E30 the biowaste - metamorphosis to M52
  • Motheye99
    • May 2018
    • 853
    What wheels are you using, and I like the M3 Rep fenders
    91' 318is 90' 325is
    Originally posted by Sonny
    Buy the E30s, they ain't gonna last long
    E30 can make you, E30 can break you
    "He who controls the Nova's, controls the Boomers"
    • jeenyus
      • Aug 2011
      • 2064
      "impossible"
      • hasa
        • May 2013
        • 306
        The wheels in the picture are ATS DTC 9x17. It's very likely I'm going to use them, but by now they are just borrowed from my friend to test fitment. It seems that I need at least 50mm spacers for each side even with the wider Z-hubs. Less for the front obviously.
        • hasa
          • May 2013
          • 306
          First cut Sent from my iPhone using Tapatalk
          • hasa
            • May 2013
            • 306
            Fibreglass work continues Sent from my iPhone using Tapatalk
            • moatilliatta
              • 6151
              Progress?
              How are the MRT Arms working out?
              @Zakspeed_US
              • hasa
                • May 2013
                • 306
                Mrt stuff looks good. I’m not yet convinced if the arms are long enough for my setup but that will be sorted out later. Preliminary fit for the bodykit is ok by now. I need to continue with rear suspension. Sent from my iPhone using Tapatalk
                • hasa
                  • May 2013
                  • 306
                  • hasa
                    • May 2013
                    • 306
                    This needs upgrade. Condor bushings and MRT rose joint setup. Current mushy powerflex bushings need to go. Sent from my iPhone using Tapatalk
                    • hasa
                      • May 2013
                      • 306
                      I fixed the arms location to the subframe by welding. Next some cut and welding more. It seems that I bought wrong shims from Condor so I placed just regular shims to mount the purple E46 rack. Sent from my iPhone using Tapatalk
                      • hasa
                        • May 2013
                        • 306
                        Some progress has happened. Bodykit installed Problems with fender clearance I considered cutting the control arm with an angle grinder, but it seems to generate insane amounts of heat. Which is obviously bad idea. So here we are. 10mm taken off. Sent from my iPhone using Tapatalk
                        • moatilliatta
                          • 6151
                          Looks like you have the 12* sweep angle setup subframe?
                          @Zakspeed_US
                          • hasa
                            • May 2013
                            • 306
                            Yes, I had something like that.
                            Current plan is to use E36 Compact/Z3 subframe with 12mm riser bushings and toe/camber correction kit. It is much more simple setup.
                            • hasa
                              • May 2013
                              • 306
                              I had to modify inner fenders to make some room for the tires. e30 is a small car! Sent from my iPhone using Tapatalk
                              • litu
                                • 837
                                Looking good...
                                https://www.facebook.com/Cry_77_IX-110483784967661
                                https://www.instagram.com/cry_77_ix/
