E30 the biowaste - metamorphosis to M52
  • hasa
    • May 2013
    • 307
    #31
    Finally I got my steering shaft solution installed. I truly hope that it works. Also some stoppers were required for the purple rack. Sent from my iPhone using Tapatalk
    • hasa
      • May 2013
      • 307
      #32
      Bumper reinforcement Now it kinda fits... badly Sent from my iPhone using Tapatalk
      • hasa
        • May 2013
        • 307
        #33
        Has somebody else faced quality problems with the Garagistic camber/toe-kit? This simply does not work as the machined piece has wrong dimensions. Sent from my iPhone using Tapatalk
        • amcp
          • 489
          #34
          I hate to talk shit about any company that makes parts for our car but that seems like par for the course for ANY Garagistic part I've purchased. Its either a hair larger or smaller than the its supposed to be.
          • hasa
            • May 2013
            • 307
            #35
            Could this be ok when using delrin bushings? I mean, how the eccentric adjustment would work when the bushings are almost solid. I try to find good sides from this issue. Sent from my iPhone using Tapatalk
            • Metallated
              • Dec 2016
              • 1074
              #36
              My experience as well.
              I like the company, but I feel they're too focused on coming up with new stuff, and have lost quality by growing so fast...
              • hasa
                • May 2013
                • 307
                #37
                In meanwhile I purchased another set of camber plates and prepped the Z-axle to a jig for modifications. Left toe is slightly out and way too much camber at both side. 4-4.5 degrees. Camber plate placement must be done carefully. Sent from my iPhone using Tapatalk
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #38
                  You can correct camber/toe if you raise the height of the cross member in the chassis, too. Would have to read back at your cross member connection choice, but it may be as simple as raising it a few MM.
                  Those adjusters tend to move when on track, the ones with serrations hold better, but are limited on adjustment with the notches.
                  john@m20guru.com
                  Links:
                  • 2mAn
                    Señior Mod
                    • 20982
                    #39
                    Hope this thing ends up back on the track in 2021
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    Make R3V Great Again -2020
                    • hasa
                      • May 2013
                      • 307
                      #40
                      Originally posted by ForcedFirebird
                      You can correct camber/toe if you raise the height of the cross member in the chassis, too. Would have to read back at your cross member connection choice, but it may be as simple as raising it a few MM. Those adjusters tend to move when on track, the ones with serrations hold better, but are limited on adjustment with the notches.
                      Yes you are absolutely correct! I purchased one serrated kit from Ebay, but the adjustment is way too coarse for toe-in. It has 3.5mm steps which is alot. And this kit missed one plate. Sent from my iPhone using Tapatalk
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #41
                        You are using a jig and have the serrated adjusters, perhaps you could do all your camber/toe corrections using both the serrated adjusters and cross member height before you even get it in the car. When using the serrated adjusters, you can notch the cross member first, bolt them in place without welding so you can move them around, then tack, remove, final weld.
                        Also, side note, you may want to blur the address on your packages in public photos. Just read an article about new hackers using photos to get personal information. Your screen name "hasa" makes sense now.
                        john@m20guru.com
                        Links:
                        • hasa
                          • May 2013
                          • 307
                          #42
                          Yes, I'll do something like this as soon I get the missing plate.
                          I have couple of goals for this modification
                          • Get the toe & camber corrected
                          • Fix the anti-geometries that are f..ked up when the car is heavily lowered
                          • keep the roll center as much original as possible
                          So I will lift the mounting points as high I can without opening the rear passenger floor ( like done in DTM cars where rules maybe prevented rising higher ). I already have the 12mm riser subframe bushings on the place, but there is still way to go.
                          ForcedFirebird Thanks for the reminder about privacy... fortunately the address points to local freight pick up point.
                          • hasa
                            • May 2013
                            • 307
                            #43
                            1 done, 3 to go.
                            • hasa
                              • May 2013
                              • 307
                              #44
                              Different day, still same story. Almost done. Sent from my iPhone using Tapatalk
                              • moatilliatta
                                • 6152
                                #45
                                OH man.. those are going to suck to tighten. Check out the IE serrated ones, every serration is about .25 degree adjustment, and they fit into slots so they are easy to tighten.
                                https://www.iemotorsport.com/product...si-lock-style/
                                I welded a nut on the threaded back side because you know that's gonna strip out...
                                @Zakspeed_US
