Colorado general chat...
This is a sticky topic.
  • iamsam
    • Jun 2008
    • 176
    #2776
    Insurance companies cancelled insurance??? that should be illegal!!
    • Bimmerman325i
      • 6854
      #2777
      Well, they did for that week.
      There has been a huge laugh-at-georgians'-inability-to-drive thread on bf.cot.
      2017 Chevrolet SS, 6MT
      95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
      98 M3/4/5 (stock)
      • blefevre
        • Dec 2008
        • 4287
        #2778
        Similar thing happened in Iowa a few years back. We had a typical summer storm with huge winds and tornados but it decided to throw in softball to melon size hail in the mix just for fun.
        Our entire town got destroyed more or less. State farm "cancelled" home and auto insurance for over half the town. A lot of my friends familys got really screwed with needing new cars and roofs. My family lucked out and we got enough money to fix all our crap. It is such a screwy business.
        - E30, DSM, Golf R, Mazda 3 Skyactiv
        • Cloudbase
          • 1795
          #2779
          "Folsom's the best road in Boulder" is a saying. Maybe that's faded into obscurity since I moved out of Boulder. I would stay on the neighborhood roads over that in the snow...
          New Running Issue:
          A week ago I felt the slightest hesitation at highway speed, 5th gear 75mph. So I'm driving to work, accelerating on to the highway after a right hand turn and I get a nasty stumble. I downshifted and got my revs over 4000RPM and it cleared up after about 30 seconds. Driving home from work just after starting it flat out quit. I had to rev the hell out of it to keep it going. After stalling 3 times it managed to clear. It hesitated a couple times on the way home at about 3000 RPMs, but I couldn't get it to duplicate when I got home.
          I suspect bad gas or water in my gas, but I fear it isn't that simple. When it hesitated on the way home in was in 5th gear and the RPMs indicated by the tach dropped from 3000 to below 2000 rpms almost instantly. If it was just loosing fuel the RPMs wouldn't drop that fast because I was in gear right????
          In the last 3 months I've replaced my ICV, Throttle Switch, Intake Boot, AFM, Coolant Temp sensor, ECU, and ground strap. Anyone had anything similar?
          JOY IS AN E30...
          • blefevre
            • Dec 2008
            • 4287
            #2780
            Have you touched the spark plugs?
            • monkeytaco
              • Jan 2010
              • 882
              #2781
              Cracked distributor cap? Bad rotor? Bad o2 sensor?
              If it always bogs at the same rpm, it could be o2. If it gets moisture in the cap/rotor it would be all over the place. Check the easy ones first...
              Looking for a clean e30 shell for a project.
              • Cloudbase
                • 1795
                #2782
                No, I was going to jiggle them when it was stalling in my work parking lot, but it wouldn't run long enough for me to get out there. Plus I would think it would be in the distributor or coil instead of just one plug. I don't have my plastic under cover on so I do wonder if water isn't getting into something. It's got new Bav Auto wires, coil, and distributor from the PO.
                Doesn't bog at a consistent RPM. I might check the distributor cap in the morning. I work early and won't have time to do a thorough diagnoss until Sat afternoon.
                JOY IS AN E30...
                • blefevre
                  • Dec 2008
                  • 4287
                  #2783
                  I thought O2 only did something during warm-up? Open loop vs closed loop.
                  • blefevre
                    • Dec 2008
                    • 4287
                    #2784
                    I dont have the cover on mine and it's never had a problem. The car is parked outside too. But it still could be bad of course.
                    • Cloudbase
                      • 1795
                      #2785
                      Wouldn't O2 throw a check engine light too?
                      JOY IS AN E30...
                      • hyperE30
                        • Sep 2009
                        • 2202
                        #2786
                        Man sucks the car is giving you some shit.. ready to sell?? jk.. hope you get it fixed up!!
                        HyperWerkz
                        89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
                        " enjoy the show "
                        • Roland H
                          • 4480
                          #2787
                          Sounds like you have an issue somewhere in your ignition system..
                          • Cloudbase
                            • 1795
                            #2788
                            If the tach takes a big drop as compared to the loss of road speed the cause will be something that is taking away timing data to the DME, a loss of power ground to the DME, or a fault in the DME.
                            Thought this might apply. I've spent the last 7 hours searching possible causes now it's 6:00am and I have to get up in an hour, shit!!!!!
                            J/k!!!!!!!
                            JOY IS AN E30...
                            • wh00sh
                              • Dec 2010
                              • 68
                              #2789
                              New Running Issue:
                              Sounds like fuel pump/filter to me. When was the last time any of this was serviced?
                              '88 iX Money Pit/Labor of Love
                              • Cloudbase
                                • 1795
                                #2790
                                New filter and lines in Oct. I'll pull the pump and test it tomorrow. I think it's electrical though.
                                JOY IS AN E30...
