PNW Chit Chat thread
  • Rennsport
    • 2139
    #27346
    Simplest way without having to do any fabrication. Not exactly cheap, but less than paying someone to weld tabs to the subframe.
    http://www.turnermotorsport.com/p-35...ac-street.aspx
    m106 1990 e30
    e36 daily
    e32 cruiser
    • the imitator
      • May 2013
      • 1006
      #27347
      Originally posted by Pdxseth
      If I'm not gonna drive it like it should be driven I may as well buy a Kia, I drive e30's because it's the only affordable car that can take the abuse I put them through.
      Not to mention how sexy they look :)
      I agree, once I get my swap put together I'm sure I wont be the kindest guy if I find myself alone on some backroads.
      Adjustable rear subframes are great as long as they don't pop out of adjustment, and if you're driving hard consistantly, I'm sure that can happen.
      Its as easy as just tack welding your adjustment in place.
      I will most likely be using revshift poly subframe riser mounts, using diff spacers. Unless a better option pops up.
      • DER E30
        • Sep 2013
        • 2343
        #27348
        I have no experience with these but they look better than the "offset washer" style...
        -Christian
        • iansane
          • 1341
          #27349
          Hey guys I'm going to be doing a full suspension refresh in a couple weeks and I'm curious what I can do for rear camber correction, I was thinking of using the condor 12mm subframe risers. Do I need the diff spacers too? I don't really understand how that stuff works. I'm on gc coils spun all the way down.
          I just did the weld in kit for the subframe. Can you weld? If so, it's ridiculously easy to do. I picked up a spare subframe from the JY for $15 so down time is nil. (I have to install it this week and get it re-aligned).
          84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
          • e30austin
            • 15382
            #27350
            I would so weld if I had a welder and knew how to. Have a few spare subframes, too.
            '70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
            • iansane
              • 1341
              #27351
              Dude. Welding is one of those things every car guy should learn how to do. It has come in handy so many times and lets you do so much more custom stuff. I started with a shitty harbor freight $50 MIG welder when I was 16 or so and eventually found a basically new lincoln140 on craigslist for $150. You don't perfect because a grinder and paint pretties up almost anything. I won't weld a cage or anything but making motor mounts, shock mounts, brackets, exhaust systems, etc are cake.
              • DER E30
                • Sep 2013
                • 2343
                #27352
                This, a thousand times this!
                Those harbor freight welders are terrible... After mine broke I picked up a lincoln 180 on craigslist and haven't looked back. A gas welder welds 100 times better than a flux core :up:
                Practice makes perfect, or at least much better... :rofl:
                -Christian
                • the imitator
                  • May 2013
                  • 1006
                  #27353
                  ;DI may have to give this shit a try, worst case I have 2 buddies that weld like mad, Aluminum reservoirs/aircraft welders.
                  I'm gonna weld my doors shut and jump threw my windows racecar style. Just for practice.
                  • DER E30
                    • Sep 2013
                    • 2343
                    #27354
                    Have fun with that! Use little tacks and limit the amount of heat to limit warpage! Thin metal sucks to weld on because it warps so easily...
                    Because racecar!!
                    -Christian
                    • Pdxseth
                      • May 2012
                      • 3124
                      #27355
                      I'm actually certified in mig and tig but I don't own a welder lol :(
                      On another note if anyone needs foglights for a euro valance, hella 550's are a perfect fit and I mean perfect! But if you want to make use of the covers that come with it you would have to modify(cut) the valance. I haven't decided if I'm going to do that yet, my valance is pretty beat up and amber Hellas are nla I was pretty lucky to find a set Bnib. So I just have to figure out if I care more about the valance or the fogs....
                      • e30austin
                        • 15382
                        #27356
                        Don't use the covers. If you care about them that much, take them out and get deletes.
                        • Pdxseth
                          • May 2012
                          • 3124
                          #27357
                          I didn't buy them not to install them. That's a waste of money. Although I probably won't use the covers because I don't want to have to get out of the car and pull them off when I hit fog.
                          • Wschnitz
                            • 8089
                            #27358
                            Theres also this thing called laminx...
                            willschnitz
                            • MPLFoster
                              • May 2013
                              • 1490
                              #27359
                              Originally posted by Wschnitz
                              laminx...
                              this.
                              i put that shit on all my headlights. tuff stuff.
                              form.follows.function IG @mplfoster
                              • DER E30
                                • Sep 2013
                                • 2343
                                #27360
                                Originally posted by 325islandhopper
                                this.
                                Yup me too. The highway I live on has too many semis throwing gravel (literally) to run bare glass headlights...
                                -Christian
