Nonsense Thread
  • roguetoaster
    Biggus Tippus
    • 7830
    #15001
    No.
    The unholy trinity is much more likely to be English design, Italian running gear, and French electricals.
    • McGyver
      • 4636
      #15002
      ^Yeah, but I bet you can stick a paperclip into something somewhere to reset that.
      • econti
        • May 2014
        • 1152
        #15003
        Originally posted by Northern
        Even worse, these are like 50% Ford lol. Especially the Lion V6 powerstroke diesel ones with the snappy cranks.
        Every one with a snapped crank that I've seen seems to have obliterated bearings, so it might be an oil pump/oiling issue more than anything. Otherwise I would really want one for the torque/fuel economy/webasto heater.
        Yeah we didn't get the diesels here, I think all the way back to the original Disco. You can get the D5 here up to 2020 with a Td6... but it's supposedly the same engine as the LR3/4 so in theory it has the same issues but you tend to hear about DPF and EGR problems more than anything. Not sure if there are simply fewer D5s around (particularly diesels) or if there's something else different about them.
        I am pretty interested in one as an XC90 replacement as they're very cheap. Delete the crap and hopefully enjoy.
        The same motor in Jaguars and Citroens don't do the crank but they are pretty much the same, nobody's figured out an actual root cause. The D5s don't do it, and our Ford Rangers now use an evolution of that motor with a stronger crank and they don't do it either. So the factory know that its a problem however refuse to do something about it. You win some you lose some
        • varg
          Florida Turbo Man
          • May 2014
          • 3439
          #15004
          Is the crank breaking and causing bearing failure because of oil pressure loss through the fracture when the engine continues to run, or are the bearings failing first? I'd expect a lot of heat damage to the journals in the case of the latter.
          IG @turbovarg
          '91 318is, M20 turbo
          • econti
            • May 2014
            • 1152
            #15005
            Snaps first, heat damage isn't bad if its caught early. Friend had one at his shop that seemed to run perfectly fine, just a bit of vibration at idle. The snap kept it 'keyed' together so it still transmitted power.
            When someone figures out how to do plug and play M57 swaps, they will make a lot of money.
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              #15006
              There are a few M57 swapped ones out there now. Seems reasonably doable, but M57s aren't far off hen's teeth here.
              There are ~half a dozen M57 Land Rover swap groups out there in facebook land with decent info.
              Mostly annoying that the ZF6HP is different on both ends between the two so you need an adapter plate on one end or the other.
              Not sure if 8HP is an option at the moment outside of with an aftermarket controller.
              EDC17 (Late E70 X5 M57 in NA) didn't come with an 8HP, but people smarter than me are poking around and saying it may yet be possible.
              I do like the 5.0 AJ133 though. Sounds good and 375hp/375ftlb is definitely enough for me, it's just a pig on fuel...
              Originally posted by priapism
              Originally posted by shameson
              • Northern
                • 5284
                #15007
                https://www.schmiedmann.com/en/produ...t=BLSE30SREDWE
                Anyone see these late model "Startec" lookalikes yet? I want them.
                • 2mAn
                  SeƱior Mod
                  • 21085
                  #15008
                  I think its up to us idiots left here to try out these aftermarket parts and report to everyone else...
                  PS TERRIBLE review video coming soon about the Turkish E30 door seals
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • Northern
                    • 5284
                    #15009
                    I hope you mean the content is terrible and not the seal fitment lol
                    • roguetoaster
                      Biggus Tippus
                      • 7830
                      #15010
                      As long as he's not blowing seals it'll be fine.
                      • 2mAn
                        SeƱior Mod
                        • 21085
                        #15011
                        I guess you guys will have to spend the ~5 minutes to watch the review video...
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • MrBurgundy
                          R3V Degenerate
                          • Mar 2012
                          • 5616
                          #15012
                          I think he is
                          Click image for larger version  Name:	harbor-seal-phoca-vitulina-face-17498743.jpg Views:	0 Size:	86.2 KB ID:	10156476
                          • JasonWilson48
                            Not my real name
                            • Jan 2025
                            • 258
                            #15013
                            5 MINUTES OF MY TIME!!! IN THIS ECONOMY?!?
                            How am I going to doom scroll TIKTOK for an hour before bed if I do that?
                            89' Build
                            2009 Honda Element (Daily/Beater)
                            • JasonWilson48
                              Not my real name
                              • Jan 2025
                              • 258
                              #15014
                              Now THIS I can spare 5 minutes of my time to watch... for research purposes... obviously.
                              89' Build
                              • McGyver
                                • 4636
                                #15015
                                If someone could make a summary video of the review video, that'd be greaaaaaat.
                                Also, Garagistic has released some Startech/MHW lookalikes that I've been thinking about. I guess someone in china made some coppies and various distributors are picking them up to resell?
