Project Weißer Regen: 91 318iS Restomod
  • rturbo 930
    • Dec 2005
    • 2629
    #271
    The end result from vapor blasting is really impressive. Wow.
    • Balleristic31
      • Aug 2009
      • 4198
      #272
      I know this is meant to be a pretty oem original rebuild, but have you considered upgrading the lower timing case to the later m42 version? Much safer design that eliminates the idler wheel and the potential flaws in the early castings that have been known to fail.
      Just something to think about before you put it all back together!
      -NICK
      • Powling
        • Jan 2015
        • 1291
        #273
        With the vapour blasting, do you need to do anything to protect the metal after its blasted? Or is it good to go right after blasting?
        Steve • Toronto
        1991 318is • Brillantrot
        Build Thread
        • Jordan
          • 12916
          #274
          Are you planning to still run the throttle body heater and the rest of the mess?
          I intent to restore that back to OE appearance, but I may not actually plumb the coolant loop in. We'll see when I get there.
          I'm aware of the inner timing case failures, but its really a non issue blown out of proportion by the internet.
          I guess that depends on where you live. Down here in Texas cast aluminum stays bright an clean for years. Up where you live? Salt in the winter air probably starts dissolving it right after it leaves the machine
          In the case of those that live up north with liberal applications of sodium chlorinate on the roads I'd say yes either seal it, or don't drive in it.
          https://mtechniqueabs.com/
          • Jordan
            • 12916
            #275
            Started to reorganize a few things and pull out some new parts to put a few sub assemblies together.
            Freshly plated studs reinstalled in lower intake manifold
            Shifter linkage
            Steering column, which was blown apart to be able to plate the main housing bracket and vapor blast the ignition lock housing.
            Close up of the bottom bearing with spacer and dust shield
            Top side
            Fully reassembled
            • parkerbink
              • Jun 2004
              • 10138
              #276
              Simply amazing!
              • Powling
                • Jan 2015
                • 1291
                #277
                Hmm I wonder if it would still be a factor with a 'summer only' car.
                Either way, how would you seal it?
                Steve • Toronto
                Build Thread
                • didithepest
                  • May 2017
                  • 45
                  #278
                  Oh I am going to say is wow - I need to start taking notes - Much respect
                  • Cha Ching
                    • 1668
                    #279
                    Your attention to detail is awe-inspiring. I'm taking copious notes.
                      • 37834
                      #280
                      Love the eye candy! Those tires fit the Euro weaves nicely too.
                      Grover Beach, California
                      BimmerHeads.com
                      • wazzu70
                        • Jan 2005
                        • 1143
                        #281
                        The vapor blasted surfaces look great. Never had heard of that process before!
                        The cad plated bits look great, Im liking it better than polished/stainless/powdercoat!
                        -Nick
                        M42 on VEMS
                        • dasmanschaft012
                          • Apr 2014
                          • 642
                          #282
                          If you guys haven't heard about vapor honing before, Jay leno had a specialist on his show.
                          We're in deep now boys
                          1988 325i SETA - Daily driver
                          1988 340iL - Track car
                          My M60 V8 swap thread here
                          [oo==OO==oo]
                          • Jordan
                            • 12916
                            #283
                            I don't think its going to be any kind of issue down here in Texas anyway. My 14 535i daily driver still has pristine aluminum components, as does my wifes 13 X3 and both cars are year round dailys.
                            You and me both, thought about getting a machine for the shop yet?
                            I'm happy with the tire choice, they are nice and square with the wheel protector lip sidewall design.
                            https://www.youtube.com/watch?v=30HBumz3zJ4
                            This build exists largely because I found this process ~6 months ago and I knew I had to build a car around it. Thats a good video for the process, although it take a lot longer than that (Video was cut to make it look faster)
                            • Jordan
                              • 12916
                              #284
                              I've been looking for a nice set of late model tail lamps this whole time and it *just* occurred to me I could probably buy them new. Sure enough they were still available, and about $225 for the pair was a no brainer IMO.
                              They come super shiny of course, and with plastic film over the lenses for protection.. and nice supple gaskets.
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #285
                                Wow 225 for the pair is cheap! Early model ones are 280 a side last I looked.
                                1991 318i 4dr slick top
                                Mtech 2 turbo restoration
