do another light sanding and then paint. After that another light sanding and do a satin clear coat. The one chrome piece on below the rear window I could not for the life of me figure out how to get it off without damaging it so I had to pain on the car.
                        • Staszek
                          • 2533
                          #282
                          More parts yay!
                          • AWDBOB
                            hooptie connoisseur
                            • Aug 2013
                            • 4496
                            #283
                            Nice! What sandpaper did you use to prep it for primer?
                            • Staszek
                              • 2533
                              #284
                              I used 180 to get a good grit, then I went to 320 to make it fine and smooth. I will wet sand a bit with 600 before I put the paint on, trying to get as smooth as possible so I can match the OEM shadowline. Unfortunetly my car was missing chrome on one side, so I bought new OEM shadowline trim. I am trying to match it as close as possible.
                              I am not really good at painting lol but I am taking a lot of time with these.
                              • 0-60 freak
                                • Jun 2015
                                • 511
                                #285
                                I would scuff and shoot the new piece of trim along with the old , sem trim black is the only way to go
                                Sent from my SM-N950U using Tapatalk
                                Current Cars:
                                2016 PORSCHE GT3 RS
                                2017 FERRARI 488GTB
                                2018 RAPTOR CREW CAB
                                1991 318is SLICKTOP H&R SPRING SEMA CAR
                                1991 318IS SLICKTOP STERLING SILVER
                                1990 325ic BRONZIT/AUTO :)
                                1989 E30 M3 (SOLD AWAITING SHIPPING)
                                On Order:
                                2018 DODGE DEMON
                                Searching for:
                                CLEAN E30'S
                                S54 DRIVETRAIN
                                E30 DASH
                                E30 PARTS
