Colorado general chat...
This is a sticky topic.
  • Bimmerman325i
    • 6854
    #4276
    Originally posted by Roland H
    Alex - Willing to bet it's the pad compound. I'm probably available early next week, let me know when you get back from work and we can do your suspension, and take a look at your brakes too.
    Brad - I always either bed them in, or use them very aggressively when I first slap them on.
    David - Can't watch Videos at work.... :(
    Watch it when you can, it's hilariously awesome.
    2017 Chevrolet SS, 6MT
    95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
    98 M3/4/5 (stock)
    • Cloudbase
      • 1795
      #4277
      Thanks guys. My gut feeling is it's more than pad compound. I ordered new ceramic composite pads that Cal will have in tomorrow. I have a set of rotors that came with the car, but they are Napa Premium brand with a huge Made in China stamped on the box. I'm gonna swap them out in the morning. I'll replace them with rotors with something proper when I figure out what the problem is.
      Roland I'm going to order a new wheel bearing and do that while front end is torn apart. I'll get new rear shock mounts from Ben, should I order anything else? I've got the 15mm drop hats. Should I order new washers? My rubber spring pads are shot, was going to order new OEM ones. What about bump stops? If I can scrounge the cash I'll get new subframe and trailing arm bushings too, makes sense to do that while taking the rear end apart.
      JOY IS AN E30...
      • Roland H
        • 4480
        #4278
        Your original washers should be fine, bump stops should only be replaced if they're broken. subframe and trailing arm bushings are a HUGE undertaking fyi. Basic shocks and springs are one thing, but the bushings are a pita.
        • blefevre
          • Dec 2008
          • 4287
          #4279
          Get new front upper strut bearings/mounts.
          - E30, DSM, Golf R, Mazda 3 Skyactiv
          • Bimmerman325i
            • 6854
            #4280
            Psh, just replace everything while you're taking the car apart. Might as well do it once and not worry about that one thing you left undone.
            98 M3/4/5 (stock)
            • Cloudbase
              • 1795
              #4281
              I wasn't sure about the upper bearings and mounts.
              I always have a "how deep to go" conversation in my head when I start tearing things apart. I can do the subframe stuff later. I have a homemade tool and want to practice on the E30 before I do the M Coupe. At least I don't have to pull the tie rods to do the rear.
              JOY IS AN E30...
              • Bimmerman325i
                • 6854
                #4282
                Well, you can DD another car or two while the E30's being worked on, ya? Just do it at once and make it a project.
                98 M3/4/5 (stock)
                • iamsam
                  • Jun 2008
                  • 176
                  #4283
                  So what are we arguing about here? Someone give me the super brief cliffs
                  yeah yeah i know....
                  • Cloudbase
                    • 1795
                    #4284
                    E30 Suspension (brakes earlier)
                    It's not DDing the other cars, it's M Coupe being exposed to rain and snow while the E30 is up on blocks. I know, I know...
                    JOY IS AN E30...
                    • blefevre
                      • Dec 2008
                      • 4287
                      #4285
                      Get the upper strut mounts. Not only do the bearings wear but the bushings to too, double wear item. If you are doing springs there is no reason not to do the upper mounts too. Do it right.
                      • iamsam
                        • Jun 2008
                        • 176
                        #4286
                        Alex, H&R Race or Sport, Bilstien Sports, E90 drop hats, IE RSMs, dun du-dun dun DONE
                        • Bimmerman325i
                          • 6854
                          #4287
                          For a DD I wouldn't go H&R Race low, nor would I buy any IE part. Bimmerworld, GC, or Turner will sell good RSMs, so will JT Designs.
                          Unless IE's RSM is really that much better than anyone else's, I wouldn't buy it. Their camber plates suck monkey trucker scrotum.
                          98 M3/4/5 (stock)
                          • iamsam
                            • Jun 2008
                            • 176
                            #4288
                            their RSMs aren't bad. Super simple design, not much to go wrong, plus mine have worked for years, and are in perfect shape despite daily driving, autocross, track day, and a couple rally races. So there is firsthand experience for ya. They came with the reinforcement plates, alot of the other options you had to buy the plates seperately for $20 extra, that is what sold me on these at first.
                            But yep, they work great, through years of brutal abuse.
                            • Bimmerman325i
                              • 6854
                              #4289
                              Hm. they don't look like crap, so maybe they're not.
                              98 M3/4/5 (stock)
                              • fsmtnbiker
                                • Feb 2011
                                • 617
                                #4290
                                IE's motor mounts, on the other hand, are the biggest pieces of garbage I've ever seen someone try to pass off as a useable product.
                                Chris
                                97 M3
                                01 325
                                Weston Auto Gallery
